Another Sanyo ebay scam
  • Hagis2k
    • Jul 2006
    • 66
    Needed capacitors to repair a computer powersupply and i did order a few here and there, so i did order a batch of 20 of Sanyo WG 2200µ/16V he never showed the top of the capacitors and i read his feedback and i thought it should be ok? no...
    I knew right away when i saw the "+" type of vent that it was fake but lol look at the photos, they didn't even care to remove the old heatshrink so i reported the seller too.
    https://www.youtube.com/watch?v=zW2HFj7rAXc
    So here is a video i made for the seller, to prove to him that i marked my cut with a blue permanent marker where i did cut, and yes i find some marks in the metal after someone else did rebadge these capacitors
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Another Sanyo ebay scam
    The vent cuts looks like Nichicon's the way they shallows on the ends of the capacitor. But what series? Good luck finding that.
    By the way, did you check their ESR and capacitance, just for kicks?
    I guess let this serve as an example here why to avoid buying caps from shady sellers on eBay.
    • Hagis2k
      • Jul 2006
      • 66
      Well i did two tests on each cap, first with a chinese component tester but i am not trusting that more then my Atlas ESR70
      • Behemot
        • 4845
        • CZ
        I got better and genuine capacitors there
        • capuse
          • Jun 2015
          • 9
          • usa
          Another possible fake on eBay? These Rubycon are listed as 6.3v 1500uf MBZ size 8 x 20. But the MBZ spec sheet lists only a 10.0 v 1500uf in the 8 x 20 size. Has anyone seen a 6.3v 1500uf MBZ in this size?
          • Behemot
            • 4845
            • CZ
            It may be custom for some MB maker, these are about the only remaining genuine ultra-low ESR caps in there. I have bought 1000 pcs of MBZ 1000/6,3 like that (blue ones) while datasheet also only says 820 uF. They appear to be quite genuine, have legs cut and bent to fit D10 holes.
            • Hagis2k
              • Jul 2006
              • 66
              The Rubycons look real but it is like russian roulette to buy capacitors over ebay lol, i bought 50pcs of 1000uF/16V nichicon from audjade_chn and they seems ok
              Is there anyone who has a "list" of sellers on ebay they trust a bit?
              • Behemot
                • 4845
                • CZ
                No use, sometimes it seems same companies have tens of different accounts…and when they sell out genuine caps they just start selling craps or fakes.
                • Hagis2k
                  • Jul 2006
                  • 66
                  Yeah that sounds like how it is, seen so many sellers with almost the same names, better to buy them else where you know what you get.
                  • Behemot
                    • 4845
                    • CZ
                    The problem is there is almost nowhere to buy them anymore. Big resellers may have a few left but they also have terrible prices. Than topcat has some…also for somewhat higher prices.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      something to be said for getting what you order reliably.not to mention buying from the badcaps store keeps this forum running.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4968
                        • New Zealand
                        Exactly - forget eBay etc and buy from a known good seller!
                        It may cost more but I find having confidence in the parts is worth far more than the money saved by getting them elsewhere.
                        -David VanHorn
                        • Behemot
                          • 4845
                          • CZ
                          I am reliable too And also cheap and also sell on ebay…you got it all wrong sir
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            But you are like 1 in a million there
                            Keep it up, though. I appreciate sellers that offer quality caps.
                            • Behemot
                              • 4845
                              • CZ
                              Yes, but the way he wrote that means there are *no*. In such case, only one existing means his statement has been proved wrong. You have to love mathematic logics
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4968
                                • New Zealand
                                Well, if you sell genuine capacitors on eBay then that's great and you have proved me wrong, but the last thing I read about eBay sellers on the forum here suggested there were none left that were any good.
                                -David VanHorn
                                • Behemot
                                  • 4845
                                  • CZ
                                  https://www.badcaps.net/forum/showthread.php?t=47349
                                  But I guess you rather keep buying 98 % fakes than invest some money in originals. The same way ppl fucked me over with those KZNs and keep buying 2200uF caps for mostly the same price…
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4968
                                    • New Zealand
                                    Me? I've never bought fakes...
                                    -David VanHorn
                                    • Behemot
                                      • 4845
                                      • CZ
                                      This is the english…you cannot distinguish you singular and you plural
                                      • DXseekerMO
                                        Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                                        by DXseekerMO
                                        Hello everyone!
                                        Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                                        I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                                        Yes
                                        0%
                                        1
                                        All backlight strips are the same quality
                                        0%
                                        1
                                        No
                                        0%
                                        0
                                        12-16-2021, 03:58 PM
                                      • myth77
                                        how do you resolve problems with ebay (and other shop) scammers!?
                                        by myth77
                                        When i need to replace cpu or gpu or pch ...i mostly order reballed chip from china, but lately there are more broken ones then working.
                                        So lately i tried with ebay "not working motherboards". I ordered a few broken motherboards from ebay but i have found out that there are many scammers on ebay. The most of them are selling already destroyed motherboards with pictures in low resolution, some of them are being scammed and just scam forwarding...
                                        First board i ordered last month was ok. Cpu was dead but i could use gpu and pch. The second arrived 2 weeks ago...and it was...
                                        09-02-2022, 04:53 AM
                                      • cj_reha
                                        Mystery 80s Sanyo cap - perhaps polymer?
                                        by cj_reha
                                        Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                                        01-06-2023, 09:24 AM
                                        LED Solar Flood Light Dusk to Dawn Security Wall Street Yard Outdoor Lamp modifications are in order
                                        by sam_sam_sam
                                        I bought one about a month ago from an eBay seller who now is out of stock however I found another eBay seller that has the same version of this device so I think about buying a few more of over a period of time
                                        Awhile back I bought some A123 brand 18650 battery cells that are 3.2 volt battery cells that I am going to use in this device for more running time in a florescent bulb fixture that I gutting out the tube sockets and turn it into a solar powered LED lighting fixture instead
                                        Pictures will come later when I have the lighting fixture gutted and have the battery...
                                        08-11-2024, 11:10 AM
                                      • Andriy Andrusyk
                                        Buying a Used GTX 1080 Ti – Is It a Scam?
                                        by Andriy Andrusyk
                                        I am buying a used MSI GeForce GTX 1080 Ti. All photos are attached. Is it a scam?...
                                        05-15-2025, 12:31 AM
