Re: Need cap replacementt advice Chang CD288H / HE
Excellent advice. The lower RPMs should keep the dust buildup to a minimum too.
This might also be a good idea, but I have to see if there is enough clearance on the solder side of the board. When mounted, there is only a small clearance to the metal back of the display panel.
Half of the computer problems is caused by bad contacts
