Replacement for Rubycon MCZ Caps ??
  • Pipkin
    • Mar 2015
    • 8
    I'm needing to replace some caps on a motherboard from our Dell Server.
    It's about 10yrs old, and initially I thought it was going to be one of those 'capacitor plague' issues that I read Dell had problems with.
    But... on closer inspection, I find that Dell had used Rubycon MCZ caps on the board, which after reading on this forum, I understand are deemed to be 'GOOD' caps ?
    So I'm guessing it's just the age of the cap that has been the problem. The server will have been on 24/7 for the best part of ten years, so I can't complain !
    Anyway - can anyone suggest a suitable replacement for the following caps please ?? As I understand that Rubycon have stopped making the MCZ series ? I found some on ebay, but I'm worried they are either fake, or old stock ?
    Rubycon MCZ 16V 1000uF ( MB has 4 of)
    Rubycon MCZ 6.3V 2200uF ( MB has 31 of)
    Rubycon MCZ 6.3V 1800uF ( MB has 14 of)
    Rubycon MCZ 6.3V 1500uF ( MB has 2 of)
    Rubycon ZL 6.3V 220uF ( MB has 4 of)
    Rubycon YK 16V 220uF ( MB has 2 of)
    The only caps showing physical signs of failure are the 2200 & 1800 devices. About 8 of these are 'gone'. Do you generally replace all the caps including the OK looking ones ?
    I had a look on farnell, and searching for Rubycon 6.3V 2000uF returned the following ...
    ZLH Series
    ZL Series
    YXG Series
    YXF Series
    Would any of these be OK ?
    Many Thanks to you all
    • 31289
    Re: Replacement for Rubycon MCZ Caps ??
    mcz are some of the best, i would only replace them with poly's
    • Pipkin
      • Mar 2015
      • 8
      OK .....
      So can you point me in the direction of a suitable 'poly' series I should be looking at ?
      Thanks for your help
      • retiredcaps
        • Apr 2010
        • 9271
        Rubycon MCZ are good caps.
        Running 10 years at 24x7 = 87,600 hours.
        See this post
        https://www.badcaps.net/forum/showpo...4&postcount=10
        So if your server was running around 55C internally, the MCZ cap life would be around 64,000 hours.
        --- begin sig file ---
        --- end sig file ---
        • Pipkin
          • Mar 2015
          • 8
          See this post
          Thanks for that info. It's good to know that Dell didn't cut corners with the caps then - it might explain why the server cost so much more than a PC does !
          So that leads me to the question of replacement... Are the MCZ caps still available, and if so, where can I get hold of some genuine ones ?
          Or... have Rubycon replaced them with an improved series ?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            No, all these highend electrolytic caps have been replaced in new designs with solid polymer caps, and thus the large manufacturers have stopped manufacturing electrolytics with ultra low ESR.
            The reason you see such high capacitance rating in most VRM designs is because the larger the cap the lower it's ESR is, and that is what the board designer is after.
            A high frequency VRM does not need allot of capacitance, due to it's high switching speed what it needs is ultra low ESR.
            Thus it is fine to replace the caps with polymers of significantly lower capacitance.
            But we need to see where they are used, because this only applies to the kind of regulators I have described.
            Can you post some pics of the board, I'm guessing there are allot of caps but only those in high-stress VRM positions will have failed...
            https://www.badcaps.net/forum/showthread.php?t=13542
            https://www.badcaps.net/forum/showthread.php?t=21540
            • retiredcaps
              • Apr 2010
              • 9271
              MCZ was discontinued back in 2010. I believe Nichicon HZ meets or exceeds the ripple and ESR specs of the MCZ. You can compare yourself using the datasheets linked below.
              http://www.thecapking.com/spforrumcz.html
              Badcaps store sells Nichicon HZ.
              https://www.badcaps.net/pages.php?vid=23
              • Pipkin
                • Mar 2015
                • 8
                Thanks for all your help :-)
                I've taken the server apart again, and snapped a few photos.
