Need Help identifying a capacitor...
  • explosive_steve
    • Nov 2010
    • 4
    I have a ASUS P5N-T Deluxe Motherboard. Recently decided to clean out the dust and noticed a capacitor missing. Its neighbour is not well either.
    Pic of missing cap with neighbour...
    Cap has the following information written on it:
    822K
    561
    6.3
    Image:
    I've spent an hour reading the internet for info but have been unable to identify exactly what this capacitor is. The only thing I am pretty sure about is that it is 6.3V.
    Can anyone tell me what farad rating it is?
    any help appreciated..
  • POM_MJ
    • Aug 2009
    • 228
    Re: Need Help identifying a capacitor...
    Fujitsu
    560uF/6.3V
    I'm not sure about their type, Solid capacitor?
    http://capacitor.web.fc2.com/solidca...r.html#fujitsu
    | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
    | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
    | 2xWD7500AYYS | 2xHD322GJ Raid0 |
    • Toasty
      • Jul 2007
      • 4171
      Fujitsu FPCAP - Functional Polymer
      Fujitsu sold to Nichicon:
      https://www.badcaps.net/forum/showthread.php?p=62943
      Use UCC PSC (8mm) or PSE (6.3mm) series:
      http://search.digikey.com/scripts/Dk...me=565-3227-ND
      http://search.digikey.com/scripts/Dk...me=565-3255-ND
      Or use Nichicon L8 (8mm) or S8 (6.3mm) series:
      http://search.digikey.com/scripts/Dk...=493-4021-1-ND
      http://search.digikey.com/scripts/Dk...=493-4043-1-ND
      8mm sizes are higher ripple (5700ma), so if they fit, make them 1st choice.
      Toast
      veritas odium parit
      • explosive_steve
        • Nov 2010
        • 4
        Thanks Guys,
        I really appreciate the quick response and detailed info.
        now to go buy some and get soldering!!
        thanks again
        steve
        • Cellkeep
          • Jul 2011
          • 1
          Thanks for the info also, I bumped one and jammed it a bit to one side while putting a CPU cooler on my mobo. hoping it wasn't borked I tweeked it back in place. Finished putting pc together only to find it would not post or show video. Really hoping this is the problem as I am on break and need to get some pc time in
          Thanks guys
          • Agent24
            I see dead caps
            • Oct 2007
            • 5095
            • New Zealand
            I wonder why the Fujitsu capacitors were falling off in the first place...
            -David VanHorn
            • yafmaverick
              • May 2013
              • 1
              • Yugoslavia
              It's the same capacitor as this one
              The only difference is text on it:
              F
              812e
              101
              16
              Help please. What is the capacity for this one, anywhere I could buy it?
              • mariushm
                • May 2011
                • 3799
                100 uF 16v
                101 = 10 x 10¹ = 100 uF
                As for where to buy it... try http://www.farnell.com/ or rs-online.com but I doubt they sell to your country.
                Otherwise... you could try eBay.
                Since it's so low capacity the capacitor was most likely for a fan or something not so important, and they probably used this Fujitsu polymer just to advertise the board as having "all solid Japanese capacitors" on the box.
                If you can't find a store to sell you one, I can mail you a 100uF 16v electrolytic capacitor, Panasonic FR quality one, you just have to paypal me 1$ for stamps and envelope and give me your address
                • Prolog
                  RTX 3080 FE Identifying capacitor
                  by Prolog
                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                  I hope these photos make it clear which component I am referring to:
                  (yes, the soldering is a bit botched from removing the blown one, I know)
                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                  12-01-2024, 08:27 PM
                • MORETTIGIAN
                  Capacitor detached from PCB – RTX 2070 Super Founders Edition
                  by MORETTIGIAN
                  Title:
                  Description:
                  During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                  I did not notice it detaching, so I am unsure of its original location on the PCB.
                  Procedure performed:
                  - Removed backplate
                  - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                  - Reapplied thermal compound
                  - Reassembled card
                  Observed behavior after reassembly:
                  - GPU powers on and operates normally under...
                  09-18-2025, 12:14 PM
                • Ambro
                  Help identifying missing smd capacitor for HP elitebook 840 g3
                  by Ambro
                  In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
                  I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
                  I've attached a picture of where it's located on the board.
                  Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
                  Thank you for any help you can provide....
                  09-09-2023, 06:21 PM
                • grimacelord
                  Need Help Identifying Capacitor On Kar-Tech Versa Remote
                  by grimacelord
                  I have sort of a weird one here. This is the circuit board for a Kar-Tech VERSA remote. It's a wireless transmitter for crane and other heavy equipment.
                  One of the capacitors have blown and I need help finding a replacement. The capacitors are 11.4mm x 6.6mm in size and the only imprint on them is "200mΩF", which I am assuming means 200 microfarads. There is no other markings on them. I have tried doing some searching on digikey and mouser, but I can't seem to find anything like this on there or I am inputting the wrong search parameters....
                  09-08-2023, 09:28 AM
                • krob80
                  PS5 Edm-010 No Power - Help identifying missing capacitor
                  by krob80
                  Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
                  It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
                  When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
                  I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
                  05-15-2025, 04:24 PM
