Boyam99's mass merge of trolling & noob questions
  • boyam99
    Banned
    • Jul 2016
    • 26
    Ps3 cap not coming out
    My playstations cap is not coming out even while using a heat gun
      • 31214
      Re: Ps3 cap not coming out
      dont use a heatgun - post a photo
      • ozzy214
        • Nov 2013
        • 319
        • usa
        Can be leaded solder instead of unleaded which takes more heat. People dont condone it, but I use a soldering gun made for cars that puts out 100 watts I think. Takes most anything off.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          I've had to untangle many severely damaged boards and throw away a lot of destroyed boards that people used those on. It's definitely not recommended or a wise choice of tooling for this kind of work....I guess I shouldn't mind, I've made a lot charging people to unto their stupid mistakes....but it never ceases to amaze me the silly things people do & use to "fix" something.
          ...but for a PS3, which will be RoHS compliant (lead-free solder), read up on through-hole soldering, paying close attention to reflowing a little fresh solder into the joint to loosen it up....its right before how to hack vbulletin admin accounts and not getting caught...
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            +1 lol
            • boyam99
              Banned
              • Jul 2016
              • 26
              Found a bsod dell on the street with unknown cap
              A week ago I found a Dell on the street and I try it out and it bsod on the user login screen. I opened it up and I am unable to figure out what cap is in it. I am also unable to figure out what uf is it also after some research I'll guess it's a rubycon
              800uf 6.3v cap
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                Re: Found a bsod dell on the street with unknown cap
                umm, you answered your own question. read the FAQ section before making anymore threads.
                Team : 49813
                Join in!!
                Team Stats
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Re: Boyam99's mass merge of trolling & noob questions
                  Now can we ban him? He has started 9 different threads with nonsense characters after you consolidated all his questions into this thread. Proof via screen capture. He has already been warned once.
                  --- begin sig file ---
                  --- end sig file ---
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    the trollmonger is gone.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • ozzy214
                      • Nov 2013
                      • 319
                      • usa
                      #30
                      Whats a matter with using a solder gun? I have had great success. Mine is 30 year old weller like this....been using with no issue to fix boards.
                      https://www.amazon.com/Weller-8200-U.../dp/B00002N5LN
                      Never had a issue!!
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16958
                        Never had a issue!!
                        Consider yourself very lucky. Thats like using a 10lb sledge to drive finishing tacks. Just because it works doesn't mean its the correct tool or method.
                        Team : 49813
                        Join in!!
                        Team Stats
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          #32
                          Yea I was going to yesterday.
                          Even took a printscreen of all threads and shit.
                          Then I thought to myself: someone on the internet is wrong.
                          And I went to bed instead
                          And today I woke up a happy man when I saw TC has taken care of it
                          Here it is:
                          • ozzy214
                            • Nov 2013
                            • 319
                            • usa
                            #33
                            Im impatient. I dont want to bea tmy head off the wall waiting for the item to heat up LOL!
                            • DrewPhillips
                              Capacitor Diarrhea - Nichicon PL Series
                              by DrewPhillips
                              Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                              The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                              03-02-2025, 10:18 PM
                            • nick3092
                              Mid/late 80's Nichicon Yellow Caps
                              by nick3092
                              I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                              08-28-2022, 03:56 PM
                            • chth96
                              Is there datasheet for nichicon LXJ series?
                              by chth96
                              I want to calculate capacitor ESR referring to below guide.
                              https://forum.digikey.com/t/calculat...-from-tan/2633
                              I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                              I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                              Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                              11-20-2022, 08:11 AM
                            • chth96
                              Is there any datasheet for nichicon RT(M) series?
                              by chth96
                              A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                              https://www.badcaps.net/forum/troubl...e-been-blew-up
                              and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                              But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                              I have spare console...
                              11-28-2023, 03:36 AM
                            • spiros.p
                              EV dsp,replace the nippons lxz with nichicon fw ?
                              by spiros.p
                              Hi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
                              12-19-2023, 12:26 AM
