Please teach me how to find datasheets to obsolete caps
  • CdDvdFlash
    • Jan 2020
    • 35
    I've got a Toei arcade CRT chassis and printed on the PCB is CM-R14 but it might be a CM-R20 and so far needs two caps replaced, I've looked on the Nippon Chemi-Con site and got their 2020 catalogue I cant find any info about the first cap in the catalogue or on their obsolete catalogue, on the cap is:
    (Radial electrolytic cap) Nippon Chemi-Con 1uF 160v 85c 8mm diameter, roughly 15mm long (cap is bulging at the legs) with 6mm PCB hole spacing, the chassis service manual says this cap C58 is a CE04W with "04" in a smaller font than the capital "CEW" so it must be a zero not the letter O, can someone please teach me how to find the datasheets for old capacitors as I have only found two bad caps but I am going to remove and test all of them with an ESR meter and multimeter, normally I type the brand and value and any other series letters/numbers into google with "datasheet" and sometimes I'm lucky but that's all I know, I need to know how to do a better search or which sites to go to suited for cap finding instead of asking about caps with a mile long list. I need the datasheets so I can match the ESR and or ripple current etc and I know I can use a slightly bigger or smaller cap can if good quality and the same for a larger voltage/temperature is ok but not lower voltage/temperature. I would be grateful for this so that I've learnt how and I would be saving peoples cap searching time unless I find a real difficult cap I would return here. Thank you all.
  • CdDvdFlash
    • Jan 2020
    • 35
    Re: Please teach me how to find datasheets to obsolete caps
    I would still like to know the info from my first post and I was searching for cap repair kits and found only one so far for a complete cap replacement, has anyone bought from this site before and would they be really old caps with a bad shelf life or does the guys there sell good caps they say the caps are all 100% Nichicon
    https://www.arcadepartsandrepair.com...105c-nichicon/
      • 31264
      i have repaired those,
      just look at caps from rubycon and panasonic for high voltage caps
      • CdDvdFlash
        • Jan 2020
        • 35
        Should they be low ESR and if so how low is low I don't have a lot of experience in this, if for example there is a 160v cap would 200v be good or go even higher
          • 31264
          they dont really need to be low esr for a monitor, the highest frequency in them is 15KHz
          105' temp rating is good though.
          for 160v caps, if you can fit 200 or 250v it will be better.
          the hardest part with old monitors is if you find a bipolar cap in it (BP)
          those are hard to get now - ideally you replace it with a film cap but those are bigger
            master hoarder
            • May 2008
            • 12175
            General rule of thumb: if it's an 85C-rated cap, it's "general purpose" type... meaning NOT low ESR / low impedance... so you can safely replace it with about any 85C-rated or 105C-rated moderns caps. Just stick to the known good Japanese manufacturers to get a good service life out of the device (i.e. Rubycon, Nichicon, Panasonic, and United Chemicon.)
            In most cases, you can even use "entry-level" low ESR / low impedance caps to replace such old 85C-rated GP caps and it won't be an issue.
            stj is right about bipolar (BP) caps - those can be hard to find now, especially with a larger voltage and capacitance rating. Old CRT boards almost always had one or two in them. Just pay attention if it's a large cap (i.e. rated over 10 uF and over 100V.) Sometimes, those are rated to take really high ripple current. Replacing it with a polypropylene (PP) film cap of the same voltage rating might be a "NO GO" situation, as the PP cap might be rated for substantially lower ripple current. So for these large BP electrolytic caps, up the voltage rating to 2x if using PP film caps... and yes, the PP caps could end up being huge in comparison.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              If you ever need a BP and can't find one, you can make your own in a crude way.
              Say you need 220uF BP / NP. Take 2x 470uF polar, tie the two negative leads together and then use the positive leads of each cap in the circuit. Capacitance is reduced by half the cap rating in this config (2x 470uF / 2 = 230uF; within the tolerance of 220uF), voltage rating remains the same, so select the voltage according to what you need. It also no longer cares about polarity. I've used this a time or two back in the old world TV repair days.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
                • 31264
                for people that dont know,
                that TOEI chassis is probably running since 1979!!!
                the old caps did well.
                that said - i recomend replacing the chip socket for the deflection i.c. with a turned-pin/machined-pin type instead of the old bakelite crap
                  master hoarder
                  • May 2008
                  • 12175
                  Yup, that should work too. I've seen this done in some subwoofer amp boards too. So even manufacturers do it.
                  I've also seen the same method used with two additional diodes - one across each cap, with cathode tied to (+) and anode tied to (-) of each cap. I presume this is to limit the reverse voltage to no more than 0.7V on each cap and thus allow for higher RC through this "bipolar" configuration.
                  +1
                  Machined sockets are a lot more pricey, but well worth the money. I've seen many failed devices due to failed sockets, especially if the device was in a harsh weather environment. The contacts of regular IC sockets oxidize / tarnish quite quickly with air moisture and cause problems. Machined sockets are more durable and provide a better electrical connection.
                  • Ady2017
                    Are there any datasheets available for Elna RJG capacitors?
                    by Ady2017
                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                    05-25-2025, 02:19 PM
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • danielgerman681
                    ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                    by danielgerman681
                    Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                    08-27-2025, 01:17 PM
                  • corrize
                    Where to find a very small fpc connector 0.3mm between 2 pins ?
                    by corrize
                    Hello, I search this connector (oxydated).
                    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                    Do you know how to find this connector please ? What is the exact name for find it ?
                    08-06-2024, 05:25 PM
                    Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                    This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                    Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                    07-07-2024, 02:34 PM
