Need cap replacementt advice Chang CD288H / HE
  • nfadel
    • Dec 2015
    • 27
    COBY TFTV4025 40" TV, stobing / flashing fluorescent tubes, found 4 bulging caps in the power supply:
    Chang CD288H 220uF 35V
    Chang CD288H 1000uF 16V
    Chang CD288HE 1000uF 35V (2 of these)
    all rated -40C 105C
    I was all ready to go to digikey and order some Panasonic FC like I have in the past to fix Dell monitors and then I read in the forums here that matching the ESR and ripple current is important.
    I looked through the specs list available here and couldn't find this Chang series, and google and yandex result sites only yielded "low ESR, high ripple current" for CD288H.
    Any advice? I suspect that some good Panasonic FC/FK/FM will work but I would like to be certain to get the best match, hoping for a decent lifespan.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Need cap replacementt advice Chang CD288H / HE
    all rated -40C 105C
    CD288H is LF Series (dead link) and 288HE is GF Series.
    For the 35V 1000uF:
    Chang GF
    12.5 x 20 - 0.035 1950
    Panasonic FC
    12.5 x 25 - 0.030 1945
    It'll work, if you can fit the taller cap in. But GF has a better spec than Panasonic FC in general.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      a better advertised spec that is.
      if you want some margin go fm,fr.
      fc will outlast the rest of that set.
      • nfadel
        • Dec 2015
        • 27
        My uninterruptible power supply battery died. So, I go to the auto scrapyard to get a $20 car battery sized deep cycle battery to replace the puny $15 3 Ah UPS battery. All they had this time though were 4 huge $30 deep cycle batteries, and I didn't want to spend the $30 they wanted for one of those. But then I noticed a pallet of dead batteries destined to be scrapped for the lead, and wandered over to look at it. On top of the pallet were numerous rows of 7 Ah and 8 Ah UPS batteries. I took out my meter, and found a large number of them that tested 14.75 volts, and bought 4 of them for $1.50 each. All test near new for amp hours. I'll be going back for more, since I can sell them for $10 each, $35 new for these. I also found a $15 stainless steel 1.5 gallon stock pot for 50 cents, almost like new. Then I saw a large box full of circuit boards and decided to investigate.
        I found a CRT TV mainboard, and not only did it have 3 of the 4 capacitors I need, there were all in perfect condition, and all the caps on this board are high quality Nichicons. Paid 45 cents for it. And I can get that back by scrapping the copper and aluminum from the board and flyback transformer.
        The scrapyard can be a great source of parts, never underestimate its potential.
          master hoarder
          • May 2008
          • 12175
          If you have one near you, that is. There are none around here and within 50 miles radius. Most electronics go to the e-recycles, and those never let you take anything. Same with large chain stores that collect e-waste (i.e. Best Buy, Micro Center, etc.).
          The Nichicon caps you got from that CRT TV board are probably VR series (and if that is the case, then this would also tell me it was from a Sony TV. ) They are good caps buy probably only rated for 85C. Not sure how long they will last in a hot LCD TV. Still probably better than the Changs, though.
          And for a darn 45 cents, I guess it's worth it - at least if your time isn't too valuable, of course.
          • Behemot
            • 4845
            • CZ
            Check the newer Chemi-Con series (KYB, KZN, KZH), you should be able to find D12.5x20 caps with the same or higher capacity.
            • nfadel
              • Dec 2015
              • 27
              I searched those links for Chang and elsewhere for CD288HE and the specs only say high frequency, low ESR. But no values are given.
              I understand the value of ESR being low, but what is ripple current, and how important is it? If I cannot find the original ripple current specs, what is the best shot in the dark here for use in this TV power supply (all on the cold side)?
              I decided to move the 2 taller 1000uF 35V caps off the power supply board to a vented location because the board had heat discoloration underneath both of them, so the extra 5mm of height going with the Panasonic FC isn't going to be a factor.
              I was thinking this for the 1000 35V caps However, there is no ESR value listed and it doesn't say low ESR.
              Would this be a good ripple current value for this TV usage (1.459A)? Is higher generally better in this type of power supply application? Is a lower impedance value better? How critical are these values?
              • Behemot
                • 4845
                • CZ
                Well I got datasheet for FOAI CD288H. I also know these caps beng sold as ChengX. Would say they are all the same…
                • nfadel
                  • Dec 2015
                  • 27
                  Found what I was looking for, at wikipedia of all places! Very detailed descriptions of aluminum electrolytics.
                  Perhaps this info can help someone else in the future: When replacing caps, try to get replacements with as high a ripple current as possible. A high ripple current rating automatically equates to low ESR and lower operating temperature. Also, for each 10 degree C increase in operating temperature, a capacitor's lifespan is cut in half, so for long life it is really better to relocate the larger (or all the) caps you are replacing to a remote location off of the power supply board. Use dual insulated wire of an appropriate gauge, and consider that the caps might get hot and melt plastic or glue and shift position, perhaps catastrophically if they short out on something, so secure them properly.
