Würth Elektronik Electrolytic Capacitors Official Thread
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: Würth Elektronik Electrolytic Capacitors Official Thread
    Originally posted by mockingbird
    When you say relabeled, do you mean fake or subcontracted?
    Because this was purchased straight from Newark. In fact, they're still selling it:
    http://www.newark.com/illinois-capac...tor/dp/69K7936
    I do not mean fake, i mean IC bought capacitors from Jamicon or Lelon and got them to put custom heatshrink on them with the IC logo and marking on it. (Not saying they did but they could have)
    I'm not a expert, I'm just doing my best.
      master hoarder
      • May 2008
      • 12175
      If that ever got past Japanese quality control, it would result in a harakiri at the factory.
      By the way, was that slightly bulged cap measuring okay in terms of ESR and capacitance? Also, can you actually push the vent back down or does it feel very stiff? If the latter, that's probably a sign of gas (Hydrogen) build up and the cap is likely on its way out. (Though for high voltage caps, sometimes that doesn't apply - I have one JEE 200V 1000uF cap from an ATX PSU, and despite being slightly bulged, it measures okay on ESR and capacitance. It's been that way for 5+ years now. I've re-used it for several temporary recaps now. and it hasn't been giving me problems. Of course, I wouldn't use it for anything permanent or in a spot where it is critical for safety.)
      Probably not Lelon, as they use an "X" -style vent. Jamicon... maybe, as they do sometimes have a "Y" vent.
      • RukyCon
        A Fake Rubycon
        • Jan 2017
        • 816
        I have some Lelon caps with a Y vent.
        • mockingbird
          • Dec 2008
          • 5484
          I have just ordered a tester so hopefully I can test it when it arrives, but I'm pretty sure the cap is ok. No it is pretty stiff and I can't push it back down (I just tried with a lot of force).
          I used to buy their KXM series (equivalent to UCC KZE), but ever since then I got turned off of them.
          • petehall347
            • Jan 2015
            • 4440
            Rubbish.
            Their foil is Chinese/Taiwanese (read: inferior)
            Their electrolyte is also inferior. Since when has a European company produced something on-par with a modern Japanese cap? The business model of researching electrolyte formulas to compete with Japan wouldn't make sense at this point. The cost would be enormous.
            What does make sense is that they are probably importing raw goods from China and having them assembled in Europe.
            Big deal. They should be avoided.
            that was copied off their website .
            • RukyCon
              A Fake Rubycon
              • Jan 2017
              • 816
              Würth electrolytic capacitors have the word VENT printed on them.
              Usually the cheap capacitor company's will print VENT on their capacitors to remind their customers that their capacitors will prematurely VENT.
              • Stefan Payne
                • 1267
                can you rotate the cap a couple of degree and make another picture??
                So that you can see the VENT and the other markings like Voltage and so on for example.
                • RukyCon
                  A Fake Rubycon
                  • Jan 2017
                  • 816
                  Here are two more photos of the same capacitor so you can see all of the markings.
                  • Stefan Payne
                    • 1267
                    You don't have a similar CapXon cap, do yo??
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      I have a Capxon capacitor of the same physical size and looking at them side by side the the Würth capacitor looks almost identical to the Capxon capacitor.
                      Some photos so you can see for yourself....
                      What do you think? Do you think they could be Capxon's with the Würth name on them?
                      • Stefan Payne
                        • 1267
                        That was the first thing I thought when I saw the VENT on the cap. Also the cross seal.
                        And it should be a somewhat decent manufacturer that writes that on their caps. And the first thing is CapXon I thought of....
                        But that doesn't mean the cap is bad, without knowing the quality grade Würth wanted. CapXon has some (more) decent series like FH...
                        Also their GL series seems to be somewhat OKish - not great but certainly better than KF...
                        • Stefan Payne
                          • 1267
                          Although, after another look at the pictures there are some differences.
                          The groove on the crossection of the CapXon cap is a bit bigger.
                          And the printing looks kinda different...
                            • 31218
                            the wurth looks like it has a deeper bung-crimp
                            really though, you need to compare something bigger like 8mm or 10mm and compare the bungs.
