Recapping KRK VXT6 without original datasheets
  • slerner
    • Dec 2022
    • 20
    I'm desperate to save my pair of 2007 KRK VXT6 studio monitors, one of which died.
    Hoping for an easy fix, I bought a pair of new-old-stock replacement main boards. I installed one & it was DOA. Tried the other, also DOA. I suspect that 15 years in a Maltese warehouse dried out the electrolytic caps. I tried replacing just the two largest caps, which didn't help. Except to confirm that the old ones wouldn't reach infinite resistance & were a gram underweight.
    Q: How do I match the caps, since there's no series marked on the originals and no circa-2007 catalog or datasheets from the mfr TWBOR? I've wrung the web dry over this (wayback archive, patent office, digikey parametric search, ebay, stack exchange)!
    I also plan to recap the little “switch” board, too. It runs the status lamp & toggles for auto-mute, ground lift & overload handling (warn, ignore, limit). Its 4 caps have 8080808 printed on them. This corresponds to nothing.
    So I'm faced with recapping these boards, based solely on the marked voltage, capacitance, temp rating (all 105c) & physical dimensions. Can someone guess their functions from the pics & tell me at least generally what specs to look for, beyond what's printed on each cap? I don't have a schematic. Nobody seems to, it's been sought here & elsewhere. FWIW: this is a bi-amplification board (30 watts tweeter, 60 watts woofer, 1 mains transformer).
    Or better yet, if you've successfully recapped a KRK VXT6, would you send me your shopping list?
    Here is my list of caps, numbered according to the PCB. Height may be ±1mm, due to the black goop (which is neither brittle nor conductive).
    Code:
    Main board caps (all marked 105c)
    #	V	uF	diam	height
    1	25	330	8	12
    2	63	100	8	15
    3	63	47	8	15
    4	50	12000	30	53
    5	50	12000	30	53
    7	25	1000	10	17
    8	25	470	8	15
    9	25	470	8	15
    10	25	1000	10	17
    51	50	10	5	10
    201	50	100	8	12
    202	50	100	8	12
    204	25	100	6	10
    301	50	100	8	13
    302	50	100	8	13
    304	35	47	5	13
    502	50	10	5	13 nonpolar
    505	50	10	5	13
    613	50	100	8	12
    CA7	63	470	13	22
    Switch board caps (all marked 105c)
    #	V	uF	diam	height
    401	50	10	5	12
    404	50	4.7	5	12
    408	25	100	6	12
    410	25	100	6	12
    Last edited by Per Hansson; 02-26-2023, 02:32 AM. Reason: Fixed formatting of table
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Recapping KRK VXT6 without original datasheets
    Audio amplifiers don't usually use switchmode power supplies.
    Instead they use a big (line frequency) transformers like here.
    This means none of the caps usually are required to be low ESR.
    So just selecting "general purpose" caps with a 105°C temperature rating from the Japanese manufacturers is enough.
    Have you checked if you have any voltage on the big caps after replacing them?
    It sounds like something might have gone bad (fuse?) based on your older post here:
    https://www.badcaps.net/forum/showpo...5&postcount=10
    • slerner
      • Dec 2022
      • 20
      Thank you for the quick & excellent response! It's a huge relief that I can use general purpose caps. And thanks for fixing my table.
      The fuse idea is interesting. There was so much heat with the initial failure, that I did expect to find a fuse blown. There's nothing inside labeled 'fuse'. However, as Capsleaker mentioned in that other thread, R55 & R56 may serve as fuses. Those look intact on my original board. And on the new boards, of course.
      But, [and I presume this is your point] I also found three yellow boxes wired between the mains and the transformer. Amidst the black goo I found cbb62b printed on one. When I searched that ID, I found that it's a metalized poly film capacitor. https://pdf1.alldatasheet.com/datash...CH/CBB62B.html And on the list of 'similar products' I noticed an automotive circuit breaker. Ah ha!
      I powered up the unit and YES, my probe-style voltage detector beeped when it touched the main board's power plugs. So, it's good to know the transformer is still working.
      I also used the multimeter to test for voltage across the leads of the caps I replaced - nothing. This perplexes me. But, it's the old board that's currently installed and the crash might have fried something else on it. Each time I swap boards I risk breaking something. So, I think I'll finish recapping at least one new board and install it. If the unit still doesn't work, the diagnosis at least ought to be simpler with a fresh board.
      Thank you again for your kind advice!
      • slerner
        • Dec 2022
        • 20
        Ok, one more question.
