replacing caps in a PSU, same spec, different size?
  • logic7
    • Sep 2009
    • 25
    I just had a PSU crap out on me. Took it apart and found three fujjiyu 1000uf 10v caps that had gone bad. Looking in my parts bins, I found that I have three unused Sanyo 1000uf 10v caps, however they're physically smaller than the fujjiyu caps. Can I safely replace the larger caps with these smaller caps? I've never done a swap with smaller caps before and I'm hesitant to do it.
    • 31294
    Re: replacing caps in a PSU, same spec, different size?
    if the ESR is similar.
    the size is not important providing they will fit.
    • logic7
      • Sep 2009
      • 25
      ugh... I can't find any information on these Fuhjyyu caps (misspelled the name earlier). If the ESR is a mismatch, what's the worst that can happen?
      • c_hegge
        • Sep 2009
        • 5219
        It depends how far off it is and how tolerant the PSU's feedback circuit is. It may work just fine, or it might make the ripple worse.
          • 31294
          fuckyou - the manufacturer.
          http://www.fuhjyyu.com.tw/
          • audiofreak19
            • Apr 2013
            • 556
            • usa
            That's can mess it up? I just did this on my moms psu for her computer. There were 3 bulged. I had same spec ones to and it still had the same problem after.
              • 31294
              so the problem was deeper and the bad caps didnt cause the problem.
              what's the symptoms.
              • logic7
                • Sep 2009
                • 25
                ugh... figures their documentation doesn't give a value for ESR.
                • c_hegge
                  • Sep 2009
                  • 5219
                  If that's the case, they are probably GP caps (not low ESR caps). If that's the case, I usually use Panasonic FC, Nichicon PW, NCC LXZ, Ruby YXF or something like that. You might get away with lower ESR than that or you might not. It depends a lot on the design of the PSU.
                  • logic7
                    • Sep 2009
                    • 25
                    Yeah, they're the TN series general purpose caps.
                    The PSU is a cheapie 300W PSU I picked up years ago, but it's the only one I have available that has a 12V P4 connector on it and the machine it was used in was still in service.
                    BAH... Guess I'll need to look into different caps.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Assuming the original Fooljyyu's were 10mm diameter, any one of the following would work:
                      http://www.digikey.com/product-detai...0225-ND/266235 (Panny FC)
                      http://www.digikey.com/product-detai...877-ND/3563691 (Ruby YXF)
                      http://www.digikey.com/product-detai...1746-ND/589487 (Nichicon PW)
                      http://www.digikey.com/product-detai...1905-ND/756421 (Chemi-con LXZ)
                      • linuxguru
                        • Apr 2005
                        • 1564
                        Rubycon ZL, ZLH or ZLG are worth considering - the ZLH is available in 1500uF/10V/8mm that fits in some fairly tight spots.
