Update: Low ESRs from JayCar (Aust & NZ) don't last
  • nzo
    • Jul 2007
    • 6
    The caps I sourced from JayCar in Auckland were installed 2 years ago for my first Soltek 75KAV mobo, and 1 year ago for the second.
    Both mobos now exhibit slight bulging and leaking.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Update: Low ESRs from JayCar (Aust & NZ) don't last
    pics?
    what brand of caps are they
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Jaycar in Australia used to sell Samxon GF, green colour sleeve, in the 1000uf 10v and 2200uf 10v, which were the ones I needed
      Now they offer Suntan brand, black colour sleeve, which don't look as good quality
      Suntan bungs on bottom are flat, look similar to poor quality brands like GSC and CHSSI, whereas Samxon bungs have sculpted shape like decent quality Japanese brands
      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
      • nzo
        • Jul 2007
        • 6
        The ones I bought from them are Suntan brand, although their online catalog shows pics of Samxon brand (see pic). Maybe they've changed brands. They assured me that Suntan caps would do the job nicely.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          I can't speak as to the quality of Suntan brand. However, I've never had any problems with Samxon. I've had some Samxon caps in a testing environment for over a year now, in lets just say less than ideal conditions, and they're holding up well.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • nzo
            • Jul 2007
            • 6
            That's interesting Topcat. Is your test circuit easily replicated, as in DIY? Do you mind sharing?
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              https://www.badcaps.net/forum/showthread.php?t=2179
              thats the public test.
              The ones I'm primarily referring to are in PC PSU's. The most notable is an Aopen microATX PSU, which is very small and gets very hot. I use that system daily, have been for over a year, no issues. It's recapped with Samxon GA and GC series caps.
              Team : 49813
              Join in!!
              Team Stats
              • nzo
                • Jul 2007
                • 6
                Very cool Topcat. The ole power supply torture test
                BTW, I've sent a bunch of info on conductive polymer aluminum solid caps to JayCar and their purchasing dept. Hopefully they'll be stirred enough to look into stocking them.
                • tazwegion
                  • Jun 2006
                  • 444
                  I found the same thing when searching locally for Low ESR capacitors, the local Jaycar rep' tried pushing those POS Suntans when all I was asking for was Samxon
                  FWIW I can further confirm Samxon quality as I've used them almost entirely to recap a number of motherboards (with the exception of some EXR Hitanos & FJ Pannys) & PSU's all still in use as 24/7 F@H rigs
                  If your attempt to get Jaycar's purchasing dept. educated doesn't succeed, it may be worthwhile contacting Big Pope of these forums and arranging something between you RE: Samxon GA/GC series
                  Viva LA Retro!
                  • nzo
                    • Jul 2007
                    • 6
                    Here's one link to a new solid cap manufacturer:
                    BS Technics
                    • akwky
                      by akwky
                      Hi!
                      04-14-2025, 01:56 PM
                    • TheUser
                      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                      by TheUser
                      Hello to everyone ,
                      This is my first post here, and i would like to share with you a small story in case you can help me.
                      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                      02-10-2024, 02:07 PM
                    • lordgeny
                      z490-f gaming bricked after bios update
                      by lordgeny
                      I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
                      11-02-2023, 09:03 AM
                    • iMuhtaseb
                      A1706 2017 critical update
                      by iMuhtaseb
                      this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
                      we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
                      One weird symptom is it takes too long to power on and show the Apple logo for some reason..
                      I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
                      08-13-2024, 08:41 AM
                    • al3m0di
                      Update bios EFCN58WW to EFCN59WW
                      by al3m0di
                      Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                      I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                      The BIOS version is EFCN58WW.
                      When I turn on the device, it displays the message:
                      "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                      The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                      I've tried
                      07-29-2024, 10:32 AM
