Does anyone know/recall the dates for the bad HM and HN Nichicon caps?
HM HN, Dates for the bad boys?
Mann-Made Global Warming.
- Dr Seuss
Tags: None -
Re: HM HN, Dates for the bad boys?
Sometime in 2003. I'm currently using ones from 06 and they work well. -
I understood it was 2002 to 2004 but I don't know the months.
I know Dell pulled all their Intel boards with them in March 2004 but that doesn't tell me when the bad caps stopped.
Not really concerned with new parts.
Wanna know to know which existing motherboards to expect HM/HN problems on.
.Mann-Made Global Warming.
- Dr Seuss
Okay then.
Does anyone have a link to the news stories when Nichicon admitted the problem?
I might be able to estimate dates from those.
I have some boards w/2004 caps and I want to figure out if they are in the problem zone for time by the month.Mann-Made Global Warming.
- Dr Seuss
They should just discontinue the series these caps have obtained a bad reputation that will always be in the back of everyone's minds.
Maybe they are so reasonably priced because they want to unload junk caps.Last edited by Krankshaft; 03-20-2008, 11:10 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
Even Rubycons blow occasionally with a bad PSU or excessive heat.
One bad board here or there doesn't mean much no matter what the caps are.
Dell, who had the HN/HM problem with a number of their systems, issued a public statement that any of their system boards built after Feb of 04 would not have bad HN/HM caps.
About the same time Nichicon announced that all the faulty caps had been pulled from the supply channels. (Obviously they had stopped making whatever mistake by then.)
I don't know about early 04 but 05 date codes should be as safe as any other known good brand.
- Dr Seuss
Originally posted by KrankshaftThey should just discontinue the series these caps have obtained a bad reputation that will always be in the back of everyone's minds.
I agree with the first part.
At least come up with a new name for the series to avoid confusion and rebuild buy confidence.
The ones before and after the mistake aren't junk though.
HN is comparable to MCZ and comes in sizes you can't get with that low of ESR in any other series. (All the way up to 5600uF in a 12.5mm can.)
- Dr Seuss
Thanks, I'll take a chance and pick up a 100 or two - if they survive for a year in VRM/PSU use, I'll go back and see if I can snag the remaining stuff in the carton. It's not that easy to find ultra-low ESR 3300uF in 10mm - probably only Rubycon MCZ, a few series of Samxon - neither of which is readily available locally to me.Comment
6.3v 3300uF in 10mm aren't too hard to find here in MBZ.
Now 16v 3300uF in 10mm,, THAT'S a whole nuther story!!Mann-Made Global Warming.
- Dr Seuss
0429 HN:
For what it's worth, I have an Intel board with 3x 1000uF 10V 10mm Nichicon HN(M) caps on it. 1 of the 3 has exploded. They have 0429 date codes on them, but 1 of the good ones I can't actually read.
The one that exploded is next to the top PCI-ex slot (where a video card would be). I haven't actually confirmed what it's connected to though.Comment
they might be ok but why take the risk?
might be ok to grab some and put them in a tough app to test.
i mainly repair business and industrial stuff for folks who cannot tolerate downtime so i just buy parts with a good track record and be done with it.Comment
If you accept isolated instances as proof of anything you'll need to rule out everyone because dang near every series has a failed cap here and there.
That's kind of why I opened the thread.
If we have say 3 or 4 other reports of bad HM HN from mid 04 that might tell us something.
What gdement just did is kind of why I posted this thread.
To collect HM/HN dates of fails.
My 'for what it's worth'.
There is a 0526 date code on HM's in the wife's machine.
They are RIGHT next to the heatsink on a 2.8 GHz Prescott.
In her uATX case the cooling isn't the best.
(I hate that case but she won't let me take the hole saw or a drill bit to it...)
I bought the MoBo used.
Been up and running almost 24/7 with the Prescott for almost 2 years now.
No problems. - None.
gdement
On those 0429 HN, what was the PSU and what are/were the operating conditions.
The earliest fail I've been able to find is HM from 0135.
But that's the only 2001 dated fail I can find.
https://www.badcaps.net/forum/showthread.php?t=1286
- Dr Seuss
None of these will go into mission-critical stuff - it's just a useful ultra-low ESR series/value that will fit in places (Shuttle SV-24, Channel-Well PSUs, SFFs, etc.) where other series may not fit. It's certainly worth checking out whether Nichicon actually fixed the problem with the HMs - the only other 3300/6.3/10 mm series I have easy access to is Yageo (part of the Teapo conglomerate), so I'd be very happy if the 2005 HMs are good - I get them for the same price as the Yageo.
The first experiment will be on an i815T now running a Tualeron 1200 at 100 FSB - if I can get it to run stably at 133 FSB (1600 MHz), I'll be a happy camper.Comment
The 2 good caps are in the vicinity of RAM and the power input, the bad one is near the large PCIEx slot, where it could be buried under a video card. The Vcore caps are oscons.
So I can see how heat could have been a factor, or it could just be a random case of bad circuit design. It's an intel board though, they ought to know what they're doing... I hope.
I agree that one fail isn't much to go by, especially since I don't know the history. Unfortunately I don't have any other boards with HM/HN caps from 2004+.Comment
I'm thinking Nichicon had a ~REAL~ hard time selling them to anyone by mid 2004.
Probably just aren't that many around.Mann-Made Global Warming.
- Dr Seuss
by DrewPhillipsHello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...-
Channel: General Capacitor Questions & Issues
by nick3092I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
by chth96I want to calculate capacitor ESR referring to below guide.
https://forum.digikey.com/t/calculat...-from-tan/2633
I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
Is there anyone who still has old nichicon datasheet which has information of LXJ series?-
by chth96A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
https://www.badcaps.net/forum/troubl...e-been-blew-up
and I finally fixed​ this retro game console by soldering varistor and glass fuse.
But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
I have spare console...-
by spiros.pHi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
- Loading...
