I've got a TV board with the bad caps. The data on them are as follows:
CapXon 1000uf 10v 105c P727
I ordered some replacements with the following data:
Sanyo 1000uf 10v 105c S.E.83 WG
My question is the Sanyo's are about a third smaller than the CapXon caps that are bad. Will I be ok to use the Sanyo's or should the physical size match as well?
Thank you
Thank you
