Any idea what to replace (attachment) with?
need suggestions replacing large capacitor
Re: need suggestions replacing large capacitor
it's a motor run cap
3uf 5%
never seen multiple voltages on one before, common size is 450v
like this
http://www.rapidonline.com/Electroni...acitor-10-2934Last edited by stj; 10-22-2015, 03:08 AM. -
http://cnlastone.diytrade.com/
http://cnlastone.diytrade.com/sdp/83...Capacitor.htmlNever stop learning
"Unlike usual capacitors on psu im not sure what to search for" Motor run capacitor.
I do not know what you have available in your country.
What kind of unit is it used in, Voltage? It is only 3uF so must be a small motor.Last edited by budm; 10-23-2015, 02:47 PM.Never stop learning
Those different voltages seem to indicate shorter hours of operation as the voltage increases so I'd try to find a higher voltage cap so that the hours of operation are near or at the lowest rating. Did I read 400V / 1000hours, 500V / 120 hours?Comment
an air conditioner compressor unit, and they charge me about $40 for each replacement
its quite costly
its been at least 3 times now theyve been replaced unless.... they are taking me for a ride.Comment
by MORETTIGIANTitle:
Capacitor detached from PCB – RTX 2070 Super Founders Edition
Description:
During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
I did not notice it detaching, so I am unsure of its original location on the PCB.
Procedure performed:
- Removed backplate
- Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
- Reapplied thermal compound
- Reassembled card
Observed behavior after reassembly:
- GPU powers on and operates normally under...11 Photos -
Hello All,
I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
https://www.hifivision.com/threads/m...-screen.98243/
Troubleshooting Summary: Majority Internet Radio - Flash Chip...-
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
I hope these photos make it clear which component I am referring to:
(yes, the soldering is a bit botched from removing the blown one, I know)
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by Agent24I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
It has at least one problem.
The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
I have already ordered a replacement potentiometer, so that's not an issue.
Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
All are CapXon... -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
I know that these capacitor will not last as long as nichicon capacitor...-
Channel: General Capacitor Questions & Issues
- Loading...