        I've loaded my digikey cart with everything I need. All well-regarded brands Panasonic, CDE, Nichicon, Rubycon. A couple are Wurth, which I haven't heard anything about. But, since it's a German company I figured it's good. Also, some Kemet.
        Q: I have already replaced the TWBOR 12000uF 50V 105c 30x50mm snap-ins with JCCON 63V. [I recall reading somewhere in the JCCON docs that these have a 52V "minimum operating voltage". Honestly, I've been unable to find that wording again and maybe I mis-read it. 52V-63V seems like a crazy spec.] I'd like to buy better quality. But, digikey only stocks a 12000uF ≤ 50V in 3000hrs/85c. see link below. To me, a 3000hr/85c Nichicon, Rubycon or CDE seems like a step up from the original 105c/?hr TWBOR or the 2000hr/105c JCCON. Should I go for the 85c?
        https://www.digikey.com/en/products/...8Lmqh5JRMYjVAA
        Last edited by slerner; 02-02-2023, 07:16 PM. Reason: I had a correction in the brands
        • slerner
          • Dec 2022
          • 20
          Umm… I thought I had checked the voltage, but I guess I had not. It turns out my Klein voltage detector pen gives a little beep whenever it touches anything. That's all I got when I touched the board's power leads. If I push the probe into a mains outlet it gives a much louder beep-beep-beep.
          The reason I discovered this NOW, is I just installed my new-old-stock freshly recapped board and the amp still does nothing. No lights, sounds or heat. Honestly, I was worried that the unit failed so dramatically without blowing a fuse or circuit breaker. That seemed like a fire hazard. Instead, I guess the hazard was me. There seem to be circuit breakers on each of the 3 the mains wires into the transformer. Little yellow boxes buried in the black goop. I assume the next step would be replacing those?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Those are just EMI filter capacitors, they will be fine.
            Your fuse is in the bottom of the IEC input socket:
            P.S: The black gunk can be conductive, check out these EEVBlog videos of a similar KRK set:
            EEVblog #1072 - KRK Rokit 6 Studio Monitor Speaker Repair
            EEVblog #1073 - MORE KRK Rokit Black Gunk Speaker Repair
            Yes, using 85°C rated caps for mains frequency is no problem at all.
            I would 100% choose one of the Japanese 85°C capacitors over the other 105°C examples you provided as momaka said in your other thread here:
            https://www.badcaps.net/forum/showthread.php?t=115310
            • slerner
              • Dec 2022
              • 20
              HA! I can't believe I never noticed that! It's just like the picture. But, I can't figure out how to open that door. Wait - I just did. The fuse is burnt up. And there's a spare in the compartment. I swapped it out and IT'S ALIVE!! OMG I can not thank you enough!
              • slerner
                • Dec 2022
                • 20
                Oh, I forgot to say. Yes, I saw the Rokit video. My model seems to have a different formulation. It's not brittle and I get no continuity through it. It's actually so gooey I ruined a good brush scrubbing it off my hands. The next day I found a better solution. There's a solvent pad called Remove. It's for cleaning off medical adhesive. That worked like a charm.
                  Acer Extensa EX2540-56BF + PowerCube Original Notebook 15 Specification for Upgrade or Repair
                  This specification for the Acer Extensa EX2540-56BF + PowerCube Original Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX2540-56BF + PowerCube Original boardview and EX2540-56BF + PowerCube Original schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                  09-06-2024, 08:16 AM
                • kingiii
                  downloaded bios is smaller than the original bios dump
                  by kingiii
                  Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                  Thank you very much
                  06-07-2025, 04:21 PM
                • Ady2017
                  Are there any datasheets available for Elna RJG capacitors?
                  by Ady2017
                  I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                  05-25-2025, 02:19 PM
                • Maniackk
                  Reader PocketBook InkPad 3 – identification of a black component marked 'CT' on the microUSB line
                  by Maniackk
                  Device: PocketBook InkPad 3
                  Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
                  I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
                  I would appreciate help identifying this component.
                  Measuring the loose component with a multimeter gives 5.84 MΩ in both directions, while the one still on the board shows no measurable...
                  05-16-2025, 08:53 AM
                • KYBOSH
                  Samsung UN55HU8550F - No picture, No sound
                  by KYBOSH
                  Previous owner says this unit powers on and sometime has an image and sometimes not. They attempted to replace the main board but with no success.
                  TV came with the replacement mainboard as well as the original.
                  When the TV turns on there is no image or sound. No response to the remote or toggle button other than the power button. The power supply's relay was clipping here and there. It did that for several seconds even after I removed the mains. I did this even with no other boards connected (only the backlight was connected at the time). Backlight looks fine but...
                  01-09-2023, 02:36 PM
