So I recently purchased an Excelvan M6013 Capacitance Meter and was checking some new capacitors out. I was a little displeased that my previous favorite brand (lets call them Brand R) consistently read at least 10% below the factory rating and a few were barely in range at 20%, These are all new caps that are under two years from when I bought them from a major supplier. The Brand "N" and Brand "P" caps all read pretty close to the manufacturer specs. Is this normal? Wondering why a famously high quality brand test so poorly. Thanks.
New meter, surprising results.
Re: New meter, surprising results.
What meter do you have?Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpicComment
I am asking you.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
by jorpecHi
Thnaks -
Greetings, new guy here but always interested in the crazy universe of modding
We just finished construction of around 25 vacation houses, all inside the same private area.
Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...05-20-2025, 09:09 AM -
by eccerr0rMost analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and... -
by sam_sam_samI have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing... - Loading...
