Caps replaced, still a problem!?
  • Shimen
    • Jul 2007
    • 16
    So 14 caps got replace on my Gigabyte Ga-7DXR mobo. The comp is working wonderfully better than it did when i got it. Replacing them solved a lot of my issues with stop errors program crashes and so forth. There was also one other problem i was having that i blamed on the caps. And that was my Optical drives not working. In particular The newsest one i have a Sony DRU-830A. Ok so heres the deal. The drive recognizes when Audio CD's or program disc not on a dvd cd. So here is my major problem this drive supports everykind of dvd data there is from +r, -r, +rw, -rw, +r dl, -R dl, -ram, plus all the cds, cd-rw, cd-r, cd-rom, and also dvd-rom. The drive does not recognize any of the dvd type discs none of them. Ive tried everything i know from updating firmware, to changing IDE cable, Different IDE locations on the mobo, Slowing it down and speeding it up. Iv uninstalled and reinstalled so many times that i think im gonna go nuts. Can anyone give me a bit of insite please. Some specs
    GA-7dxr Motherboard (gigabyte)
    System Information
    Time of this report: 7/26/2007, 23:17:36
    Machine name: HOME
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
    Language: English (Regional Setting: English)
    System Manufacturer: GBT___
    System Model: AWRDACPI
    BIOS: Award Modular BIOS v6.00PG
    Processor: AMD Athlon(tm) XP 1800+, MMX, 3DNow, ~1.6GHz
    Memory: 768MB RAM
    Page File: 309MB used, 1567MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.2600.2180 32bit Unicode
    DxDiag Notes
    DirectX Files Tab: No problems found.
    Display Tab 1: No problems found.
    Sound Tab 1: No problems found.
    Music Tab: No problems found.
    Input Tab: No problems found.
    Network Tab: No problems found.
    Disk & DVD/CD-ROM Drives
    Drive: C:
    Free Space: 33.3 GB
    Total Space: 38.2 GB
    File System: NTFS
    Model: ST340016 A SCSI Disk Device
    Drive: D:
    Free Space: 38.2 GB
    Total Space: 57.2 GB
    File System: NTFS
    Model: WDC WD60 0BB-00CAA1 SCSI Disk Device
    Drive: E:
    Model: SONY DVD RW DRU-830A SCSI CdRom Device
    Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 08:00:00, 49536 bytes
    System Devices
    Name: Creative AudioPCI (ES1371,ES1373) (WDM)
    Device ID: PCI\VEN_1274&DEV_5880&SUBSYS_20001274&REV_03\3&61AAA01&0&70
    Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/3/2004 20:56:44, 4096 bytes
    Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/3/2004 20:56:58, 130048 bytes
    Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/4/2004 08:00:00, 140928 bytes
    Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 19:08:00, 60288 bytes
    Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 19:15:50, 145792 bytes
    Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/4/2004 08:00:00, 48640 bytes
    Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 08:00:00, 23552 bytes
    Driver: C:\WINDOWS\system32\drivers\es1371mp.sys, 5.01.2501.0000 (English), 8/17/2001 08:19:34, 40704 bytes
    Name: SMC EZ Card 10/100 PCI (SMC1211TX)
    Device ID: PCI\VEN_1113&DEV_1211&SUBSYS_12111113&REV_10\3&61AAA01&0&60
    Driver: C:\WINDOWS\system32\DRIVERS\RTL8139.sys, 5.398.0613.2003 (English), 8/3/2004 18:31:34, 20992 bytes
    Name: VIA Power Management controller
    Device ID: PCI\VEN_1106&DEV_3057&SUBSYS_30571106&REV_40\3&61AAA01&0&3C
    Driver: n/a
    Name: VIA Rev 5 or later USB Universal Host Controller
    Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_16\3&61AAA01&0&3B
    Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/4/2004 08:00:00, 20480 bytes
    Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 08:00:00, 142976 bytes
    Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/3/2004 20:56:48, 74240 bytes
    Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 08:00:00, 57600 bytes
    Name: VIA PCI to ISA bridge
    Device ID: PCI\VEN_1106&DEV_0686&SUBSYS_00000000&REV_40\3&61AAA01&0&38
    Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/4/2004 08:00:00, 35840 bytes
    Name: VIA Bus Master Ultra ATA Controller
    Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_05711106&REV_06\3&61AAA01&0&39
    Driver: C:\WINDOWS\system32\DRIVERS\viadsk.sys, 3.01.0001.0000 (English), 11/15/2000 11:01:00, 49644 bytes
    Driver: C:\WINDOWS\system32\VIAIDE2K.dll, 11/15/2000 11:01:00, 32768 bytes
    Name: Multimedia Audio Controller
    Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_00511102&REV_03\3&61AAA01&0&78
    Driver: n/a
    Name: Promise Technology Inc. Ultra IDE Controller
    Device ID: PCI\VEN_105A&DEV_0D30&SUBSYS_4D33105A&REV_02\3&61AAA01&0&80
    Driver: C:\WINDOWS\system32\DRIVERS\ultra.sys, 1.00.0507.0001 (English), 8/4/2004 08:00:00, 36736 bytes
    Name: AMD-761 Processor to AGP Controller
    Device ID: PCI\VEN_1022&DEV_700F&SUBSYS_00000000&REV_00\3&61AAA01&0&08
    Driver: C:\WINDOWS\system32\DRIVERS\AMDAGP.SYS, 5.02.0002.2195 (English), 8/3/2004 19:07:44, 43008 bytes
    I should mention that after i replaced caps i did a fresh install of windows. As to well Start over on a good note. So any thoughts.
