MSI MegaBox - MS6760 Motherboard
  • DeeTee
    • Jul 2008
    Hey all
    Posting From New Zealand!
    Just picked up an MSI MegaBox thats not doing whats its supposed to do, i've disassembled it, and had the motherboard plugged into PSU, all I get from it is a high pitched squealing noise, from somewhere near a bank of capacitors, I can't spy any bulging on any of the caps on the board, nor any exploding.
    Is the squealing noise something a set of caps that are beyond hope will do?
    Powersupply fans don't spin up, nothing on the board spins up, all I get is the squealing!
    Thankyou to anyone who can help shed some light on this If you require more info to help diagnose, let me know and i'll see what I can do
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: MSI MegaBox - MS6760 Motherboard
    open up the psu and post pics.
    • DeeTee
      • Jul 2008
      sorry i should've mentioned, the PSU has been running in another PC fine :\
      • DeeTee
        • Jul 2008
        also, took HS/Fan off of the SIS onboard Chip, no visible signs of damage/cracking or anything on this chip.
        • sc2k
          • Jan 2009
          hi,
          i have the same problem. changed nearly every cap on the board, but it did not change. i found a workaround:
          connect the psu with the board. then use a wire to connect pin 13 (green) of the atx connector with ground (black). the psu fan will spin up and then spin down again. now the high pitch noise disappears.
          after that i am able to start the pc with the normal powerswitch. it works until i disconnect the psu from ac. after plugging it in again, i have the same problem.
          perhaps this works for you?
          greetings,
          sc2k
          • djpc47
            • Dec 2007
            • 17
            Originally posted by sc2k
            hi,
            greetings,
            sc2k
            if your still in existence, is this still working out for you; or did you find a better solution? I have inherited one of these with the same symptoms and workaround....
            • glovecaps
              by glovecaps
              11-25-2024, 04:23 PM
            • Docus
              Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
              by Docus
              Hi everyone 😀,
              I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
              To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
              Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
              1. I already own the exact same model, but its plastic chassis is badly damaged.
              06-10-2025, 04:24 PM
            • Archimedes
              HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
              by Archimedes
              Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
              Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
              Fans are spinning. Blindly could install windows11 and got the device manager...
              07-30-2024, 05:14 PM
            • dragon3x
              by dragon3x
              power on.
              Here are some examples :
              switching supply area).
              than 6.3 V.)
              03-21-2025, 02:46 PM
              ASUS P5GC-MX motherboard recap
              by momaka
              Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
              This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
              So here is what the motherboard looked like with its original caps:
              CPU VRM area up close…...
              01-27-2021, 11:59 PM
