Re: 2200uf 10v cap replace with 6.3v?
if i have the choice, should i care about other factors besides the uf and voltage?
Yeah if it's too tall it would still be good for testing. If it works, great, you know what the problem was.
Then you should order some decent capacitors for a full recap anyway, especially if the rest are the same brand as the visibly failed one.
Extending the leads is a bad idea as it introduces additional resistance which defeats the purpose of a Low ESR capacitor to begin with. Also may increase lead inductance which adds its own problems.Last edited by Agent24; 07-06-2014, 05:46 PM.Leave a comment:
there are no other 2200uf caps in the psu. others in it are 16 and 50v.
why would it be a bad idea to extend the legs on the cap and place it elsewhere?Leave a comment:
it is a bad idea,
you could use it with the case open to see if it fixes the problem though.
what other caps are in the psu - 10v or 16v type?Leave a comment:
i found a single 2200uf 16v SXE brand with
(M)105c | 7(7) | 8I
on the side, would this be a good replacement?
although, i just checked. i might not be able to get the case back together if i do use that one, its too tall. by about a quarter inch
But! if i can run small wires and hot glue it in place elsewhere on the board... - is this a bad idea?Last edited by jasonbay13; 07-06-2014, 05:26 PM.Leave a comment:
if the voltage is even close to 6.3v the sanyo will explode - literally.
i wouldnt chance it.
if you have a broken computer, see what's in the psu - that's gotta have 10v and 16v rated caps in it.Leave a comment:
i have a westinghouse monitor 19" that had been taking 5-15 minutes to come on, so i decided i'd open it up and check for bad caps. well, i found 1 bulging.
the bad cap is 2200uf 10v capXon p723. radioshack never carries anything and i dont want to wait 3 weeks to get caps over the internet. i happen to have a broken computer with a few 2200uf 6.3v sanyo n.e.91 caps. would one of those work fine? or would it just go bad right away since the slightly lower voltage rating?
and should i replace more than just the bulging cap?Tags: None
by ssl6Hey Everyone,
Long time lurker, but I think this is my first time posting.
Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've... -
by black6hostGood day!
I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
I'm going to replace the caps and I'll be the first...-
by howardc64Fixed a 10yo HP inkjet with a bulging cap on the digital computer power rails (1 to 5V). Unstable voltages causing these inkjets to not boot properly or crash quickly. Seems like more and more of these are showing up nearing the 10 year mark. Board design seem to look similar for many of these printers.
https://h30434.www3.hp.com/t5/Printi...t/true#M99792202-03-2025, 09:50 PM -
by cloppy007I've found out that the all the Nichicon HM(M) caps on this board are faulty and need replacement. However, I didn't plan in advance and I don't have good replacement caps.
The original values are 2200uF, 6.3V, 5mm pitch. According to the datasheet, the rated impedance should be around 13-18 uOhms.
There are 8 of them, 3 to the left of the CPU socket and 5 on the bottom, very close to the northbridge. They are all connected, according to my multimeter.
I think I recall hearing that I don't have to use the same capacitance for in series...08-21-2023, 03:18 PM -
by rattlesnakeHi guys,
I'm going to recap this baby. I found it dumped in the street years ago, and now it's time has come. I remember having tested it and it posted back then.
Original caps are bulged and look nasty. All are SACON
11 x 1000uF 10v
12 x 1500uF 10v
1 x 470uF 16v
11 x 22uF 25v
1 x 10uF 25v
The smaller ones look fine. Should I replace them too?
I read on another forum that I could replace the 1500uF caps with 2200uF caps. Is that so?
The thing is I could get Sanyo 2200uF or Capxon 1500uF (or Jackon 1500uF)....-
Channel: General Capacitor Questions & Issues
- Loading...