                            • RukyCon
                              A Fake Rubycon
                              • Jan 2017
                              • 816
                              I'm going to get more Würth capacitors at some point for some minor repairs and projects.
                              I was also thinking about getting some of their low impedance or low ESR capacitors for testing in some small power supply's.
                              • Behemot
                                • 4845
                                • CZ
                                #35
                                What's the point?
                                  • 31218
                                  what Behemot said,
                                  they will work, fukyou's will work, capxon's will work,
                                  the only difference between shit and say pana or rubycon is how long they stay working!!
                                  do you have a couple of years for your test?
                                  • RukyCon
                                    A Fake Rubycon
                                    • Jan 2017
                                    • 816
                                    Well i guess i will go back to my original plan of using a mix of Rubycon and Panasonic capacitors for the power supply's with the Würth capacitors being used in low stress applications. (If they can even be used for that)
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      #38
                                      Actually, it's not a problem of how many years they will work but *which* of the capacitors you got will last that many years. In other words, crap capacitors tend to have more unpredictable and inconsistent failure rate. You can have two CapXons next to each other, and one last 10+ years and the other go bad after 1 year of use. I've actually seen that happen quite often with crap brands.
                                      The only way to see if these Wurth capacitors are any good is to buy at least 20 of each kind you plan to use, then put them in the same equipment - say, 20 identical power supplies. Then run each of these power supplies 24/7 for several years or more to see how the caps fare. But the truth is, hardly anyone will have time or motivation for an experiment like that. So in the end, it just may not be Wurth it... lol
                                      On the other hand, it makes me feel kind of sad, because if a new electrolytic capacitor company started making decent caps, they would probably go unnoticed, as there is no incentive to move away from the offering of the good Japanese companies. But I suppose that's the way things are. After all, Rubycon, Panasonic, Nichicon, and Chemicon have invested a lot of money into research into making electro caps, so it's undoubted they have advantage over anyone else, both in terms of quality and price (or at least price/performance).
                                      A lot of cheap caps have the word VENT printed on them, and also quite a few have "X" -shaped vents (in fact, I think that is probably one of the most commonly used vent). So I don't think that alone can conclude that Wurth (or any other capacitor for that matter) is related to CapXon.
                                      If anything, the bung, vent stamp, and leads may be a more accurate indicator. But it's still possible that many cheap cap companies could be getting their leads and cans from a larger manufacturer and then putting their own foil and electrolyte in the cap. So you never know who makes what with cheap brands.
                                      • Electone
                                        • Mar 2016
                                        • 19
                                        I would hope that a company with the reputation of Wurth would have invested time and effort to make sure that the product they're stamping their name on will not sully their reputation. I cannot see them rebranding low quality products. It would be like BMW rebranding Geely Motors cars as their own.
                                          • 31218
                                          that's a poor example, /bmW has a lot of problems with newer cars - so do mercedes.
                                          • CapLeaker
                                            AcuRite 5 in 1 temperature sensor replacement repair
                                            by CapLeaker
                                            Got a new victim:
                                            AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                            A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                            B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                            Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                            04-15-2025, 01:32 PM
                                          • asdas09
                                            Temperature to remove chips from motherboard
                                            by asdas09
                                            What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                                            I have device Sugon 202. I'm used also normal flux and rosin flux.
                                            09-12-2023, 12:44 AM
                                          • Dreigas
                                            ISL95880HRTZ desoldering temperature
                                            by Dreigas
                                            I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                                            Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                                            09-13-2024, 10:59 PM
                                          • ADV
                                            Acer Ferrari F-20" monitor display interference and replacement capacitor selection
                                            by ADV
                                            Good day everybody
                                            I hope I'm posting in the right section - I am new to this awesome forum.
                                            I have received an ACER Ferrari F-20" LCD Monitor to repair.
                                            It produces interference lines on the image displayed and slowly rotates across the whole screen, with respect to the center of the screen. One rotation takes about 4 minutes and the cycle repeats over and over.
                                            For some reason the On Screen Display Menu is not affected when switched on with the Menu button.
                                            I opened the external 18V power supply and see no bulged capacitors...
                                            11-02-2021, 09:32 AM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
