Where to find Fujitsu low profile "Super ML" capacitor?
  • Kelvinman11
    • Nov 2016
    • 13
    • Malaysia
    Hi, im new here. Do you know where to get fujitsu 3v-1000uf cap?
    • 31293
    Re: Need Help identifying a capacitor...
    3v? never seen 3v before.
    seen 2.5v and 4v though.
    • Kelvinman11
      • Nov 2016
      • 13
      • Malaysia
      Asus Extreme Rampage x48 fujitsu 3v-1000uf caps
      Hi, would like to ask if anyone know the silver flat Fujitsu 3v-1000uf cap can be replace? Just bought an used board but found it the cap is damage. Any reference where can i get those if it can be replace. Thank you
      • Kelvinman11
        • Nov 2016
        • 13
        • Malaysia
        Something like this
          • 31293
          that's new - never seen a low profile cap like that before!!
          • Kelvinman11
            • Nov 2016
            • 13
            • Malaysia
            Ouch~ that's bad.. the board is dead forever
              • 31293
              what's on the other side, is it 2 wires going though or something else?
              • Kelvinman11
                • Nov 2016
                • 13
                • Malaysia
                Located exectly behind the processor pin.
                  • 31293
                  how do you know it's bad?
                  • Kelvinman11
                    • Nov 2016
                    • 13
                    • Malaysia
                    The first photo I attach the cap is puffed-up
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Re: Where to find Fujitsu low profile "Super ML" capacitor?
                      I created a new thread for you because it did not belong in the other one.
                      It's a Fujitsu Super ML capacitor.
                      • Kelvinman11
                        • Nov 2016
                        • 13
                        • Malaysia
                        Ok, thank you very much
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          They also exist with the branding "FPCAP" but that quickly gets confusing because Fujitsu also has a range of regular polymer caps named that...
                          Picture source: http://forums.vr-zone.com/hardware-d...ia-gtx680.html
                            • 31293
                            be interesting to see one lifted.
                            i wonder if they are like the "proadlizer" caps from NEC that keep failing in laptops?
                            • R_J
                              • 9624
                              I found this http://www.ebay.com/itm/FPCAP-decoup...v#ht_720wt_955
                                • 31293
                                $18.50? for a cap?? fuck......
                                • Kelvinman11
                                  • Nov 2016
                                  • 13
                                  • Malaysia
                                  Finally found what Im looking after been searching for so long. Thanks alot R_J Will post up some photo when those cap is lifted off from the board.
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    Well it's surface mount so not going to be very easy.
                                    What is the problem you are having with the board?
                                    Because what you could do is try to remove it and power it up.
                                    If it works but isn't stable you could replace that capacitor with a regular Polymer cap.
                                    Unless you intend to do some serious overclocking or such where you really push the system...
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      at $18.xx for one it would quickly have 2 820@2.5 yellow fujitsu tacked on there.and would work fine.might look tacky but its hidden in the pc anyway.
                                      i doubt theres more than 1.5v there.
                                        • 31293
                                        i was thinking 4x 330uf smd poly's recovered from a laptop or similar.
