cap testing
  • pete g
    • Jan 2010
    • 20
    cap testing
    hi all, I recently built a esr meter. I need clarification on two of the parameters it measures. 1) memory effect. 2)sz value. also what values of these two would render a capacitor defective? thanks.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4979
    • New Zealand
    Re: cap testing
    I have never heard of an ESR meter which measures anything other than, well, ESR.
    Can you post photos of what you've actually built?
    -David VanHorn
    • pete g
      • Jan 2010
      • 20
      Re: cap testing
      hi, the meter I built is a Hungarian design. it measures memory, leakage and tan delta along with esr. great meter but kind of tough to get built. has some very critical components. anyway I'm adding an attachment where you find details. use google to translate.
      https://www.microsofttranslator.com/...eg_oldal1.html
      • vinceroger69
        • Mar 2012
        • 6714
        Re: cap testing
        This thread maybe worth a read if you have not seen it already
        https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
        • pete g
          • Jan 2010
          • 20
          Re: cap testing
          hi, does it measure in circuit. under 300mv output?
          • Agent24
            I see dead caps
            • Oct 2007
            • 4979
            • New Zealand
            Re: cap testing
            The 'memory' they speak of is likely dielectric absorption. I have not heard of this parameter changing due to a failure in the capacitor, at least nobody had mentioned it here that I'm aware of.
            Usually, a capacitor will fail totally; going shorted or open-circuit (these can also be intermittent faults), or, its ESR will become too high, leakage may become too high, capacitance may drop, or it may start breaking down under full voltage.
            For all these parameters, you can check the datasheet and see if your measurements are within the specified values. I imagine dielectric absorption is either listed there too, or can be calculated.
            As for 'sz value' I am not entirely sure what they are referring to (EDIT: looking at the photos, the meter displays Csz when showing measured capacity, so they probably mean capacitance), but in 99% of cases, capacitor faults will be found by checking ESR, leakage, capacitance, or voltage breakdown. If a capacitor passed all those tests, but you still had reason to suspect it as faulty, then at that point it would be faster/easier to just replace it.
            -David VanHorn
            • pete g
              • Jan 2010
              • 20
              Re: cap testing
              hi, I think sz is referring to leakage. the lcm meter I built shows memory on a scale of 1-99. is the lower value indicative of a better cap. if not important parameter why show it?
              • Agent24
                I see dead caps
                • Oct 2007
                • 4979
                • New Zealand
                Re: cap testing
                The meter shows "Csz" when displaying capacitance. I didn't see a photo where it displayed a leakage current.
                I don't know anything about the dielectric absorption. You will have to do some Google research... I have never seen anyone using it as a test to identify a bad capacitor. It may only be useful to know when designing a circuit, perhaps.
                -David VanHorn
                • pete g
                  • Jan 2010
                  • 20
                  Re: cap testing
                  hi, I thought sz might mean series impedance? I think your correct about memory being important in design.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4979
                    • New Zealand
                    Re: cap testing
                    I don't know. This is the only place I could find 'sz' mentioned, and it's clearly referring to capacitance. Where did you see it in the article?
                    -David VanHorn
                    • pete g
                      • Jan 2010
                      • 20
                      Re: cap testing
                      let me say there are literally hundreds of pages (forums) written about this meter. I thought somewhere I read that what it was. i'am probably wrong. it can't be series z. what do you think of this meter? worth the effort?
                      • rugger
                        • Feb 2005
                        • 55
                        Re: cap testing
                        Only problem with these LCR meters is that they don't work well for faulty capacitors.
                        They are sorta/kinda OK for capacitors in good condition. But no good for faulty or capacitors in otherwise poor condition.
                        My main tester is the peak atlas tester: https://www.peakelec.co.uk/acatalog/jz_esr60.html
                        • pete g
                          • Jan 2010
                          • 20
                          Re: cap testing
                          hi rugger, being an ex service tech for Philips, I accumulated a bunch of defective caps. I saved them. my experience has been that this cap checker lcm3 caught everyone of them. both for hi esr and low capacitance.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            Re: cap testing
                            lcm3
                            http://www.electronics-lab.com/proje...nced-lc-meter/
                            • pete g
                              • Jan 2010
                              • 20
                              Re: cap testing
                              hi, I made that one too. but for some unknown reason couldn't get it to work right. if anyone makes a successful build plz let me know.
                              • rugger
                                • Feb 2005
                                • 55
                                Re: cap testing
                                I probably should be clearer and state the right problems, as I was recalling from memory why I bought the expensive meter.
                                The main reason to get the more expensive meter is that you can often do ESR testing in-circuit with the expensive meter, so you don't have to unsolder the cap to do basic testing.
                                This meter is also a good design for in-circuit ESR testing, even though you build it yourself: http://www.altronics.com.au/p/k2574-esr-meter-kit/
                                • pete g
                                  • Jan 2010
                                  • 20
                                  Re: cap testing
                                  nice meter. $90 bucks, ouch!!!!
                                    Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                    by sam_sam_sam
                                    I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                    I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                    12-31-2023, 06:04 AM
                                  • chth96
                                    Is it possible to test small ceramic disc capacitor with analogue meter?
                                    by chth96
                                    I read EBOOK of Testing Electronic Component and found that
                                    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                    Is it really possible to test small ceramic disc capacitor with analogue...
                                    03-09-2024, 10:03 PM
                                  • bauto601
                                    KDM 480W PSU upgrade succes! (opinions?)
                                    by bauto601
                                    Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                    A "nice" YoungYear unit? - Badcaps
                                    The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                    12-26-2023, 03:05 PM
                                  • jorpec
                                    Changing the scale of an analog meter
                                    by jorpec
                                    Hi
                                    I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                    I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                    Thnaks
                                    01-23-2023, 10:37 AM
                                    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                    by sam_sam_sam
                                    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                    12-14-2023, 07:45 PM
