Samyoung LXZ, KME & KMF datasheets
  • markcoenen
    • Dec 2016
    • 28
    Does any know of a source for SamYoung datasheets for series KMF, KME & LXZ?
    I've looked in the databases I found in forum posts and google searches.
    I have these datasheets NXP(LXZ), NHA(KME) & NZE(KMF), are they ok to use?
    thanks
  • mockingbird
    • Dec 2008
    • 5484
    Re: Samyoung LXZ, KME & KMF datasheets
    Just use their direct analogues which should be UCC KME, KMF and LXZ.
    KME is general purpose 105C, KMF is general purpose 105C but with a 5000 hour endurance rating, and LXZ is non-aqueous low ESR starting at 2000 hour endurance.
    • markcoenen
      • Dec 2016
      • 28
      OK, thanks
      I still have 2 problem caps.
      A Samyoung LXZ cap 25v 820uF size=10x20
      In NCC's LXZ datasheet there isn't a 10x20 size
      the closeist is 25v 820uF size=10x25 imp=0.045@20c & 0.090@-10c ripple=1,440
      The Samyoung NXP(LAZ) datasheet
      Has 25v 820uF size=10x20 imp=0.052@20c & 0.10@-10c ripple=1320
      What ripple current should I use?
      for a Samyoung cap 450v 150uF size=10x45 w/ case markings 0546 (M)105c
      the NCC KMF series datasheet does not have an entry for 450v 150uF cap at any case size, only goes to 450v 47uF
      The Samyoung series NFD(KMF) datasheet last 450v entry is 120uF size=18x40 ripple=740 (mArms/105c, 120Hz)
      Any suggestions on ripple current for this cap?
      I am a novice and this is the first time I am trying to select caps.
      thanks for your help.
      • mockingbird
        • Dec 2008
        • 5484
        For the 10x20 LXZ, use UCC 16v 1000uF 10x20. The reason you can go down from 25V to 16V here is because 25V is never needed on secondary 12v rail supplies where the voltage will not exceed 12V. One of the only times you would actually only really need to pay attention to voltage is for the output of an unregulated DC voltage. An example of this would be the output cap after the bridge rectifier on a wall wart, where the voltage will fluctuate based on load, and a 12V adapter will exceed 16V when not loaded.
        As for the lower ripple rating (1220 vs 1320), don't worry about that. These two series are direct analogues, so it's more than likely that Samyoung was just uprating the ripple value here a bit.
        The KMF does not seem to be an analogue of UCC KMF as we originally thought, because in your case, it's a large cap which tend to have completely different series designations. And inndeed, Samyoung specifies NZE as a replacement series for their now deprecated KMF series.
        10x45 is impossible for that value, as the NZE datasheet specifies 18x45, and the KMF datasheet already specified 18x40 for a lesser capacitance. So most likely you meant 18x45 and not 10x45 (10x45 would be a very thin, long cap. Doubt something in that dimension is even produced for the masses nowaday with those measurements).
        For a direct replacement, go for UCC KXG. The exact part number is EKXG451ELL151MM45S.
        Good luck and please let us know how things go.
        • markcoenen
          • Dec 2016
          • 28
          Thank you. The explanations are most useful. Knowing the “why” of it helps a lot.
          This has been quite an arduous adventure. I’m into my 5 week of trying to order these caps. There is a lot more to replacement cap selection then I imagined, a LOT more. I am overwhelmed with information.
          You are right the 450v 150uF cap is 20x45 I read my scale wrong. The part you recommended EKXG451ELL151MM45S is sold in quantities of 250 only. I found a Rubycon 1189-3226-ND on digikey that physically fits.
          As for the Samyoung LXZ cap 25v 820uF size=10x20, after reading your comments I searched for a new cap using the lower ripple and found Digikey part P14423-ND.
          Does that look good?
          • mockingbird
            • Dec 2008
            • 5484
            This has been quite an arduous adventure. I'm into my 5 week of trying to order these caps. There is a lot more to replacement cap selection then I imagined, a LOT more. I am overwhelmed with information.
            P14423-ND is certainly an adequate replacement. It's not a lower ripple part, but a much higher rated part at 2180. Just keep in mind that the ESR is much lower, at about 1/5 the original.
            Yes, the Rubycon looks perfect too.
            Good luck.
            • Drack
              Yup it's me
              • Nov 2016
              • 297
              • Venezuela
              If it's an smps it could be a problem using a too low ESR cap, especially if it's old, the ripple can go really high because they are not designed for working with such a nice part (low ESR) weird huh?
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                is this a pc psu?
                if so mockingbird is correct.
                you did not state what you are working on.
                often a higher voltage/larger can part is used to get the esr needed in a cheap part.
                • markcoenen
                  • Dec 2016
                  • 28
                  Thanks for your help.
