HONGYE elyts
  • zuhr14
    • Dec 2013
    • 23
    • Antarktis
    HONGYE elyts
    Knows somebody their full home page?
    I found only:
    HONGYE Electric CO.,LTD
    http://hongyecapacitor.com
    established: 1999
    Country/Region: China
    - but here is only supercaps and other. No elyt and datasheets
    It would be best, find out their old home page for tracing with wayback machine.
    here is some HONGYE(without series) caps from LAN card REPOTEC RP-1624WA(RTL 8139D):
    HONGYE ?? 16V,22uF,105° (4x8) - 3x:
    • 30937
    Re: HONGYE elyts
    just use panasonic FR or rubycon YXJ series.
    • zuhr14
      • Dec 2013
      • 23
      • Antarktis
      Re: HONGYE elyts
      NET card is working - no need recap it. When I'll want to recap it, here I can put any general use caps with R.C:40/120Hz
      This small caps is not necessary replace with high quality caps.
      I only look for full version of home page + elyt sheets from this for me unknown company
      • microwave_highvoltage
        Old BIOS request(s) T550 and/or T440
        by microwave_highvoltage
        Hi there!
        The following request might well shatter the rules, however I ask you to read through to understand.
        I am looking for BIOS updates and or dumps from BIOSes that haven't been updated since December 2016 or have been saved before January, 2017,
        targeting ThinkPad T550 and/or T440. These are supposed to be TXT and/or Boot Guard enabled which is exactly what I'm looking for.
        Since I do not (yet) own a ThinkPad I cannot share a BIOS dump nor do I know a serial number.
        Why do I need this?
        I am very interested to see a special kind of...
        05-29-2025, 07:49 AM
      • slerner
        Recapping KRK VXT6 without original datasheets
        by slerner
        I'm desperate to save my pair of 2007 KRK VXT6 studio monitors, one of which died.
        Hoping for an easy fix, I bought a pair of new-old-stock replacement main boards. I installed one & it was DOA. Tried the other, also DOA. I suspect that 15 years in a Maltese warehouse dried out the electrolytic caps. I tried replacing just the two largest caps, which didn't help. Except to confirm that the old ones wouldn't reach infinite resistance & were a gram underweight.
        Q: How do I match the caps, since there's no series marked on the originals and no circa-2007 catalog or datasheets...
        01-31-2023, 02:21 AM
      • CapLeaker
        Fluke 289 bad supercapacitor replacement repair
        by CapLeaker
        Here it goes... we have two Fluke 289, bought one in 2012 and the other in 2013, both are rev. 015 boards. Both supercaps are done for. Take battery out for 3 seconds, put it back in, got date and time error on the display.
        The original supercap was a Panasonic EN series 3.3V 200mF SMD @ 500hrs rated. Digikey #: P14162CT-ND , Manufacturer #: EEC-EN0F204AK . https://www.digikey.com/product-deta...2CT-ND/1937320. Not available anymore.
        Replacement SMD Digikey part #'s:
        ELNA DSK series, 200mF @ 3.3V, exact...
        09-30-2018, 07:05 AM
      • Logistics
        Turn the wayback machine to 30-pin SIMMs
        by Logistics
        Because I have the bug like a lot of people on this board, and just like to dink around with old hardware, I've often has fantasies about recreating old hardware with new technology so that it's smaller or faster, whatever. For example, remember 30-pin SIMMs? Back then we were actually concerned with how many nanoseconds they ran at because you could actually notice a difference between say 60ns simms and 100ns simms. Or at least we thought we could.
        Anyway, I was wondering how comparable the speed of a 60ns SIMM would have been compared to the actual memory bus. What if you put...
        07-13-2012, 06:35 PM
      • pentium
        WhizPro BIOS password
        by pentium
        I have an OEM board here with the model SL-810 from BCM which again is some weird OEM company who barely supports this.
        I say barely because while a page for the motherboard exists all the links both now and according to the wayback machine which would remotely help me are all broken. Furthermore my board has a password set on the BIOS and it isn't clearing with the CMOS battery removed. It isn't totally locking the machine down however as I can still boot from an optical drive (but not the floppy ) but I've already gone through it with the BIOS tools on the Hirens Boot CD and...
        08-18-2017, 10:30 PM
