powering up old unused electrinics equipment
  • paulmars
    • May 2011
    • 31
    • usa
    I remember in electronics school in the 1980s we learned that the
    best way to damage a very old piece of electronic equipment was to
    power it on with full voltage. After a long time with no power caps
    go to zero ufd, which will pass the full voltage and burn out other
    components. Something like that. Im looking on the internet for
    info about this, but I cant find any. Do you know of any?
    tks,
    pa
  • tjg79
    • Sep 2013
    • 49
    Re: powering up old unused electrinics equipment
    Take the cover off, plug it in and watch the circuit board carefully. If you see smoke, unplug it, investigate the issue and try again.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5038
      • New Zealand
      No, the leakage current of the capacitors can increase. Often they can be re-formed. If the capacitance dropped to zero, it would be shorted or open circuit.
      How old is the equipment you want to power on? If the capacitors are ancient (like Valve-era) you should remove and test them first - those ones are most likely to explode if unused for decades
      -David VanHorn
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Do you really need to know? have you something you want to start up?
        Try on antique radio .com? or google electrolytic capacitor shelf life
        assuming you are not talking wax and paper in which case antique radio may
        be the way to go.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          DONT PLUG IT IN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          unless its from the 80s, then go ahead.
          Follow the white rabbit.
          • paulmars
            • May 2011
            • 31
            • usa
            its late 1970s and has need seen power for at least a decade.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5038
              • New Zealand
              What is it? Have you had a look inside yet for any obviously visible issues?
              If you want to be on the safe side, test or replace any big electrolytic filter capacitors and any other high voltage ones. Low voltage ones should be OK to leave as is.
              -David VanHorn
              • Heihachi_73
                • Jun 2012
                • 713
                Late 70s would basically cover "80s" as far as electronics goes.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  i wouldn't say that. i have had two radios made in the 70's pop the filter, one of which cut a gash in my arm about half the length of a lighter. all the 80's worked and didn't blow up.
                    master hoarder
                    • May 2008
                    • 12175
                    If it's old stuff (but not super old like tube stuff), I say it depends if the caps have safety vents or not. If no safety vents, be careful!
                    • valvashon
                      LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                      by valvashon
                      The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                      Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                      11-24-2024, 12:08 PM
                    • BOSCHNJAK
                      by BOSCHNJAK
                      ABOUT ME INTRODUCTION FILE
                      2
                      024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                      2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                      2022 BEV, PROJECT ?
                      2021 BEV, PROJECT ?
                      2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                      2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                      12-28-2023, 02:09 PM
                    • DarKHawK
                      Asus 2021 ROG Strix G17 G713 not powering on and not charging.
                      by DarKHawK
                      I have an Asus 2021 ROG Strix G17 G713 that is not powering on and not charging. Board number is G533-6050A3250201.
                      When plugged in, I found that the 3.3v/5v regulator was getting extremely hot, so I removed, next I found a short on the 3.3V rail. Removed the two 3.3v mosfets and found one of them shorted, but still the short on the rail did not clear. Then I injected voltage at that rail, and found out that U60400 the 2.5v rail was also getting hot. Removing it changed the short from 0 ohms to about 5-6 ohms, then I remove a bunch of other suspect components but that did...
                      07-11-2025, 05:24 AM
                    • serious_electron
                      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                      by serious_electron
                      Hello Everyone!
                      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                      06-28-2025, 02:57 PM
                    • R7027
                      Paid for wrong boardview for Samsung Galaxy S7 (SM-G930F)
                      by R7027
                      I have a Samsung Galaxy S7 (SM-G930F) that's not powering on, and I want to try to repair it. I'm not a repair professional and while I have learned quite a lot in the past two months when I started to learn and gather equipment, supplies and information, I still have plenty more to explore and much more to learn.
                      So I was looking for the boardview file for this phone the other day, and I thought found it on another site. I actually had to pay for it. I paid for both the BVR and the BVRE version. Then I found this site, and the same files can be downloaded...
                      12-31-2022, 12:13 PM
