Need help to ID for novice
  • Bishop
    • Apr 2009
    • 99
    I have two Elite Gate control motherboards that died. The first boards lasted about five years, the company replaced it for free. The second board lasted about the same and the company replaced it again without cost to me. But I saved them both, just in case.
    I was going thru my rainy day (When I can't work outside) stock and decided to ID the problem. I just replaced the bad mofset on board #1, and I'll keep the board until I need it.
    Board #2 has a SMD burnt, but I'm not sure about its value ID.
    I posted some pics of board #1 that shows the same good SMD for ID and a pic of the burnt SMD.
    Any Ideas
  • Bishop
    • Apr 2009
    • 99
    Re: Need help to ID for novice
    My wife called dinner, I forget the pics
      • 31170
      it looks like an inductor, can you check the resistance across the good one next to it?
      • Bishop
        • Apr 2009
        • 99
        Could this inductor cause total failure of the motherboard?
          • 31170
          hard to say.
          if the power is going through it then the board will lose power.
            I would say it is inductor (ferrite bead) too, check the resistance between GND and each end to see if it shows low resistance <100 Ohms. It may have burnt up due to heavy current flowing through it.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
              by momaka
              03-15-2023, 10:17 PM
            • ermals
              Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
              by ermals
              Hi all!
              I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
              1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
              2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
              3. I've checked voltages...
              08-01-2022, 10:35 AM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
