Re: List of Bad Cap Manufacturers
I have a couple of HP 17" LCD's that had some dark spots ( bad pixels ) that had good boards I used to fix other Dell LCD's. I'm thinking of recapping them to have as spare since I see a lot of these. The first board is a BenQ with 19 caps, 16 Elite ( 2 obviously bad ) and 3 Lelon. The second is a really f snazzy board with the display driver circuitry on the same board as the PS with a large Genesis chip. It has 3 OST caps ( 2 obviously bulging and 14 Su'scon all of which appear okay. Should I replace all of the caps because they are suspect?
This is a sticky topic.
oh.there are plenty of them here in our country.Leave a comment:
Teapo???are the same brand that are mounted inside the d-link and netgear!Leave a comment:
1.6 ohm for such capacitor is a reasonable value.
As for replacement, I'd look at Nichicon PW or capacitors with similar specs as Nichicon PW.
Don't hesitate to replace it with a capacitor rated for 50v or even higher, it's not a problem.Leave a comment:
Has anyone seen SHI capacitors - I know, someone actually chose to call their capacitors SHI(R) without the T.
Tried google but no joy....
I have a 10uF, 25v with 1.6ohm ESR and wanted to see the specs for a replacement (see Paulmann electronic transformer thread)Leave a comment:
Not sure if its appropriate to post this here or start a new thread; but is there a corresponding list of the known high quality caps manufacturers ?
I'm thinking maybe the top 5 brands or something...
I've done a quick search but cant find anything so far.
All I have managed to find upto now from my web searching is that the Panasonic FM and FC series seem to be highly regarded.Leave a comment:
S.I. are bad too, swapped a bunch in a Socket A motherboard.Leave a comment:
I swapped out four bloated R&C brand caps in a Space 600T digital set top box earlier this year. The machine would power off immediately after turning it on.
I didn't see R&C in the list, so it's probably just a generic Chinese make (in fact, the "Space" brand name is seemingly just as generic as the caps within). At the time, I only had access to equally generic S.I. caps from Jaycar Electronics, but they have held up so far. The machine now works fine, albeit missing the remote and having a password on the setup menu (it's not the default 0000 as most are).Leave a comment:
Same here. Someone just brought me an Acer that won't boot up. It has a cheap imitation Foxconn board. It's littered with Lelons and OST's. But the caps that are bulging and leaking are TK's. I'm not gonna waste my time with this one though since a new board with an LGA775 socket is only 20-30 bucks.Leave a comment:
tk is one of the most notorious brandsLeave a comment:
I just pulled 10 TK 6.3 1800uf from a newer E-machine no name board with 8 leaking and 2 full blown. Either something else is wrong with this board (besides being an E-machine, lol)
Or you guys should definitely make sure that they are on the first list on this thread.
PestiLeave a comment:
Here's a hint.
Mouser and Xicon have the same address in Texas.
http://www.macraesbluebook.com/searc...company=440357
http://www.mouser.com/contact/
I doubt Xicon actually manufactures[ed] caps.
There old site was www.xicon-passive.com but now that redirects to Mouser.
I think they were a rebranding distributor and not actually a manufacturer.
Mouser is phasing out Xicon caps and replacing with Lelon.
.Last edited by PCBONEZ; 11-11-2011, 01:39 PM.Leave a comment:
Is it green or blue?
Green=Xicon's Low ESR series
Blue=Xicon's GP seriesLeave a comment:
where do I find the list of bad cap manufacturers. I am questioning a cap with the markings of "xicon" its a 470uF at 16vdcLeave a comment:
by cookAre there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
Thanks-
Channel: General Capacitor Questions & Issues
by Mark DThe TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
by Deby
This is a list of compatible laptop motherboard information that I have been collecting for some time.
And it's still ongoing.
Every time I come across information that a board is compatible with another, I write it down.
Anyone who wants to, can continue to expand the list.
Packed in the rar, is an excel table that has additional information.
Motherboards.rar...05-31-2024, 04:34 AM -
by MarkRocketThis is not a definitive list, and I do not claim if it is 100% accurate so please do your own research, based on the information from littlefuse, RS, Farnell and a few other places, using information about the markings on the fuses
Please feel free to distribute, amend, correct, etc... -
Samsung UN82NU8000FXZA 82" LCD TV Parts List...
Channel: Schematics and Boardviews
11-01-2024, 06:16 AM -
- Loading...
