It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
PS. Additional diagnostic, after setting speedstep to minimum and turning off C1E, it did get into Memtest, where I'd never succeeded before, making me pretty sure that unstable power delivery is the problem
 I think that's a record (or close) for a CPU VRM. At worst, a few may be for CPU Vtt... , which is still less than 2V, so can still use 4V -rated polymer caps.
 Winblows 98 is maybe truly only useful for a handful of games. Most everything from the late 90's will run OK on 2k and XP... with some patches, at worst. W98 is mostly just for re-living the 90's retro experience... and maybe some older DOS games, I suppose.