                  It's a Samsung p2350 23" Monitor
                  I'm currently working on the Power Supply
                  It has these markings and labels
                  Printed
                  ITE Power Supply
                  LEVEL 3
                  LR76377
                  White paper label
                  MD54PWI2304SL (a)03393
                  Printed [this is the model # i used to find it on line with pix]
                  model PWI2304SL (c) rev 1.0
                  I found these 2 links with pictures
                  https://www.aliexpress.com/item/Free...060_10061_1006
                  and here
                  http://www.ebay.com/itm/Samsung-2494...IAAOSwd0BV193O
                  • markcoenen
                    • Dec 2016
                    • 28
                    I'm also having problems finding a replacement for a
                    (JH) [Jianghai] cap BK series
                    100uF 450v 18x36
                    the datasheet says ripple 650 & ESR of 3.
                    The only one I've found is a UCC from Digikey where I would have to buy 200 of them. Digikey part # ESMH451VNN101MP35T-ND
                    Is this an unusual cap or something?
                    Could be replaced with something with different specs?
                    I think there is room for a 25x48.
                    http://www.digikey.com/product-detai...35T-ND/4002784
                    thanks again.
                    • mockingbird
                      • Dec 2008
                      • 5484
                      100uF 450v 18x36
                      thanks again.
                      Here you go:
                      http://www.digikey.com/product-detai...386-ND/3134342
                      • markcoenen
                        • Dec 2016
                        • 28
                        Thank You mockingbird.
                        I'm guessing that this is one of the times you can use impedance and ESR interchangeably.
                        But how did you know where to look? Is this something you get to know over time or did I miss something in how I'm searching for replacements?
                        thanks again
                        • markcoenen
                          • Dec 2016
                          • 28
                          I just realized the JH cap is ripple=650 and ESR=3. I assume that is 3 ohms.
                          The datasheet for the Rubycon 1189-1386-ND does not list ESR but has a "Low Temperature Stability Impedance Ratio(MAX)" of 6.
                          Is that 6 ohms?
                          I'm not finding a definition to "Low Temperature Stability Impedance Ratio(MAX)".
                          Is that the same as impedance? Or, does the "Ratio(Max)" imply a formula?
                          If it is 6 ohms of impedance and we use that for ESR, is this still an appropriate cap? If so, why?
                          I find that there are 2 levels of understanding; understanding what someone is explaining to you and understanding something enough to explain it to someone else. It seems I'm not at the first yet. I'll get there, till then thanks guys.
                            Monitor power supply: just use PANASONIC FM/FR series for the small cap.
                            The main filter cap (100uf 450V) if it is bad then just get one with the highest ripple current rating you can get, it is is exposed to 120HZ so ESR does not really matter much for that cap and its application.
                            That Rubycon TXW should be fine.
                              Want to learn about the spec of the cap?
                              https://cdn.badcaps-static.com/pdfs/...64fb172f94.pdf
                              • ajdrenter
                                Picking caps for Antec SU-380
                                by ajdrenter
                                In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                https://www.badcaps.net/forum/showthread.php?t=14159
                                It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                05-13-2023, 10:40 AM
                              • Ady2017
                                Are there any datasheets available for Elna RJG capacitors?
                                by Ady2017
                                I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                05-25-2025, 02:19 PM
                              • slybunda
                                Elite Capacitors? (450v 47uf power board Toshiba Vestel TV)
                                by slybunda
                                anyone heard of these caps before? at first glance i mistook them to be Elna caps but closer look and it was elite. not sure if they are known failure prone brand.
                                also they are 47uf and 450v. why are they so large in height? i can get replacement 450v 47uf caps that are a quarter the height. what am i missing here?
                                if i were to replace them what should i be looking for?
                                they are on the power board of a toshiba (vestel) tv power board.
                                pic attached...
                                11-13-2023, 06:33 AM
                              • P4C800
                                ASUS P5A and P2B-S recapping. Searching old datasheets.
                                by P4C800
                                I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
                                There are three mainboards:
                                - ASUS P5A rev 1.04
                                - ASUS P2B-S rev 1.03 "Rubycon"
                                - ASUS P2B-S rev 1.03 "Chemi-Con"
                                If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
                                They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
                                P5A
                                10-09-2023, 05:55 AM
                              • CdDvdFlash
                                Please teach me how to find datasheets to obsolete caps
                                by CdDvdFlash
                                I've got a Toei arcade CRT chassis and printed on the PCB is CM-R14 but it might be a CM-R20 and so far needs two caps replaced, I've looked on the Nippon Chemi-Con site and got their 2020 catalogue I cant find any info about the first cap in the catalogue or on their obsolete catalogue, on the cap is:
                                (Radial electrolytic cap) Nippon Chemi-Con 1uF 160v 85c 8mm diameter, roughly 15mm long (cap is bulging at the legs) with 6mm PCB hole spacing, the chassis service manual says this cap C58 is a CE04W with "04" in a smaller font than the capital "CEW" so it must be...
                                08-12-2023, 12:29 PM
