Würth Elektronik Electrolytic Capacitors Official Thread
  • Electone
    • Mar 2016
    • 19
    Not a lot of information out there on this German company's electrolytics. They have a family of seven different types:
    WCAP-ATG8: General Purpose, standard temperature
    WCAP-ATG5: General Purpose, wide temperature
    WCAP-AT1H: Long Life, wide temperature
    WCAP-ATET: Long Life, very wide temperature
    WCAP-ATLI: Low Impedance, wide temperature
    WCAP-ATUL: Low ESR, Long Life, wide temperature
    WCAP-ATLL: Low Impedance, Long Life, wide temperature
    They generally sell at lower prices than their Japanese competitors. This would be a good place to discuss personal experience with the product. I have an upcoming recap job on a Yamaha cassette deck and I have ordered Wurth caps for the job. I will follow up when complete.
  • Electone
    • Mar 2016
    • 19
    Re: Würth Elektronik Electrolytic Capacitors Official Thread
    Just as a comparison, I have put together a Wurth to Nichicon cross reference:
    ATG8 --> VR
    ATG5 --> VZ
    AT1H --> PV
    ATET --> BT
    ATLI --> PJ
    ATUL --> ?
    ATLL --> PW
      • 31122
      the poly's are cheap too.
        master hoarder
        • May 2008
        • 12175
        I've always wondered about Wurth caps myself. I've been seeing them get advertised a lot on Digikey lately, along with other non-cap products they make.
        That said, I still trust the old Japanese brands more than anything else. Though recently I noticed that many of them have moved production to China. For example, I just got some Nichicon HE not too long ago all of which had a COO (Country Of Origin) as China. Let's hope the Japanese are keeping a close look on those Chinese factories.
        • Electone
          • Mar 2016
          • 19
          Well, I completed my re-cap job with the Wurths. Everything went fine and unit is working great. We'll see how things go from here, but I've used a lot of Wurth products in the past from automotive to electrical and have never had any issues. What I do know is that the job cost 1/3 less than going with similar Nichicon caps.
            master hoarder
            • May 2008
            • 12175
            Good!
            Keep us posted (if possible) if anything happens with them. It's always good to have a bigger list of known good caps to work with.
            • Capt. Cap
              • Oct 2017
              • 40
              • US of A
              Did you use the WCAP-ATUL series?
              I was looking at using some Wurths in a power supply recap...
              Do you think the WCAP-ATLL or ATLI series would be good enough where the ATUL is not available?
              • mockingbird
                • Dec 2008
                • 5484
                Wurth are re-branded Taiwanese caps. Probably either Lelon or Teapo.
                Their polymers are also probably re-branded Taiwanese. Taiwanese polymers are of adequate quality compared to Chinese polymers, which should usually be avoided.
                I hope to address that in a seperate thread in the future. Lelon makes pretty good polymers, but their electrolytics should be avoided. I would also avoid Wurth electrolytics.
                • Electone
                  • Mar 2016
                  • 19
                  I used the ATLL series which is, I believe, comparable to Nichicon PW.
                  • Behemot
                    • 4845
                    • CZ
                    That's because of chinese manufacturing policy. Basically importing anything to that country makes it very uncompetitive which is a problem if you are electronic component manufacturer and maybe some 70 % of the world production is in China On the other hand building a fab and manufacturing there (what's exactly the goal of da government) has so many advantages.
                    But that does not mean the japanese fabs do not run, even though most Chemi-Cons I source come from China and Indonesia, I still get some from Japan directly. Usually the newest high-voltage series or some special ones (like the D10x40 KZNs).
                    • mockingbird
                      • Dec 2008
                      • 5484
                      Have you seen Kemet electrolytics for sale recently? Or Vishay for that matter?
                      We need to start testing these two companies by using them in repairs... We know nothing about their quality.
                      ...or we'll end up with something like Epcos -- a trash brand everyone believes is on par with Japanese caps.
                      • petehall347
                        • Jan 2015
                        • 4429
                        vishay is Philips ..or is it other way round ?
                        • mockingbird
                          • Dec 2008
                          • 5484
                          Who knows.
                          We need to find out more about Illinois, CDE, Vishay, Kemet, Tecate, etc...
                          Vishay could be manufacturing one thing in-house but then sub-contracting electrolytics to someone else.
