Boyam99's mass merge of trolling & noob questions
  • boyam99
    Banned
    • Jul 2016
    • 26
    I was able to find a replacement for my 6.3V 820uF caps,thanks for the help! However u have one more question, I need to replace some 100uF 16V nichicon caps in my mobo and after a quick Google search there are tons of variants of this type of caps. I need these specifically for a xbox 360 motherboard and I don't know which alternative's are available. After a bit of research I came across this thread
    https://www.badcaps.net/forum/showthread.php?t=24983
    But it doesn't state the cap that I need to replace. And I don't know if any polymers are available for this type.
    • 31214
    Re: Quick question about nichicon capacitors.
    what is written on the old cap?
    you need to know the series to get the right datasheet
    and dont use google - go here:
    http://www.paullinebarger.net/DS/
    • boyam99
      Banned
      • Jul 2016
      • 26
      It's the VZ series nichicon Capacitor
      • boyam99
        Banned
        • Jul 2016
        • 26
        https://cdn.badcaps-static.com/pdfs/...096baac272.pdf
        • boyam99
          Banned
          • Jul 2016
          • 26
          Found caps of different uF but same voltage
          I found a old computer with a ton of caps with the same voltage as the required caps I need but their uF is a bit higher.
          Will these work?
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            Re: Found caps of different uF but same voltage
            dont ever scavenge caps from another device and reuse them....they may not be any good either. You'd also need to check the spec sheets and make sure ripple & ESR specs are close. Quit being cheap, just buy the right parts.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • boyam99
              Banned
              • Jul 2016
              • 26
              I just order some Panasonic caps for about $2 and I would like to know if the are good in terms of quality and will they work?
              • boyam99
                Banned
                • Jul 2016
                • 26
                Is there a certain type of solder I should purhase?
                I order some .5mm rosin solder for some caps and I need to know if this will work or do I need a bigger mm size?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Re: Are Panasonic caps any good
                  Yes they are very good, what application for ?
                  • boyam99
                    Banned
                    • Jul 2016
                    • 26
                    Xbox 360
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      You will need Fk or Fr for them what they replacing. Also why several threads ?
                      • boyam99
                        Banned
                        • Jul 2016
                        • 26
                        http://m.ebay.com/itm/10pcs-Panasoni...=1764248671012
                        I got this
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Originally posted by boyam99
                          They are fake and will not be properly rated to genuine ones, order from somewhere like Rs.
                          • mariushm
                            • May 2011
                            • 3799
                            Re: Is there a certain type of solder I should purhase?
                            It will work just fine.
                            • boyam99
                              Banned
                              • Jul 2016
                              • 26
                              OK I'll cancel my order
                              • boyam99
                                Banned
                                • Jul 2016
                                • 26
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Ok bud.
                                  • Fixxr
                                    • Jul 2016
                                    • 7
                                    Have never had any problem with Panasonic, go for original one and You will be ok )
                                    • boyam99
                                      Banned
                                      • Jul 2016
                                      • 26
                                      What is the right watt soldering iron to desolder cap?
                                      I have a 30w soldering iron and I'm having trouble removing some of the caps in a gateway computer. Is there a specified watt I should use.I also have a 120w soldering iron as well
                                      • mariushm
                                        • May 2011
                                        • 3799
                                        Re: What is the right watt soldering iron to desolder cap?
                                        Can't solder stuff on motherboards with a 30w soldering iron, at least just with one.
                                        motherboards have multiple layers connected together, so all those layers of copper quickly absorb heat and move it away, making it almost impossible for your soldering iron to maintain the temperature of what you try to solder above the solder's melting temperature.
                                        It helps a lot to heat the board from the bottom with something, could be as simply as a hair dryer or a paint stripping gun but be careful to heat from some distance and gradually (start far away and bring heat source closer) and not go overboard because you don't want parts on the bottom to desolder themselves.
                                        Liquid flux also helps a lot, find some before abusing the board.
                                        • DrewPhillips
                                          Capacitor Diarrhea - Nichicon PL Series
                                          by DrewPhillips
                                          Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                          The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                          03-02-2025, 10:18 PM
                                        • nick3092
                                          Mid/late 80's Nichicon Yellow Caps
                                          by nick3092
                                          I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                          08-28-2022, 03:56 PM
                                        • chth96
                                          Is there datasheet for nichicon LXJ series?
                                          by chth96
                                          I want to calculate capacitor ESR referring to below guide.
                                          https://forum.digikey.com/t/calculat...-from-tan/2633
                                          I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                                          I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                                          Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                                          11-20-2022, 08:11 AM
                                        • chth96
                                          Is there any datasheet for nichicon RT(M) series?
                                          by chth96
                                          A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                                          https://www.badcaps.net/forum/troubl...e-been-blew-up
                                          and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                                          But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                                          I have spare console...
                                          11-28-2023, 03:36 AM
                                        • spiros.p
                                          EV dsp,replace the nippons lxz with nichicon fw ?
                                          by spiros.p
                                          Hi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
                                          12-19-2023, 12:26 AM
