Please Help!!
  • pauloz!
    • Mar 2008
    Please Help!!
    Hi, i recently acquired an old pc from a friend and he was telling me that sometimes the screen turned off randomly, so when i got it i changed the power supply to one that i already had, put different ram, a new gfx card and a clean hard drive with windows XP. Luckily i didnt have to purchase any of this as i already had these spare components.
    HOWEVER the pc still switches off the monitor randomly and goes into a freeze. I cant press num-lock, ctrl-alt-del or anything and the computer is stuck running with no output to the monitor. Sometimes it takes 5 mins for this to occur but sometimes it won't happen at all. I can't even turn it off from the power switch on the pc when it does happen, i have to turn it off from the power-point!! And sometimes the pc doesnt even load the BIOS when i turn on my pc again. Btw i am using a different monitor to the one my friend had.
    Then i came across this site and was a little intrigued. I am pretty sure that i have badcaps but take a look at these pics and tell me what you think...is it definitely badcaps??
    All that orange stuff is only coming out of the capcitors around the CPU. Luckily i didnt purchase any upgrades for the PC.
    SO all i wanna know is it definitely bad capacitors causing these problems???
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    Re: Please Help!!
    Yes, it is definitely bad capacitors, these bad caps seems are 1500uF 6.3v D8mm, just replace them with good caps is ok.
    I suggest you should replace all the same brands of bad caps on your motherbaords if possible.
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
    • starfury1
      • May 2006
      • 1256
      Re: Please Help!!
      Oh its defiantly bad caps
      but thats to start with ...if it still posting but hanging there's fair chance a recap will fix it
      What is the Mother Board ?...
      they look like they might be GSC caps if so make sure you replace ALL 330 uF and up
      (well anything with a vent can be advised, depending)
      (replace all anyway is best idea)
      It looks like the Output VRM caps are all history,
      The Input caps (etc) look OK but replace them as well is the best Idea
      If you dont know how to recap
      there are guides and lots of posts on it , look in the FAQ to start with.
      Alternatively contact TopCat forum owner if you wish to send out for recap.
      lastly sometimes memory can be screwed cause of bad caps so I think its important to put that through it paces too.
      welcome and Cheers
      • gdement
        • Jan 2007
        • 690
        Re: Please Help!!
        The Vcore output capacitors are definitely blown, but it's possible some of the blown caps could also connect to something else. Impossible to say without multimeter testing.
        Point is, you may find that it runs a little better with a slower CPU or downclocking the existing one. But even if that works it's not going to last very long, it really needs to be fixed, retired, or sold to someone else who will fix it.
        Don't put anything in there that you really care about, boards with dying caps can sometimes ruin your components.
        By the time the board stops working completely, it has much less chance of recovery. As long as it's still semi-working, it can probably be fixed.
        • starfury1
          • May 2006
          • 1256
          Re: Please Help!!
          just to add
          The symptoms you describe are typical of failed caps
          just so you know next time to look.
          This happens a lot with psu's too and can give the same symptoms
          Also caps can fail and not show signs of it
          Here is willawake's post on how to recap
          https://www.badcaps.net/forum/showthread.php?t=485
          And practice on junk first is my advice
          read posts around here and you will get to know what to look for with regard to caps and MB failures
          cheers
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            Re: Please Help!!
            well if thats not badcaps i dunno what is
            • stevo1210
              • Oct 2006
              • 4156
              Re: Please Help!!
              I am taking a guess that the motherboard is a Gigabyte motherboard?? That has to be the worst case of badcaps that i've seen in ages .
              Am I seeing things or is that CPU fan missing one of its fan fins??
              • starfury1
                • May 2006
                • 1256
                Re: Please Help!!
                possibly cause it looks similar to one you had stevo Gigabyte GA-8IDX
                https://www.badcaps.net/forum/showthread.php?t=4409
                but yeah that was my guess too...couldn't find anything to match it as yet
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  Re: Please Help!!
                  me too. anyway if they are puking orange then they are GSC and they are crap and they all have to go
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    Re: Please Help!!
                    thats a classic case of blown caps alright!
                    welcome to badcaps forums!
                    btw in the future you are likely to get better responses to your problem if you post the make/model/symptoms/ect instead of please help in the title.
                      by momaka
                      03-15-2023, 10:17 PM
                    • keepread
                      Dell monitor PSU vs Dell laptop PSU
                      by keepread
                      Hi there!
                      Someone gave me their old monitor, it's Dell S2715ht.
                      The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                      Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                      10-30-2025, 04:45 PM
                    • wattage
                      by wattage
                      Hello Badcaps Community,
                      07-13-2025, 04:41 PM
                      Wise Wing F199 19'' LCD monitor - recapped
                      by momaka
                      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                      When I saw the Craigslist post, I wasn't...
                      08-24-2020, 10:58 AM
                    • sew333
                      Pc shutdown, monitor flickered with no signal after 10 seconds
                      by sew333
                      My pc:
                      10850K stock 4800mhz stock Kraken X73 good temps
                      2x16 GB DDR4 GSKILL 3000mhz XMP
                      Seasonic Tx-850 Ultra Titanium
                      Gigabyte Rtx 3090 Gaming OC
                      Aorus Z490 Pro Gaming
                      1 TB SSD
                      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                      Power...
                      02-22-2022, 10:27 AM
