dc7800 - motherboard bad capacitors
  • buran
    • Aug 2014
    • 5
    • Slovenia
    I am interested if you could share your opinion if these capacitors (and circumstances) could be the cause of my motherboard malfunction. I have installed new more powerful graphic card and the motherboard went "dead" (fans spin on then go off, 4 short beeps then pause cycle).
    After looking in more carefully i've noticed a dozen (13 - 470 uF 16V exactly) mildly cap and bottom bubbled and capacitors, some of them even show sign of leak.
    Is it possible that the new more powerful card pulled a bit more power and helped them in their final breakdown.
    Here are some nice pictures.
    Share your opinion
  • selldoor
    Slow Learner
    • 7870
    Re: dc7800 - motherboard bad capacitors
    Capxon KF ? - Notoriously bad - I will let the motherboard gurus suggest replacements
    • buran
      • Aug 2014
      • 5
      • Slovenia
      Last night i did pulled out some capacitors I`ve seen capacitors in worse condition but these are interesting too. Will post some funny pictures later on.
      • c_hegge
        • Sep 2009
        • 5219
        It is entirely possible that the caps are your problem. I can't tell from the pics what the voltage and capacitance ratings are, but something on this list (https://www.badcaps.net/pages.php?vid=23) should do fine.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          CapXon KF? Looks like someone recapped this board before you as I don't recall any Intel boards using CapXon caps.
          Also, it looks like those CapXon KF caps have leaked electrolyte on the board. Electrolyte can eat away traces over time. So I suggest you remove them immediately and thoroughly clean the affected areas on the board with IPA (isopropyl alcohol), preferably 95% or higher.
          The caps on c_hegge's list should work fine. Panasonic FR/FM, as well as Nichicon HD, Chemicon KZE, and Rubycon ZL/ZLH/ZLG/ZLJ should be fine as well since the caps in question look like general filters for the PCI-E slots.
          • Farhan9
            • Jan 2017
            • 3
            • Pakistan
            I want deatils DC 7800 all Capacitor picture
            • dragon3x
              After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
              by dragon3x
              Hi, I have some 32 bits computer motherboards that need repair, as they fail to
              power on.
              Here are some examples :
              (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
              switching supply area).
              (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
              than 6.3 V.)
              1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
              I replaced capacitors with aluminum-polymer.
              3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
              03-21-2025, 02:46 PM
            • stanwebber
              did bad capacitors kill my motherboard or prolonged exposure to faulty psu?
              by stanwebber
              i've got a pretty rare motherboard that i'm evaluating for repair. it's a biostar m7mia-raid which is the only ddr socket a motherboard ever produced, consumer or industrial, with an isa slot. its 20 years old now and finally gave up the ghost last month. i was saving a dd image of the hdd to a portable usb drive when i found it unresponsive with a black screen and a solid lit hdd led. after forcing it to power down it never posted again. the psu/cpu/case fans will spin and the onboard motherboard power led will light up, but no beeps or error codes even with the cmos reset and ram plus all expansion...
              03-10-2022, 12:35 AM
            • varkatope
              Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
              by varkatope
              Hey there, retro fans.
              I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
              12-15-2024, 09:48 AM
            • glovecaps
              Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
              by glovecaps
              I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
              My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
              The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
              11-25-2024, 04:23 PM
            • Docus
              Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
              by Docus
              Hi everyone 😀,
              I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
              To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
              Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
              1. I already own the exact same model, but its plastic chassis is badly damaged.
              06-10-2025, 04:24 PM
