polyethylene????
  • cornflake
    • Jul 2007
    • 8
    polyethylene????
    Does anyone know if polyethylene is static safe enough for motherboard work? I was tinkering around with some ideas for making a cheep but useful motherboard holder for recaping. I have this polyethylene tubing used to insulate hot water pipes. It comes in tubes with a slit down it's length that snaps nicely over the pipe. It seems to me it could snap just as nicely around the edges of a motherboard to protect it while being held by whatever is being used to hold it up without getting in the way of the work... If it isn't a static hazard that is...
    any ideas?
    Better to have it and not need it...
    than to need it and not have it!...
  • Logistics
    • Apr 2007
    • 721
    Re: polyethylene????
    ............................................________
    ..............?.....__.........................................:............./
    ............./__.(.....“~-,_..............................,:............/
    .........../(_....”~,_........“~,_....................,:.........._/
    ..........{.._$;_......”=,_.......“-,_.......,.-~-,},.~”;/....}
    ...........((.....*~_.......”=-._......“;,,./....../”............../
    ...,,,___.....~,......“~.,...........................}............../
    ............(......=-,,.................................(......;_,,-”
    .................~.*-,.....................................|,./.......,__
    ,,_..........}.>-._.....................................|................=~-,
    .......=~-,_.._..........,...................................
    ..................................:,,.............................................__
    ........................................_............._,-%...........
    ...................................,<...._|_,-&........................
    • Logistics
      • Apr 2007
      • 721
      Hint: Polyethylene is a dielectric.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        can you cut the new members a little more slack please
        • 999999999
          • Sep 2006
          • 774
          While polyethylene is a reasonably good insulator, that's somewhat the opposite of what one wants to prevent ESD damage. For example, polyethylene ESD protective bags are forumulated to conduct, the polyethylene is just a convenient way to make a bag that still needs some megaohn range conduction.
          You wouldn't want to slide the material across the board, it may generate a charge in that case. snapping it onto the edge of a board probably won't generate any charge enough to matter.
          • Fizzycapola
            • Oct 2006
            • 423
            Indeed. Agree. Sometimes people don't like to be made fools of for simply asking honest questions, because you know 16 bytes of information doesn't mean someone else used their 16 bytes of storage for the same thing.
            Cool text picture Logistics.
            As I remember I usually put things straight into cases and then decide next phase, maybe plain old desks are best, special equipment who has time for it, plain white bottom of the range non coated 80gsm paper has done me ok so far also.
            [and now to finish my tapping on these cheap plastic buttons ... comedy with the punchlines and timing removed just to be annoying ...]
            Us poor internet people, how are we meant to know anything, for a start we never attended school or achieved qualifications, thats how we all wound up on the internet, how I'd like to go back to the world where the internet was never invented, where you saw flowers AND you could smell them and women didn't ask whether you "Want to go private?" even though they can't even see you.
            Rubycon Rubycon Rubycon
            • spice_disc
              Vizio TV M50-C1 reboot cycle and static on screen
              by spice_disc
              I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
              The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
              09-08-2024, 02:37 PM
            • Leebo249
              SA-HD52 1 Default Crosstalk/static after replacing selector switch IC?
              by Leebo249
              Hey,
              A month back I replaced the selector switch IC on my Panasonic SA-HD52 as the radio was still playing when I selected the CD, it did this with the tape and record too.
              Now when I replaced the IC it worked perfectly, no cross talking and I left it at that for a month and have come to it today to play a CD (you can hear it spinning) and the issue has come back although with another issue.
              Both issues are random, the original problem where the radio will play over other playbacks has come back and another time you turn it on it will refuse to play anything,...
              09-07-2025, 07:23 AM
            • mon2
              Crate guitar amp with extremely loud static on power on (no input)
              by mon2
              Hi. Not our mainstream line of work - we work with digital mostly. Will study the schematic found on the internet. The output darlington transistors appear to be ok. Even with no input, the output is extremely loud with static / crackle / pop. Any ideas? Will post more details and fix as we continue the review. Have not checked the main power supply rails yet (+-40V and +-16V).
              07-18-2025, 06:40 AM
            • diggitt
              Radio, no stations, quiet static sound
              by diggitt
              I am repairing a DeWalt DC011 radio. I found that the secondary coil of the transformer had gone open circuit and the amplifier ic had shorted. I have replaced both but I can’t tune it in to a station and the static is very quiet. Any help is greatly appreciated. Thank you
              04-14-2025, 05:06 AM
            • EazyBone
              LG 75UH8500 color static frozen
              by EazyBone
              Got a LG with color static frozen. Doesn't move just stays on this picture. I'd assume it's main board but I'm sure one of you has seen this before. Any data helps thanks...
              06-10-2024, 09:35 AM
