VERY bad cap
  • tattoodee
    • Dec 2015
    • 8
    VERY bad cap
    Approaching my elderly mothers door recently I heard a crack which sounded like a .22lr rifle, on entering she informed me that it had come from the TV or the digital recorder box, she had immediately switched both off at the power outlet so I took a look, the TV was fine but when sniffed the recorder box smelt odd, but not exactly a "burnt electrical" smell, on opening it up I saw that one of the 220uf 16v caps had literally exploded off the board leaving both wires in place, before I attempt a repair does anyone have any idea what could have caused this?
    • 31003
    Re: VERY bad cap
    clean up the mess and take another pic so we can see the area better.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Re: VERY bad cap
      Usually never see that kind of catastrophic failure with caps unless it was abused (like reverse polarity)... Weird...
        master hoarder
        • May 2008
        • 12170
        • Bulgaria
        Re: VERY bad cap
        I guess the cap must have not had a safety vent. Because, even with reverse polarity and severe over-voltage, most caps with vents still just gas out politely.
        • tattoodee
          • Dec 2015
          • 8
          Re: VERY bad cap
          Well I replaced the cap and it didn't fix it, all I was getting was the front panel led flashing I'm guessing that either the exploding cap caused some other damage or some other fault caused the cap to fail
            master hoarder
            • May 2008
            • 12170
            • Bulgaria
            Re: VERY bad cap
            We need more pictures. You may have other bad caps in the box or perhaps something else wrong with the power supply.
              • 31003
              Re: VERY bad cap
              given the 4pin connector it's next to, i suspect it's related to the 5v or 12v rail
              maybe the hardrive is not being powered, a lot of newer cheap-ass pvr's store the firmware on the drive and only have the bootloader in flash.
              • tattoodee
                • Dec 2015
                • 8
                Re: VERY bad cap
                I took a look at the rest of the caps and several of them are swollen , I imagine it has had it's time but it hasn't done too badly lasting 5 or 6 years of daily use.
                  • 31003
                  Re: VERY bad cap
                  so new caps then
                  • Behemot
                    • 4845
                    • CZ
                    Re: VERY bad cap
                    I don't see the images but did the caps have proper vents? If they were ventless, its actually quite common for the pressure to leak through the bung.
                      • 31003
                      Re: VERY bad cap
                      vents?
                      he had the pair of plates and balls of brown paper syndrome!
                      no idea where the can went!!!
                        DVR recorder Switching power supply Failure
                        by sam_sam_sam
                        When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                        Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                        This...
                        05-27-2023, 03:03 AM
                      • Ady2017
                        Panasonic DMR-EZ48V DVD/VHS combo - DVD recorder part not working
                        by Ady2017
                        I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that...
                        06-06-2025, 08:05 AM
                        DVR camera recorder switching power supply capacitor failure really
                        by sam_sam_sam
                        These cheap non brand capacitors at it again
                        Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                        Well at least I have the cameras back on line I to try the...
                        01-22-2022, 06:28 PM
                      • UNITRAX
                        Radio tape recorder Hitachi TRK 8010k - How to install aux in place of am band?
                        by UNITRAX
                        Hitachi TRK 8010k
                        Is it possible to have an aux input in place of the radio on the am band range? When connecting to the tape recorder, I have additional tape noise. There is an integrated circuit HA11251 in the schematic. Which pin is the am radio output on?
                        Radio tape recorder diagrams and HA11251 datasheet included...
                        02-18-2023, 07:23 AM
                      • Sheppma
                        Streamax X5-E0804 CCTV recorder dead
                        by Sheppma
                        Hi, we have a number of Streamax X5-E0804 vehicle CCTV recorders that are dead - they all have a power supply PCB with 5 10F 2.7v super capacitors which have leaked and buckled, but replacing them doesn't fix the fault. Digging deeper it seems that there short circuit somewhere, but so far I have been unable to locate the faulty component. its a long shot but has anyone come across these DVR's or better still have a schematic?
                        02-26-2024, 10:10 AM
