HM HN, Dates for the bad boys?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #41
    Re: HM HN, Dates for the bad boys?
    Thank you kc8adu, that was a very interesting read!
    So afterall my readings where very much in line with what to expect for HM/HN, very interesting!
    • japlytic
      • Oct 2005
      • 2086
      On a Palit 8400GS Super video card, I saw a 1500uF 6.3V Nichicon HN series on it, made on the 13th week of 2009. Should that unit be OK?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        2009 is fine.
        Bad ones were 2001 thru 2004.
        The Hillman-Helmold study doesn't apply to the HM/HN problem.
        It DOES explain why caps made with CH and TW sourced materials are crap and that's why you hear 'use Japanese caps' so much.
        The study was done by CALCE out of the University of Maryland.
        There is all sorts of interesting stuff on their site.
        http://www.calce.umd.edu/
        Mann-Made Global Warming.
        - Dr Seuss
        • oddbondboris
          • Jun 2011
          • 9
          #44
          i know this is old and all but i've got 9 nichicon hm series 6.3v 1500uF caps in a 3com 2808 gigabit switch. all the caps are datecoded 0341 and all are bad
          thing lasted 8 years in a no aircon environment on 24x7 somehow
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Thank you.
            - Dr Seuss
            • Behemot
              • 4845
              • CZ
              #46
              I believe the week 22 is NOT correct. H0452, 2200 uF/10 V from Intel D865 PERL, no source of excessive heat nearby (between SB and RAM) and it is very nastly bulged as all the bad HNs did/do.
              Just for case removing also golden 820 uF/6,3 of H0447 in the CPU VRM. One strange thing, I have had the same board before, also with bad HN's, but there was more of them in the VRM. Is it only my impression or did Intel really use random ratio of Nichicon's HN and Chemi-Con's polymers??
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Here's something interesting:
                My Asus A7N266-VM has HMs coded 0310.
                But the BIOS is August, 2002.
                I hope this don't mean that Nichicon is using Seagate-like date codes, where
                "10254" I think is actually in 2009! (And not 2010 like some people believe)
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • Behemot
                  • 4845
                  • CZ
                  #48
                  Whats the problem? The manufactured the board later yet loaded with old revision of BIOS.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    The board is OK, no signs of bad caps. (Unless tests that were fine before suddenly fail.)
                    I just had it sitting. Because it won't let me OC.
                    "-VM"s especially that generation, prohibit OC'ing.
                    You must mod the board to OC a "-VM", especially the socket 462s.
                    It worked fine in 2007, the last time that it was on a lot.
                    "-X" boards usually allow a fair amount of OC'ing and Vcore changing.
                    Arc A770 16 GB
                    • Behemot
                      • 4845
                      • CZ
                      #50
                      Just found two HMs, 0227. They measure 4400 uF, seems that part of the problem may be somebody tried to push it too hard
                        master hoarder
                        • May 2008
                        • 12175
                        #51
                        ^ Typical for problematic HM and HNs. The capacitance is actually not that high, but these capacitors develop high internal leakage and will fool an ESR meter.
                        • UserXP
                          • Apr 2012
                          • 440
                          • Serbia
                          #52
                          Here is my contribution to the topic.
                          There are two 6.3V, 3300uF Nichicons HM series dated 0432 next to the heatsink on this older Gigabyte S478 board I have, and near VRMs there are three 16V, 1500uF Nichicons HM series also dated 0432. There are no signs of bulging and the board runs perfectly stable. The processor is a P4 at 3.0GHz and its temperature idles around 43 degrees (more when something is run).
                          So, these Nichicons were produced sometimes in the second half of the year 2004. They seem OK after so many years and use. Maybe these have a corrected formula.
                          On the other hand, I had to replace the 0522 Nichicons on another S478 board (we had a discussion here about that experience in my topic regarding that), so there it is. Datecode 05 failed, whereas datecode 04 still operates fine. I guess it did depend on a particular production line or something, right?
                            master hoarder
                            • May 2008
                            • 12175
                            #53
                            It's possible.
                            I think this issue also possibly extends to the HZ series.
                            Last week, I dug up some severely bulged 6.3V 2200uF Nichicon HZ from my parts bin. These caps were pulled from various Xbox 360 motherboards, but they were all good at the time I pulled them. That was about a year ago, though.
                            Now check this out: the Nichicon HZ caps with datecodes H06 and newer (so 2006 and newer) are all fine. However, several of the H05's were bulged. Moreover, last time I used the MicroESR to check another parts bin of mine that also had various HZ caps, most of the 2200uF H05 HZs read 2300-2400 uF and some even higher. But not a single one lower.
                            Perhaps overfilled like the defective series from 2001-2004? I think so. Maybe not as badly, as Nichicon likely had figured out their mistakes by that time and were probably just "tweaking" their manfacturing process.
                            For that reason, I don't fully trust Nichicon HM/HN/HZ caps from 2005. If they read higher capacitance, then they may be overfilled.
                            I still use them, though - mostly for testing or repairing my own (non-critical) equipment.
                            • PeteS in CA
                              • Aug 2005
                              • 3581
                              • USA, Unsure of Planet
                              #54
                              In an electrolytic capacitor, the electrolyte is a conductor. The capacitance depends on the surface area of the plates and the thickness of the dielectric, which is a layer of aluminum oxide on the anode foil. If the capacitance of those HZ caps has increased over time, that means the electrolyte has attacked and thinned the aluminum oxide layer. Not a good thing! That increases the capacitance and decreases the actual maximum voltage the part can handle.
