Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Which caps to replace: ECS P4M800Pro-M V1.0A
by momaka
by Paxman_SwedeHello!
I have studied the board and...-
Channel: General Capacitor Questions & Issues
by edithHello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
Thank you!-
I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.-
by reweaseHi everyone,
There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...-
- Loading...
