WhizPro BIOS password
  • pentium
    • Mar 2006
    • 2778
    • computers, electronics, anime.
    I have an OEM board here with the model SL-810 from BCM which again is some weird OEM company who barely supports this.
    I say barely because while a page for the motherboard exists all the links both now and according to the wayback machine which would remotely help me are all broken. Furthermore my board has a password set on the BIOS and it isn't clearing with the CMOS battery removed. It isn't totally locking the machine down however as I can still boot from an optical drive (but not the floppy ) but I've already gone through it with the BIOS tools on the Hirens Boot CD and nothing seemed to work. The weird "WhizPro" BIOS isn't something any of the tools expect. I need something a little bit more powerful but I do not know what else to try. Any suggestions?
    Find Nedry!
    Check the Vending machines!!
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: WhizPro BIOS password
    Maybe same layout as their SL620, which is only S370/LPX board listed on BCM support page
    Does your SL810 have a JP2/Clear CMOS jumper in the same place as SL620 ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • pentium
      • Mar 2006
      • 2778
      The layout appears to be wildly different unfortunately.
      Find Nedry!
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        What about compared to FX815ELT ? - only other Wizpro BIOSed board from their Socket 370 range
        Or SL5598 ? - only LPX board from their Socket 7 range
        Otherwise, sorry - hope for response from your post on Vogons
        • pentium
          • Mar 2006
          • 2778
          Nope. None of those match up. :/
          Find Nedry!
          • rioreno
            • Feb 2009
            • 540
            • Indonesia
            if the cmos jumper suggested from boardl cannot work,
            you can try pull the winbond chip bios, and read using bios programmer like : cheap nanobios programmer..
            http://www.ebay.com/itm/NANO-BIOS-Pr...-/280388472031
            post here your backup file, i'll try to clean your bios..
            • pentium
              • Mar 2006
              • 2778
              I have a Willem Ver 5.0 unit that can dump the chip but it is being very inconsistent with this chip so far unless my settings are wrong.
              I can however dump the chip while it is in the machine. I got more than enough tools for that.
              Find Nedry!
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                How long did you leave the CMOS battery removed ?
                I'd try leaving it out overnight, the Irish technique (to be sure, to be sure)
                • pentium
                  • Mar 2006
                  • 2778
                  It was out for two weeks minimum.
                  Where the board came from initially I regularly see them come with flat CMOS batteries anyways. This could of been missing a backup battery for years.
                  Find Nedry!
                  • Adam925
                    • Aug 2017
                    • 19
                    • a whole lot of shit
                    that has worked for me more than once in the past!!!
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • electronics and DJing/producing music
                      I'd focus on getting a reliable read of the BIOS EEPROM. Given the age of that thing and since it's not in CMOS, the password is likely to be stored as plain text in EEPROM.
                      A working TV? How boring!
                      • pentium
                        • Mar 2006
                        • 2778
                        It's a 49LF004A. It's still quite new.
                        Also, I already dumped it. Poling through a hex editor however has not yet found anything.
                        Find Nedry!
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          If you got a good image check if you can disassemble it using tools leaked on the internet. Unless it's a Compaq BIOS it's likely to be some variant of AMI, Award or Phoenix which can be taken to bits.
                          • Black6spdZ
                            • Sep 2022
                            • US
                            hey Pentium.. do you recall ever getting into this board? I have one with a BIOS PW as well and swapping almost all of the jumpers around hasn't cleared the CMOS PW
                            • pentium
                              • Mar 2006
                              • 2778
                              Nope.
                              The dumps I did get were inconsistent so I don't trust my Willem with reading the FWH chip correctly. I was able to locate the CMOS clear jumper and while that did indeed clear the CMOS it immediately sets the password again, so that's a BIOS default parameter. I don't think I have ever seen something do that.
                              Because I couldn't crack the password I moved on from this board.
                              Find Nedry!
                              • Olegst44
                                Acer Aspire 3 A315-22G - NB8607G02-MB (Compal LA-J761P) - BIOS Password Removal / Clean BIOS Needed
                                by Olegst44
                                I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
                                Device Information:
                                - Model: Acer Aspire 3 A315-22G
                                - Motherboard: NB8607G02-MB (Compal LA-J761P)
                                - BIOS Chip: Winbond W25Q64 (8MB)
                                - Serial: NXHE7ER00X95002B784S00
                                Problem:
                                - BIOS is password protected (Supervisor Password)
                                - Boot from USB is disabled in BIOS
                                - After 3 wrong password attempts, system shows Unlock Key Hint
                                - I have RT809H programmer available
                                What I need:
                                1. Clean BIOS dump (password...
                                04-11-2026, 05:36 PM
                              • TopPop
                                Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                by TopPop
                                Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                12-14-2025, 09:40 PM
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • Dudebroman
                                Lenovo Ideapad Slim 3 Bios Password Ghost
                                by Dudebroman
                                Hello Hello,
                                I have been browsing the site and gotten so much useful info from here, including extremely helpful boardviews and several other very useful types of information. I am very grateful to this community, as I have actually eeked out a living from buying salvage PC's & Macbooks and repairing them. So, thank you all in advance!
                                I have searched and found some useful information regarding my issue, but my case is a bit different than the info I'm finding. But if anyone here can give me any useful advice, it would be highly appreciated.
                                12-18-2025, 12:22 PM
                              • traxformania
                                TONGFANG "GM7TG7P" Bios Password Problem?
                                by traxformania
                                I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                I'm trying to reset my bios without success.
                                I tried :
                                -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                11-15-2023, 07:32 AM