                I've also done an 'overview' shot and then highlighted the eight caps which have obviously gone.
                Any advice greatly received ...
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Unless you have an ESR meter to test the remaining non MCZ bloated caps, I would say the remaining caps are suspect.
                  Unless you have an absolute need to put this motherboard/server back into service, you might be better off getting a replacement?
                  • mariushm
                    • May 2011
                    • 3799
                    Those by the cpu sockets you could replace with polymer capacitors rated for 4v... the actual voltages are much lower in reality so that would be perfectly fine.
                    You can probably use 1500uF 4v capacitors instead of the 2200uF ones and 1000-1200uF ones instead of the 1800uF capacitors.
                    Those capacitors by the chipset and other locations further away from the cpu sockets, you can go with series of capacitors that are close enough to the old Rubycon series, the motherboard won't be that picky about what you use.
                      • 31289
                      seems a waste only half-loading it, get a second cpu!
                      • Pipkin
                        • Mar 2015
                        • 8
                        We need to have this server in operation at the moment. It is running with the caps as they are now - we spotted them during a routine clean of the server today.
                        I want to do something about them, before they become a bigger problem - hence why I'm looking for replacements.
                        • Pipkin
                          • Mar 2015
                          • 8
                          And load up the already stretched power supply some more ??
                          • Pipkin
                            • Mar 2015
                            • 8
                            So I should be OK to use 'Nichicon HZ' for the ones not near the CPU socket ?
                            What series of polymer caps should I be looking at for the CPU ones ?
                            I haven't used polymer caps before.
                              • 31289
                              you may want to check the caps in the psu.
                              a good excuse to blow the dust out of it.
                              • black6host
                                Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                by black6host
                                Good day!
                                I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                I'm going to replace the caps and I'll be the first...
                                02-06-2024, 08:22 PM
                              • rewease
                                Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                                by rewease
                                There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                                Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                                Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                                09-17-2023, 12:53 AM
                              • HectoPascal
                                Replacement caps ok? (smoothing caps, PSU heating controller)
                                by HectoPascal
                                Hallo,
                                i want to replace two smoothing caps from a heating controller PSU. They are probably 30 years old and it might be time to replace them.
                                SXE 470uF 63V 105°C (tested: 472uF 0.35Ohm) --> Nichicon VY 105°C - 463uF 0.15Ohm
                                SXE 470uF 25V 105°C (tested: 422uF 0.63Ohm) --> Samwha K5A 85°C - 446uF 0.10Ohm (or Panasonic RAD FC 470/25 8mm)
                                I couldn't find anything about 'SXE'. That's the only declaration on the caps. Edit: The top/bottom ident says Nippon CC.
                                Nichicon should be 'VY' series (linked).
                                I couldn't find anything about Samwha...
                                09-06-2023, 08:30 PM
                              • kahlil88
                                AOpen MX36LE-UN which replacement caps?
                                by kahlil88
                                Just got a computer with this board and ALL of the Lelon RXA caps have failed. Having trouble finding datasheets to match against potential replacements. The caps in question are 7x 1500uf 6.3V 10x20 and 11x 1000uf 6.3V 8x12. Open to replacing with polymers as long as it works.
                                10-23-2025, 03:14 PM
                              • Techboxcomputer
                                XBOX One S caps value and replacement
                                by Techboxcomputer
                                Hi -
                                I saw there was another post similar to this, but I do not believe he was referring to the same caps I am seeking.
                                These caps are in the “B” section of the board and the board is marked C9C11, C9C4, C988. The caps appear to be aluminum sheathed and are marked “FP 95 CD 271 16” The Digikey tech's best guess was Nichicon 16v 271 uf but I don't want a guess and solder in the wrong cap. Do any of you know exactly the value of these caps and a good replacement for them?...
                                12-21-2022, 08:35 AM
