need suggestions replacing large capacitor
  • biatche
    • Apr 2012
    • 27
    • Malaysia
    Any idea what to replace (attachment) with?
    • 31294
    Re: need suggestions replacing large capacitor
    it's a motor run cap
    3uf 5%
    never seen multiple voltages on one before, common size is 450v
    like this
    http://www.rapidonline.com/Electroni...acitor-10-2934
      http://cnlastone.diytrade.com/
      http://cnlastone.diytrade.com/sdp/83...Capacitor.html
      • biatche
        • Apr 2012
        • 27
        • Malaysia
        Actually I was more hoping for a quality replacement because we've replaced this MANY times and they just keep breaking
        Unlike usual capacitors on psu im not sure what to search for
          • 31294
          they shouldnt break.
          what is it fitted to?
            "Unlike usual capacitors on psu im not sure what to search for" Motor run capacitor.
            I do not know what you have available in your country.
            What kind of unit is it used in, Voltage? It is only 3uF so must be a small motor.
            • orgwood
              • Apr 2013
              • 39
              Those different voltages seem to indicate shorter hours of operation as the voltage increases so I'd try to find a higher voltage cap so that the hours of operation are near or at the lowest rating. Did I read 400V / 1000hours, 500V / 120 hours?
                • 31294
                no, 400v 10,000 hours,
                500v 1000 hours
                that's still nothing when you do the division.
                1000/24(hours in a day) = about 40days!!!!
                • biatche
                  • Apr 2012
                  • 27
                  • Malaysia
                  an air conditioner compressor unit, and they charge me about $40 for each replacement
                  its quite costly
                  its been at least 3 times now theyve been replaced unless.... they are taking me for a ride.
                  • MORETTIGIAN
                    Capacitor detached from PCB – RTX 2070 Super Founders Edition
                    by MORETTIGIAN
                    Title:
                    Description:
                    During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                    I did not notice it detaching, so I am unsure of its original location on the PCB.
                    Procedure performed:
                    - Removed backplate
                    - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                    - Reapplied thermal compound
                    - Reassembled card
                    Observed behavior after reassembly:
                    - GPU powers on and operates normally under...
                    09-18-2025, 12:14 PM
                  • praveenramavath
                    Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                    by praveenramavath
                    Hello All,
                    I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                    https://www.hifivision.com/threads/m...-screen.98243/
                    Troubleshooting Summary: Majority Internet Radio - Flash Chip
                    04-26-2025, 09:08 AM
                  • Prolog
                    RTX 3080 FE Identifying capacitor
                    by Prolog
                    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                    I hope these photos make it clear which component I am referring to:
                    (yes, the soldering is a bit botched from removing the blown one, I know)
                    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                    12-01-2024, 08:27 PM
                  • Agent24
                    Dick Smith Q-1760 linear power supply filter capacitor question
                    by Agent24
                    I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                    It has at least one problem.
                    The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                    I have already ordered a replacement potentiometer, so that's not an issue.
                    Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                    All are CapXon...
                    10-21-2025, 05:39 PM
                  • chth96
                    If I replace with inferior capacitor, Is it No harm to other IC components at all?
                    by chth96
                    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                    I know that these capacitor will not last as long as nichicon capacitor...
                    12-22-2023, 04:34 AM