  • Sparky
    High voltage
    • Jan 2007
    • 234
    Re: Caps replaced, still a problem!?
    Different drives doesn't help any?
    Might be the IDE controller is malfunctioning.
    • Shimen
      • Jul 2007
      • 16
      Nope the other drive i have is a cd-rw drive and it works fine after the re capping and fresh install. And this drive works great aside from the dvd part of it. I thought it might have been the IDE cont. also but assumed that i would be having problems with all types of media and not just one. But then again i could be wrong ive heard of electronics being picky!!
      • Rainbow
        • Aug 2005
        • 1375
        If the drive doesn't read DVDs, it's bad.
        • Shimen
          • Jul 2007
          • 16
          You know every forum ive been in seems like people are so up on jumping on the DRIVE IS BAD wagon. As i mentioned in my post before.... Drive works perfectly fine on another computer. Meaning no issues no problems ready and writes all media types........
          • shadow
            • Feb 2007
            • 732
            My next move in solving this problem is to use another Operating System and see if it works on that same computer. I would use a live Linux distribution (just so you do not have to install it, just run it from the CD). If you still can not read DVD's even from Linux, then you can rule out a software fault. That would at least narrow it down to either hardware or BIOS fault.
            Hope I gave you some idea's.
            • Shimen
              • Jul 2007
              • 16
              Ahhh ok i will give it a shot and get back to you. I have to get ahold of a buddy thought so it might take me a min or two. Just curious if ive ruled out the possibility of the drive itself being bad what else am i looking at when it comes to hardware failure. Also would it be fixable. And would the bios fault be fixable if it turns out that would be the problem. thanks
              • shadow
                • Feb 2007
                • 732
                With regards to the BIOS....it would most likely be some weird setting somewhere in there. It is extremely unlikely to be faulty since your computer works just fine. Did you try to clear the BIOS settings at all? If it is a BIOS setting that is screwing it, then that should fix it up.
                Needless to say the problem should not be there, however you never know. Clearing the BIOS settings will most likely just add to the things that you tried.
                • Harvey
                  • Apr 2007
                  • 264
                  Where did you mention that? All I see is that it can still read CDs and that your other drive works fine.
                  DVD drives have two laser units in them, one for DVD media and one for CD media. The symptoms you describe (being able to read CDs but not DVDs) suggest the DVD laser has failed.
                  • Shimen
                    • Jul 2007
                    • 16
                    Ah well sorry harvey i thought i put that in my original post. But yes the drive works fine in other computers. And Shadow i have cleared my cmos (used the jumper).
                    Alright and now the drive has stopped recognizing audio CD's. So now im down to the drive only recognizing programs discs. So anymore thoughts.
                    • Logistics
                      • Apr 2007
                      • 721
                      Did you try flashing the BIOS to the newest version? I know you said you updated the firmware, but to me that refers to the optical drives' firmware.
                      • Shimen
                        • Jul 2007
                        • 16
                        Yes i did both the drives firmware and flashed bios to the newest version.
                        • Harvey
                          • Apr 2007
                          • 264
                          When you say "stopped recognizing" - does the drive make any attempt at spinning the disc when you put one in? How about if you try the drive without an IDE lead connected and powered up from a cold start (to rule out something in the BIOS doing strange things to the drive)?
                          A very strange issue....
                          • Sudum Gumudu
                            • Sep 2005
                            • 97
                            Hi.
                            You didn't by any chance happen to have installed any game protected with Starforce.
                            That malware copy protection is known to screw with optical drive units.
                            More to be read at www.glop.org/forum/viewforum.php?id=11
                            SG
                            • osrex
                              LED DRIVER KEEPS DYING
                              by osrex
                              Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                              i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                              i have no datasheet at all for the LED lights, all i have is its length.
                              long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                              as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                              05-05-2025, 03:36 PM
                            • Sileeth
                              Remanufactured GTX 650Ti Resets and Driver problems.
                              by Sileeth
                              Hi!!! Nice Day/Night
                              I bought a GTX 650Ti on Aliexpress, that could be the first problem... I think the card was built in a custom build version because it has 4 GB DDR5 of 2700 MHz memory (According to all programs except GPU-Z).
                              With GPU-Z everything is fine except the value of the memory frequency, the software says that the memory frequency is 1350 MHz with reference to the original models of this graphic card.
                              After opening the package, I disassembled the cooler and checked all the parts and the most important one, the GPU processor. Everything...
                              05-26-2022, 07:12 AM
                            • howardc64
                              Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                              by howardc64
                              Problem
                              Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                              Model & Board Pics
                              Conflicting Spec
                              Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                              https://www.shopjimmy.com/vizio-gj-2k1...
                              10-10-2024, 01:16 PM
                            • charif
                              Audio Driver for Thomson P14C4BK128
                              by charif
                              Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                              I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                              The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                              Here are the details:
                              • Model: Thomson P14C4BK128
                              • Operating System: Windows 10 64-bit
                              If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                              Thanks in advance for your help!
                              04-30-2025, 05:41 PM
                            • bohaboha
                              how to install gl usb2.0 uvc camera device driver on windows 10
                              by bohaboha
                              Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                              but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                              any help?
                              01-26-2025, 08:33 PM
