Help to Identify
  • djt4071
    • Aug 2015
    • 5
    • England
    Help to Identify
    Members,
    Please see attached photo of a bad cap on a Jetway NC9KDL-2700 motherboard.
    The cap has an indentation on the side as if it has been punctured and one of the terminals has broken off.
    As the motherboard is recently purchased albeit second hand from Ebay I am unsure if the cap has blown out or damaged in transit. Can anyone clarify if the damage reported is symptomatic of a blown cap or physical damage.
    I am struggling to identify the capacitor as the markings do not seem to correlate with anything online. I have reason to believe that it has been manufactured by Panasonic.
    Can anyone help to identify so that I can order a new one?
    Much appreciated,
    Dan
    • 31036
    Re: Help to Identify
    see this post.
    https://www.badcaps.net/forum/showpo...48&postcount=8
    • djt4071
      • Aug 2015
      • 5
      • England
      stj,
      Thankyou for your reply. Can you shed any further light as to where to source a replacement and also the details of the replacement necessary.
      Much appreciated,
      Dan
        • 31036
        820uf 2.5v polymer
        you know the diameter - i dont.
        once you know the diameter, farnell has some with free shipping.
        • djt4071
          • Aug 2015
          • 5
          • England
          stj,
          That's great - thankyou. Actually looking at the markings I can begin to decipher where you got that information from.
          Thanks for the help.
          Dan
          • c_hegge
            • Sep 2009
            • 5219
            it's probably 8x8mm (L8 series)
            http://uk.farnell.com/nichicon/rl80e...tor/dp/1854119 would be an exact replacement
              • 31036
              £15 delivery charge on u.s. stock.
              he needs to use a 6.3v version from wurth-technik
              or see if RS has other brands in stock.
              both RS and Farnell are busy cutting each others throats at the moment with unlimited free delivery!
              • thesame
                DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                by thesame
                Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                02-27-2024, 04:31 AM
              • silver60618
                Lenovo Legion 7 - Help Identify IC
                by silver60618
                Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                Any help would be appreciated...
                07-02-2025, 12:16 PM
              • chth96
                How can I identify varistor which have been blew up?
                by chth96
                I mistakely pluged 100v japanese retro game console to 220v outlet.
                So It seems that glass fuse and varistor have been blew up.
                I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                Is there any way to identify varistor type in my sega saturn PSU?
                Any reply would be appreciated.
                EDIT:
                It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                11-26-2023, 08:52 AM
              • freakorio
                Need Help To Identify Component on Ymain LJ41-05120A
                by freakorio
                Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                05-21-2024, 02:32 AM
              • baiceanu_stefan
                nm-f251 Schematic, boardview or help identify componente
                by baiceanu_stefan
                Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                04-24-2024, 12:49 AM