                  I have this TV sorted now, thanks to all that responded.
                  • Behemot
                    • 4845
                    • CZ
                    This is general information and does not always correspond with the reality. Capacitors evolve and what was low-ESR in 1990s, corresponds to some GP at best today. Nowaddays, low-ESR caps are getting closer to motherboard grade ultra-low ESR caps 10 years ago. And the current is a fuction of ESR, but not only that. Some caps have high current while higher ESR still.
                    Some wire relocation, forget about that. It is always best to have the bulk capacity as close to the ripple source as possible. As there is often heat, some reasonable compromise must be achieved. But the circuit parameters are given and by changing the lenght of the path you introduce absolutelly unknown parasitic inductance and delay in the filtering (transporting charge takes time, electrons are quite slow actually and the further it is, the worse; transporting high charges here and there also produces excessive heat). That can result in lower filtering effect or even to oscillation.
                    If there is no room, than yeah, moving it 1, 2, 3 centimeters away is not a problem. But stretching wires all over the board is just nonsense.
                    • nfadel
                      • Dec 2015
                      • 27
                      I've never encountered any problems moving them off the board, but I've always avoided routing the wires near inductors.
                      Sometimes you have to consider the unknown values introduced by heat roasting though, too. A carbonized board eventually equals a short circuit. My current power supply board:
                      • Behemot
                        • 4845
                        • CZ
                        Don't see anything in there, too tiny.
                        • nfadel
                          • Dec 2015
                          • 27
                          The brown area under the 2 big removed caps should be white. It is roasted brown.
                          • nfadel
                            • Dec 2015
                            • 27
                            I see you are from Prague, CZ. I have a friend there. Do you know the guy who posted this?
                            My youtube page
                            • Behemot
                              • 4845
                              • CZ
                              never seen that before
                                master hoarder
                                • May 2008
                                • 12175
                                If you have problems with heat, you don't simply move the caps away to keep them from roasting. Instead, a better solution would be to remove as much as the heat as possible. One way to do that in a power supply is to use bigger rectifiers with lower Vf drop... or forget about rectifiers (diodes) altogether, and use a synchronous rectification design with MOSFETs.
                                Better yet, to keep things simple, just install a low-RPM fan or put more holes in the case to allow for more air to come in and go out. Even a tiny bit of air movement can create a dramatic drop in temperature sometimes.
                                • Behemot
                                  • 4845
                                  • CZ
                                  In these displays, bad caps are often the cause of overheating (excessive switching). You change the caps, may stick a small passive in there too, and everything is good.
                                  But discoloration directly under caps is strange, what's going on there?
                                    • 31170
                                    leaky diode cooking the caps maybe.
                                    • nfadel
                                      • Dec 2015
                                      • 27
                                      Here is the video I took the image from. A bit higher resolution and you can full screen it.
                                      These are some generic images of the PC220P power supply board in case you recognize it.
                                      Going with installing a fan is a good idea, I will probably install a Pentium 3 class CPU heatsink fan along the edge of the board.
                                      The two 1000uF 35V caps go on top of the browned area, and they are in parallel in the circuit. I wonder if running two copper bus bars out past the edge of the board (on top of the board under the caps) and installing 2 more 1000uF 35V caps on this bus, so all four are in parallel, would work to reduce the heat generation? There is enough space to do it, and the copper would also act as a heat sink.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        If you have the space, then go for it. I would also advise you run it on 5V, because on 12V it might be very loud (at least most Pentium 3 -era fans are)
                                        Well, why not just solder the copper bus bars to the thickest areas of the PCB and without putting any caps on them? Then, the copper bus bars will simply serve as a heatsink and nothing else.
                                        I've done something similar with 14 AWG solid wire - just soldered a long piece on the tabs of several TO-252 MOSFETs to act as a heatsink. And it worked well.
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          11-20-2024, 08:52 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
                                        • disorder
                                          panasonic 42E5X need advice before buying hdmi IC
                                          by disorder
                                          hello guys,
                                          got a panasonic tv lcd 42E5X series, totaly dead after storm lightning
                                          on inspection, the fault seems to came from motherboard
                                          hdmi chip tmds361B si totaly fried (big hole in center), have to search on service manual to know which chip it is lol
                                          don't see any damage at inspection, do you think it is valuable to buy and replace or this motherboard became just a crap ?
                                          thank you
                                          04-11-2021, 05:19 AM
                                        • zen
                                          Txl47e5b , panasonic nand chip advice
                                          by zen
                                          Hi all
                                          Issue with this set is that after a few minutes of working , the remote control & on board functions stop working .
                                          Current software version is 1267-10402 , which i assume is the latest available , as i cannot get set to take an upgrade.
                                          Managed to obtain a working main board , which has same software version .
                                          Transplanted the TSOP 48 NAND chip , IC8900 ( 29F4G08ABADA ) from the working board into the faulty board , which now is working .
                                          This proved NAND chip is the problem , in the form of corrupt data....
                                          02-02-2021, 11:51 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