                              PeteS in CA
                              • UserXP
                                • Apr 2012
                                • 440
                                • Serbia
                                #55
                                So, there are indeed various experinces with Nichicons, even the datecodes sometimes do not denote a stable/quality build. Of all those Japanese capacitor manufactureres, I've never read anything bad about Rubycons, they seem to be a very reliable brand.
                                It is amazing how many motherboards and their brands used these Nichicon series even though there were serious mistakes involved in their production, but MB makers still continued using them. I guess production costs are taken into account here, but it is simply a bad idea to design a solid and quality electronic equipment only to risk its destruction but putting some problematic capacitors on it.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  #56
                                  Well, if you read around badcaps.net, you will see that Rubycon isn't all problem-free either. In particular, their MCZ series are not very tolerant of high heat and will often bulge. Also, their MBZ series seem to have had a little "oopsie" too. Have a look in this thread:
                                  https://www.badcaps.net/forum/showth...&highlight=mbz
                                  Despite that, I still consider Rubycon high quality, though.
                                  Now, some may argue that Panasonic is the best as it seems like they haven't had any failures with any series. And while that may as well be true, their series with lowest ESR are FL and FJ. But these aren't quite as low ESR as Nichicon HN/HZ or Rubycon MCZ/MFZ, so that's also to keep something in mind. Also, in my experience, some Panasonic caps (particularly FL) have had very soft rubber bungs on the bottom. Nothing wrong with that until you accidentally heat the cap just a little more when soldering/desoldering. And then the next thing you notice is the cap is leaking electrolyte from the bottom. This happened to me with a few Panasonic FLs I removed from some P4SD motherboards.
                                  Therefore, I don't really consider Nichicon any worse than the above. Sure they did have problems with their 2001-2004 HM and HN series (and possibly HZ?) as well as some from 2005. But outside of that, they have had good history as reliable caps.
                                  Chemicon is the same way too. Though it looks to me that they still haven't (and probably won't) fix their problems with their KZG and KZJ series (and possibly TMZ). But their other series are excellent! So I use Chemicon in repairs quite often too.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #57
                                    I wouldn't doubt them but considering these reports…got Gigabyge GA-K8NF9 Ultra. Full of HM (or HN? don't remember now) made somewhen in 2005. There was reportedly one bad cap, replaced with some PoS from local store, I replaced it with some used Panasonic (FL IIRC). PSU was bloated, I've recapped it, but it ceased working - replaced with another recapped one. But board keeps behaving strangely - sometimes got 0x0000009c error, it often does not even POST. Different graphics - same behaviour. RAM after 24+ hours in Memtest86+ OK.
                                    I remember that measuring the CPU VRM, all the caps together measured way more than their nominalxnumber of caps is. May be they are leaking? Should I try to replace them? Or just the nForce 4 is dying…
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      #58
                                      I can't say for sure. Pull a few and measure them out of circuit. If they aren't too high in capacitance, they are probably okay. If you have the caps, you might as well try and replace all of them. If it fixes your problem, perhaps they were going bad indeed.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #59
                                        I've tried to artifically heat the NB, it showed same behaviour - most likely bad BGA or die soldering. Will try to heat it with hot air gun and and add a fan on the heatsink, that's all I can do, otherwise it will go to electro-scrap.
                                        • UserXP
                                          • Apr 2012
                                          • 440
                                          • Serbia
                                          #60
                                          LOL, having checked the link, it turned out that I've actually read that Topcat's article before, but it was quite a while ago, so I forgot. Thanks for the reference.
                                          It was probably, like Topcat said, a bad batch or something. I have put MBZ caps on this S478 board of mine, their dates are from 2002 (the 6.3V, 3300uF ones), 2003 (the 16V, 1500uF ones) and 2005 (the 6.3V, 1000uF ones). Here is the board still working flawlessly every day.
                                          No matter how good the electrolytic mixture is, the heat will always be its downfall, I guess. In general, I've never had problems with any of the Rubycons myself, so I still consider them to be highly reliable caps. The problem is that they (and others as well) are very hard to come by in my country.
                                          • DrewPhillips
                                            Capacitor Diarrhea - Nichicon PL Series
                                            by DrewPhillips
                                            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                            03-02-2025, 10:18 PM
                                          • nick3092
                                            Mid/late 80's Nichicon Yellow Caps
                                            by nick3092
                                            I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                            08-28-2022, 03:56 PM
                                          • chth96
                                            Is there datasheet for nichicon LXJ series?
                                            by chth96
                                            I want to calculate capacitor ESR referring to below guide.
                                            https://forum.digikey.com/t/calculat...-from-tan/2633
                                            I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                                            I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                                            Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                                            11-20-2022, 08:11 AM
                                          • chth96
                                            Is there any datasheet for nichicon RT(M) series?
                                            by chth96
                                            A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                                            https://www.badcaps.net/forum/troubl...e-been-blew-up
                                            and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                                            But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                                            I have spare console...
                                            11-28-2023, 03:36 AM
                                          • redwire
                                            Exploding motor cap on Ryobi electric pressure washers - product recall
                                            by redwire
                                            Exploding motor cap on Ryobi electric pressure washers.
                                            Recall is for 764,000 units and 16,000 sold in Canada.
                                            "TTI Outdoor Power Equipment has received 135 reports of capacitors overheating, including 41 reports of explosions, resulting in 32 injuries and/or fractures to the fingers, hands, face, and eyes."
                                            Broken bones? Shrapnel In your face? Never reach for the on-off switch, just run away!
                                            Found this pic on Reddit, cap looks like a plastic housing electrolytic? with big rubber bung at the end.
                                            Safety vent too expensive! DELETE DELETE
                                            08-31-2025, 11:03 AM
