A question about false continuity.
  • BangBusDriver
    Maker and Fixer
    • Mar 2017
    • 10
    • US
    Here I post a question to which Google has failed me utterly.
    I am currently troubleshooting a motherboard and in the CPU vcore area, ALL of the caps seem to have continuity. And a few others on a certain power rail.
    They all have about 8ohms resistance. Is this a problem or normal?
    My hypothesis is that the caps may be charged on both sides or otherwise meant to pass high mhz ac current from the CPU?
    Please, any help is appreciated. I'm a relative beginner at electronics.
    "The whole problem with the world is that fools and fanatics are always so certain of themselves and wiser people are so full of doubts." -Bertand Russell
  • retiredcaps
    • Apr 2010
    • 9271
    Re: A question about false continuity.
    I don't know if 8 ohms is normal or not, but when you measure components in circuit, without desoldering them, you may get false readings if the components are in parallel with other components.
    To get an accurate reading, measure them out of circuit.
    --- begin sig file ---
    --- end sig file ---
    • petehall347
      • Jan 2015
      • 4435
      try measuring for longer and also swap probes .
      and also be sure the power is unplugged .
      • cpt.charlie
        • Sep 2013
        • 270
        • Spain
        It's normal to measure low values if the processor is installed (if you try to measure the VCC rail of a big chip like a processor, PCH or VGA, you will get a low reading)
        • Mint Waxed
          • Aug 2016
          • 35
          To avoid false readings, capacitors are normally removed from the circuit. The best way to test is with a capacitor tester. If you don't have this item, then use an analog meter. The capacitor should slowly charge then reverse the leads and it should kick with that charge then charge in the other direction.
          • BangBusDriver
            Maker and Fixer
            • Mar 2017
            • 10
            • US
            So based on your feedback, I have another question. The caps that can be found on the underside of a processor socket... are those all connected to the processors 1.5-1.8 volt rail, typically? I thought perhaps some of them were used to pass signal voltage and block power, maybe?
            Also to clear things up, when measuring for continuity ACROSS the caps from the positive side to the negative side (which I assume should just be ground if they are used to keep the power rails steady at load), and getting continuity, as if they were shorted. Than I measured their resistance, and it was 8 ohms, across the cap? This is because of measuring in the circuit? Perhaps because I was feeding the other caps(in parallel, or other loads) with the current form positive multimeter lead and the negative was measuring a lower voltage than it should have thus producing a lower resistance reading?
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              Like many members said , it's better to test capacitors outside the board . Notice that capacitors work like temporary batteries ; When you test them for continuity , it means they are charged and saturated , with no chance of discharging , giving you different measures , erroneous ones in fact , the next time you test them .
              • cpt.charlie
                • Sep 2013
                • 270
                • Spain
                Those caps are connected to the VRM line (0.8-1.3V) 1.5-1.8V rail is for DDR3/2 and you might have a low reading if the processor is in the socket or while the caps in parallel are charging up.
                • barrybahr
                  Magnavox 32MD350B/F7 getting a false on/off control voltage
                  by barrybahr
                  The unit is stuck in an intermittent on/off cycle. When I plug in the power cord, the green "On" light activates without any command, flashes for a few seconds, then turns off. The red standby light comes on for a few seconds before the cycle repeats. During this time, I cannot turn off the unit manually; it will shut off automatically after about five minutes, and there is no picture. Occasionally, with repeated attempts to power it on, I eventually get a picture and sound, which function properly. When it does work, I measure several voltages, and they appear to be normal....
                  04-20-2025, 10:30 PM
                • roxboy1984
                  Please Help , Asus Zenbook Motherboard repair
                  by roxboy1984
                  Please could someone help or advise me. I have an Asus Zenbook UX305UA that I am trying to repair. I'm still a newbie but I'm learning. Under a thermal cam I noticed that the TI 1285A IC is getting very hot. I checked the resistances to ground of all the pins connected to this chip, and found that pin 3 has a very low resistance of 1.8Ohms so I checked the Ceramic cap which is next in line, on continuity mode and the cap appears to be shorted. This is a 4.7uF 6.3V capacitor. My question is, do I need this cap? can I jump it? I have some donor boards laying around. What Cap would be an ok replacement...
                  04-08-2025, 07:48 AM
                • Tarot Superstars
                  trying to fix a 6V 0.5A T1 (Transformer) AD050120T2 power supply
                  by Tarot Superstars
                  Hi. I am trying to fix a 6V 5A power supply that would was used a lot.
                  I want to fix it partly for learning, and part because I don't want to buy a new one.
                  It has distinctive smell of burning but not seen obvious burned components yet. I'm not sure where the fuse is.
                  I tested the only slightly bulged capactitor (out of circuit) and it measured normal capacitance and ESR.
                  Everything else was tested in circuit with a multimeter.
                  In circuit tests
                  I tested the large diodes underside and they seem fine.
                  I tested...
                  08-14-2023, 12:45 PM
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
                • gutkin
                  HP 250 G8 Compal FPW50 LA-H325P
                  by gutkin
                  Hi colleagues.
                  Here I am asking for help.
                  I've entered this HP and it won't turn on. I can't find a schematic or boardview.
                  The first fault I found was a JW5069a IC (compatible with JW5068a). It had an internal fault, which was replaced, and now I have a stable 19V. When I press the power button, the LED appears, but it still consumes 500mAH.
                  I continued taking measurements and found that the PUG8 IC is not receiving an EN on pin 2.
                  PUG8:
                  Pin 1 5V
                  Pin 2 0V
                  Pin 3 1.8V
                  Pin 8 5V
                  Pin 12 5V
                  Pin 13 19V
                  Pin 2 of...
                  07-29-2025, 03:27 PM
