Need help identifying Green Ceramic Capacitor in Yamaha DX7IIFD
  • steamed_hams
    • Dec 2014
    I need help repairing my Yamaha DX7IIFD keyboard. I was installing the E! Grey Matter Response card, and I had to pry out the IC23 chip. While doing so, I heard a crack. When I looked down, I had saw that I broke an internal piece by accident!
    http://imagizer.*************/a/img540/6044/bZxvvx.jpg
    It's a ceramic disc capacitor that says "16x 104m" on it. It's listed in the service manual as part C33 on the DM board, but it doesn't list the name as far as I can tell. I need to know the specific name of this component so I can find a replacement ASAP if it's even possible any more.
    I know 104m is 0.1uf with +/- 20% tolerance, but I don't know what "16x" means. I can't find the exact match for this capacitor, just orange capacitors that just say "104". Another site I asked this on said the capacitor will still work fine with the chip, but I don't believe that at all. It's significantly damaged. Other sites have said that any voltage 0.1uf capacitor should work, but none of those people were certified professionals.
    • 31289
    Re: Need help identifying Green Ceramic Capacitor in Yamaha DX7IIFD
    it's just for the logic power,
    any 0.1uf ceramic will do as long as it fits.
    i'd use a milti-layer ceramic, they are smaller.
    or an axial multilayer ceramic even.
    you should be able to find what you need on anything with digital chips on it.
    you can even use surface-mount ones.
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      Actually the advice you've gotten is ok.
      Any .1uf cap of sufficient voltage rating will work. That's probably a 100v or higher cap judging by the size.
      The 16x might indicate the voltage rating but I'm not familiar with that way of marking. That's a digital synth so the voltages used by the chips is going to be pretty low, probably 5v.
      The cap may actually still work as it is believe it or not. It looks like only the edges of the plates got dinged and unless they are shorted together it probably is still about .1uf. I'd replace it anyway though, the exposed plates will corrode in time.
        http://pdf1.alldatasheet.com/datashe...BA/TC5564.html
        5V RAM IC, so anything above 10V will be fine as long as it fits the foot print.
        • chth96
          by chth96
          03-09-2024, 10:03 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • NuclearSpartan
          Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
          by NuclearSpartan
          I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
          The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
          I don't see any other visible damage anywhere else on the board....
          11-14-2024, 02:32 PM
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • rictechie
          smd ceramic capacitor use in iphones
          by rictechie
          is there a brand of smd ceramic capacitor use in iphones? or they are generics
          07-26-2024, 08:28 PM
