Dead board with no obvious signs
  • rawgerz
    • Nov 2007
    • 14
    This is my once usable, Gigabyte GA-K8NXP-SLI board.Within 15 minutes it was completely dead. It was on almost constantly for 3 years and 3 months.
    It started out by doing a hard shut down from XP, and would do that several times, even during POST until it eventually showed no POST at all and the USB ports had no power.
    I thought maybe the power supply was bad, but I checked inside it and found nothing obvious.
    Best guess I have is a VRM went bad, but maybe someone can see something I didn't (sorry about pic size, don't have PS installed). I changed out the ram, PSU, video card, unplugged all optical drives and hard drives. Nothing worked. It was behind a UPS and not even it went off from a power failure or surge, and I know it didn't over heat either.
    http://s300.photobucket.com/albums/n...Picture002.jpg
    http://s300.photobucket.com/albums/n...Picture007.jpg
    http://s300.photobucket.com/albums/n...Picture009.jpg
    http://s300.photobucket.com/albums/n...Picture010.jpg
    http://s300.photobucket.com/albums/n...Picture011.jpg
    http://s300.photobucket.com/albums/n...Picture014.jpg
    http://s300.photobucket.com/albums/n...Picture016.jpg
    http://s300.photobucket.com/albums/n...Picture017.jpg
    http://s300.photobucket.com/albums/n...Picture020.jpg
    http://s300.photobucket.com/albums/n...Picture027.jpg
    http://s300.photobucket.com/albums/n...Picture028.jpg
    http://s300.photobucket.com/albums/n...Picture032.jpg
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: Dead board with no obvious signs
    I have not seen something strange except for the blue heatsink near memory slots, have you cut it?
    Reducing heatsink increase the device temperature and maybe this bring it to fail in the long run.
    If you connect the PSU and try to start the MOBO, does the CPU Fan work?
    Can you feel if something is overheating on the MOBO?
    I see some Nichicon cap and if I'm not wrong there have been some faulty production but I can't remeber the years.
    I have no suggestion, you have already done what I would do, maybe someone else here can help you.
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • rawgerz
      • Nov 2007
      • 14
      It's not the stock heat sink.
      I had to clip some pins to make room for the newer video card, but it never went over 90F. CPU fan didn't die either.
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        The K8NXP-SLI is a late 2004 motherboard, so it could employ bad Nichicon HN or HM caps (bad ones were manicatured from 2002 to 2004): I don't see any bulged cap anyway.
        For starter I'd clear the cmos (detach the power cord and remove the battery for about 10 minutes) and boot the minimal config: mobo, cpu, 1 stick of ram, videocard (maybe a cheap entry level one, just to avoid power issues) and psu. If it still doesn't post, check the chipset (the one under the cut blue heatsink): the nForce 4 has a serious heat problem which can be exacerbated if the heatsink doesn't dissipate heat enough (because e.g. the graphic card is too long and blocks air cooling).
        BTW, can you list all components?
        Zandrax
        Have an happy life.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Some Nichicon HN and HM series caps made between 2002 and 2004 were defective, though they usually bloat.
          I also see a chemicon KZG.
          I've had those fail with no visible signs of a problem.
          Mann-Made Global Warming.
          - Dr Seuss
          • rawgerz
            • Nov 2007
            • 14
            I already tried clearing the cmos the day it died. I left the battery out all night.
            I also took all the heatsinks off for to check for any scorch marks, nothing.
            When it went dead it had
            2x1GB and 2x512MB of corsair value ram, Opteron 145/8?, 8800GTS, and a 1yr old PC power 610W. It has to be the board because the same PSU, VGA, DVD, HDD, and PCI cards are in the new machine.
            I even tried my old 6600GT card and another 410W PS in it after leaving the battery out, and no ram at all. Just blank screens with no beeps. Fans still worked but that was it.
            I was under the impression that bad caps would give symptoms over time, not just up and die?
            This board was rock solid up till then. Even if it's repairable I'm still a bit leery on doing so. If the RAM is no good I wouldn't bother any further since regular DDR hasn't gotten any cheaper sadly. But at this point I'm only looking for the cause.
            It's been replaced by a EP45-DS3L
            http://www.newegg.com/Product/Produc...82E16813128345
            I just hope this one is as good as they imply..
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Caps aren't all the same, they don't all fail for the same reason, and are all subject to differing conditions,,, There are many different failure modes for capacitors.
              I have twice had KZG problems where the system worked fine one day and then simply wouldn't boot the next morning. I know it was the KZG because that's all I replaced.
              - Dr Seuss
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                even if the ram is bad corsair has a lifetime warrenty.
                and i had a board that looked fine cap wise that would not post.had a shorted nichicon hm on vcore.
                vrm would not run into that short.
                time to see what is not running.
                so many things can cause no post.no clock,vcore,vdimm,whacked bios,ect.
                • bgavin
                  • Jan 2007
                  • 1355
                  I have a Gateway board that is DOA after recapping. It is in the winter projects bin for re-evaluation. I used all Rubycon MCZ but it is solid DOA. The VRM sings quietly so I know I have a cap problem.
                  I didn't ESR test each cap prior to replacement. Then again, I didn't have an ESR meter, either. Over the winter, I will build my ESR meter kit, and see if I can correct this board.
                  OP, if your board is valuable to you, recap everything from 470uF and up with premium caps. Or, can do it in sections. Start with VRM, then memory, then the field caps.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • k370
                    Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                    by k370
                    I have a NM-A321 board that is dead, with no power at all.
                    When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                    With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                    • +3VALW
                    • +5VAUX
                    • 1.2VSUS_PWRGD
                    • 3VALW_PGD
                    • 1.05VAUX_PWRGD
                    Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                    The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                    09-23-2024, 11:57 AM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • corrize
                    Nikon D5 – dead, power board issue ?
                    by corrize
                    Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                    When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                    I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                    Now, I try to understand how it works.
                    There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                    04-03-2023, 09:13 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
