Identify Fusible Resistor
  • Neverest
    • Jan 2017
    • 4
    • Norway
    Hello all!
    I need help with identifying the fuse in the picture below. Its placed in a 12v, 1.8A 22W TV. The color coding is green, black and red. Any suggestions to where I can get one or an alterative to replace it with?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4954
    • New Zealand
    Re: Identify Fusible Resistor
    Obviously, that colour code doesn't match any sensible resistor code (for a 3-band and hence 20% resistor, it would be at best 51k, which makes no sense)
    It doesn't match fuse codes here: http://www.slimlab.net/mirror/fuseco...usecolours.htm either.
    Maybe just replace it with a 2 - 2.5A fuse, if the normal operation current is 1.8A.
    Do you have a model number? Schematic?
    -David VanHorn
    • redwire
      • 3910
      red black green = 215 maybe 2.15A? The colour code website is for AGC glass fuses so might not match this part. It's a strange part but the PCB looks Asian.
      Just look for a through-hole fuse like Belfuse RST, Littelfuse 392, Schurter FST etc. and bend the leads to fit. Picofuses are expensive.
      I'm not sure what manufacturer is popular in Norway.
      Or take an ordinary fuse and solder on pigtail leads, and put that in a piece of heatshrink tubing or PVC tubing.
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        It's not critical to put any fuses higher than 2A , but fusible resistors differ of ordinary fuses that they are fast responding to surge powers or lightening , so if this device isn't exposed to such risks , in a safe environment , then it's okay . If not , then better acquire the original one .
        • Neverest
          • Jan 2017
          • 4
          • Norway
          I'll try this then, if you think its an ok replacement.
          Fuse 2 A super fast-blow 251 / Pico® II, 0251002.MAT1L, Littelfuse:
          Rated current 2 A A
          Breaking capacity 50 A@ 125 VAC, 300 A @ 125 VDC A
          Rated voltage 125 VAC/DC
          Characteristic (time/current) super fast-blow
          Construction form Ceramic tube, leaded
          Series 251 Pico® II
          I was the one responsible for the surge, by accidentaly reversing poles on the 12v solar system during some error testing... I guess you can call that a hazardous environment!
          The PCB is called CV209LT_A1 and the Internet isn't exactly flooding with info about it. I get two results on Google, where this is one of them, with some pictures: http://www.teleservice-depannage.com...-HTL2435HD.htm
          • Agent24
            I see dead caps
            • Oct 2007
            • 4954
            • New Zealand
            If you reversed the power connector, there may be more blown than the fuse.
            I don't know if the fuse is suitable, I would have thought a fusable resistor would act like a slow-blow fuse but I'm not certain, now that I have to think about it.
            -David VanHorn
              • 31026
              it would be nice if i could see the alleged picture.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4954
                • New Zealand
                Here it is
                -David VanHorn
                  Fusible resistor info.
                  • Neverest
                    • Jan 2017
                    • 4
                    • Norway
                    Since I had measured that the fuse was shorted, I tested with a copper wire, just to see if it was life (It was dead, so I figured I had nothing to loose). It seemed to turn on and light up the panels, but I turned it of again as fast as I saw light, because I was unsure of its function other than fusing. So if the TV would operate normaly with a new fuse, I am unsure.
                    When it happened, there was no sound and no smoke from the TV, unlike the brand new dab-radio that made nasty noice and produced an atomic mushroom cloud... So I figure the fuse blew pretty instant.
                    Could there be any negative effects of using the picofuse, other than the TV breaking again? Like fire hazard because of different function?
                    I am able to use a soldering iron and replace identified parts with correct replacement parts, but when I am unable to figure out the correct part and its function, I am at loss...
                    • redwire
                      • 3910
                      The fuse protects the parts, PCB traces, DC jack etc. from burning up if there is a short circuit somewhere.
                      I do not see any danger with the fuse you have put in. If anything it would blow fast before smoke gets out
                      I would see if the TV runs.
                      UL/CSA/IEC and electrical codes I find fuses are rated 167% of the usual current, so a 3A fuse for the 1.8A TV as a rough guide.
                      Picofuse 251 is a very fast fuse, at 3A it blows in 0.5 second. The Picofuse 47x series is slow-blo and (2A) one at 3A blows in 1 minute.
                      budm maybe thinks it is a fusible resistor?
                      Maybe... a way to see what the part is, is to break it in half and see if the fine wire inside is soft and hollow tube like a fuse, or harder like nichrome wire in a fusible resistor with wrapped cylinder body. Or scrape off the paint.
                      • gica69
                        Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                        by gica69
                        I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                        Resistor shows orange range silver gold and green lines.
                        Thanks in adv...
                        07-21-2025, 09:49 PM
                      • magneh
                        Is this some kind of fuse resistor ?
                        by magneh
                        Hello guys
                        Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                        Seem to me like some kind of fuse resistor?
                        After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                        They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                        The red band is larger than the 4 others, but I dont have much experience with these components.
                        Also one of the orange...
                        02-10-2025, 07:54 AM
                      • jinu_j
                        by jinu_j
                        Hi
                        05-03-2025, 10:51 PM
                      • corrize
                        Replacing resistor fuse in Sony DV charger
                        by corrize
                        Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                        So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                        It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                        06-30-2025, 06:59 PM
                      • bluto
                        Is this a fusible resistor?
                        by bluto
                        This is from the power supply of an LED shop light. The light went completely dead suddenly. I removed the SMPS board and it looked really good except for some bad solder joints. I touched all of them up but the light was still dead. I then found this open resistor that was between the neutral wire of the plug and the transformer. The color bands seem non-standard. Does it indicate 13 ohm, 30 ohm...? I am not sure. What should I replace this with?
                        07-01-2025, 01:30 PM