                          Kemet caps were really well-priced at one point... But without any info, they should probably be avoided. And their cap datasheets need tables. Heck, if the Chinese can do it, then so can they.
                          • Behemot
                            • 4845
                            • CZ
                            I find lot of bad IC in old UPS where others (Panasonic, Chemi-Cons etc.) are usually still good, that makes it untrustworthy enough for me. Plus their insane MOQ as you know, they can stick that to their hole.
                            I do not trust Vishay too, they bought everything from old trusty brands to some crap fabs and who knows what the quality standard is. Plus the blowing rectifiers in the HP displays (was it 3065 or something like that?). Vishay is only last resort for me when I am shopping for something special, when nothing else is available.
                            Kemet should have good film and ceramic caps. But after all, I have good enough lytics from japanese companies, why should I look elsewhere? ALL these mentioned brands are always second or third when it comes to new series with better volume capacity. So they offer nothing I would need.
                            • petehall347
                              • Jan 2015
                              • 4429
                              Würth Elektronik operates production plants in Europe, America and Asia. More than you expect!
                              • mockingbird
                                • Dec 2008
                                • 5484
                                Rubbish.
                                Their foil is Chinese/Taiwanese (read: inferior)
                                Their electrolyte is also inferior. Since when has a European company produced something on-par with a modern Japanese cap? The business model of researching electrolyte formulas to compete with Japan wouldn't make sense at this point. The cost would be enormous.
                                What does make sense is that they are probably importing raw goods from China and having them assembled in Europe.
                                Big deal. They should be avoided.
                                • RukyCon
                                  A Fake Rubycon
                                  • Jan 2017
                                  • 816
                                  I believe IC buys capacitors from a 3rd party factory and puts their name on them.
                                  The reason i believe that is because i have some newer IC brand capacitors and they look a lot like Samxon capacitors, i also have some older IC brand capacitors and they look a lot like Jamicon capacitors.
                                  Würth electrolytic capacitors, i will only use them in low-stress applications until they can gain my trust. (Note i will only use them in my own electronics)
                                  I'm not a expert, I'm just doing my best.
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    I bought a primary IC cap a few years ago and it arrived slightly bloated and the sleeve was poorly shrunken on (sorry about the poor picture quality):
                                    If that ever got past Japanese quality control, it would result in a harakiri at the factory.
                                    • RukyCon
                                      A Fake Rubycon
                                      • Jan 2017
                                      • 816
                                      Photos of crappy IC cap.
                                      IC seems to be a mixed bag when it come to quality control.
                                      Also your capacitor looks like it could be a relabeled Jamicon or Lelon which would not be a surprise as both Jamicon and Lelon are not very good at making good electrolytic capacitors.
                                      • mockingbird
                                        • Dec 2008
                                        • 5484
                                        When you say relabeled, do you mean fake or subcontracted?
                                        Because this was purchased straight from Newark. In fact, they're still selling it:
                                        http://www.newark.com/illinois-capac...tor/dp/69K7936
                                        • CapLeaker
                                          AcuRite 5 in 1 temperature sensor replacement repair
                                          by CapLeaker
                                          Got a new victim:
                                          AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                          A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                          B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                          Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                          04-15-2025, 01:32 PM
                                        • asdas09
                                          Temperature to remove chips from motherboard
                                          by asdas09
                                          What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                                          I have device Sugon 202. I'm used also normal flux and rosin flux.
                                          09-12-2023, 12:44 AM
                                        • Dreigas
                                          ISL95880HRTZ desoldering temperature
                                          by Dreigas
                                          I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                                          Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                                          09-13-2024, 10:59 PM
                                        • ADV
                                          Acer Ferrari F-20" monitor display interference and replacement capacitor selection
                                          by ADV
                                          Good day everybody
                                          I hope I'm posting in the right section - I am new to this awesome forum.
                                          I have received an ACER Ferrari F-20" LCD Monitor to repair.
                                          It produces interference lines on the image displayed and slowly rotates across the whole screen, with respect to the center of the screen. One rotation takes about 4 minutes and the cycle repeats over and over.
                                          For some reason the On Screen Display Menu is not affected when switched on with the Menu button.
                                          I opened the external 18V power supply and see no bulged capacitors...
                                          11-02-2021, 09:32 AM
                                        • jm1234
                                          9V relay temperature 40C
                                          by jm1234
                                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                          05-09-2024, 03:03 AM
