Missing capacitor
  • JorgeHernan
    • Apr 2006
    • 42
    Missing capacitor
    Hi guys
    I have bought an Intel d865 perl motherboard but a capacitor near the agp fets is missing (C6F10).Does anyone know what capacitor is?
    Thank you for your help
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Missing capacitor
    post a pic.
    not all pads are filled depending on board and parts on hand.
    • JorgeHernan
      • Apr 2006
      • 42
      • JorgeHernan
        • Apr 2006
        • 42
        • Tom41
          • Oct 2005
          • 338
          • England
          That pic is a bit blurred, but it certainly looks like there was a capacitor in there once, not just solder pads. In fact, it looks like the capacitor was physically ripped off the board with some force, leaving the legs and a tiny bit of the insides behind!
          Check the other capacitors in the vicinity - chances are, it'll be the same capacitor as one of the other nearby ones, connected in parallel. But just to be safe, find someone else who has the same board to check what capacitor should go in there.
          The 'unfilled holes' that kc8adu mentioned are like the ones at the bottom right of that picture.
          You know there's something wrong when you open your PC and it has vented Rubycons...
          • JorgeHernan
            • Apr 2006
            • 42
            Yes it is ripped off, what happened to this motherboard is what you mentioned.
            • starfury1
              • May 2006
              • 1256
              Cant help you directly with value of cap, hopefully someone here will know for sure
              If you are desperate
              At a guess , looking at the diameter of the silk screen overlay its probably the same value as the smaller one near it
              Looks like someone has been digging at the Vid connector which is possibly why it got ripped off.
              I would check (with a mag glass) to be sure no other damage was done to the surface mounted components near by, or pcb
              You could possibly varify the voltage rail by doing a point to point (resistance continuity measurement) with a multi meter to see which rail (5V 12V whatever) it was hanging across.
              (to help work out what it might have been and as a safety measure so you don't use a lower voltage cap across a higher voltage)
              As above, caps tend to be in groups of values and voltage so the overlay diameter can be a bit of a guide.
              Better thought if someone does know the value and can post
              HTH Cheers
              You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
              • Paul S
                • Sep 2006
                • 326
                The Intel web site for this card has a neat 3-D image of the board. I still can't make out the cap, but give it a look.
                Intel D865PERL
                • CaysE
                  • Feb 2006
                  • 40
                  Hopefully this might help: http://www.motherboards.org/reviews/...ds/1250_2.html
                  Looks like 25v 100uf in 6.3mm
                  • Paul S
                    • Sep 2006
                    • 326
                    There actually is another current thread in the badcap forums on this board. The original poster misidentified it as a D965PERL. Maybe you can ask him to identify the cap:
                    https://www.badcaps.net/forum/showthread.php?t=3717
                    • JorgeHernan
                      • Apr 2006
                      • 42
                      Yes! it turned out to be a 25v 100uf capacitor!Now is working flawlessly!Thank you!
                      • CaysE
                        • Feb 2006
                        • 40
                        You're welcome.
                        • MORETTIGIAN
                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                          by MORETTIGIAN
                          Title:
                          Description:
                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                          Procedure performed:
                          - Removed backplate
                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                          - Reapplied thermal compound
                          - Reassembled card
                          Observed behavior after reassembly:
                          - GPU powers on and operates normally under...
                          09-18-2025, 12:14 PM
                        • benberry24
                          surface go 2 missing capacitor, Motherboard# DA0Z93MBAE0
                          by benberry24
                          I have surface go 2 that a capacitor was nocked off. Can anyone tell me the value of the missing capacitor or if it's needed.
                          Motherboard# DA0Z93MBAE0...
                          09-12-2025, 10:16 AM
                        • krob80
                          PS5 Edm-010 No Power - Help identifying missing capacitor
                          by krob80
                          Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
                          It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
                          When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
                          I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
                          05-15-2025, 04:24 PM
                        • Prolog
                          RTX 3080 FE Identifying capacitor
                          by Prolog
                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                          I hope these photos make it clear which component I am referring to:
                          (yes, the soldering is a bit botched from removing the blown one, I know)
                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                          12-01-2024, 08:27 PM
                        • fab13
                          Capacitor missing on GTX 1050 TI 4GT OC - Need help
                          by fab13
                          Hello everyone and happy to post a message, I have an MSI GTX 1050 ti 4gt oc and at any time the card gives me a black screen and then nothing.
                          Even when trying to install windows for example at startup, the card started to make a black screen.
                          I have not yet tried to take measurements but I have observed a missing capacitor which is impossible to find on the boarview and seems nonexistent for this one or diagram.
                          In addition, my thermal camera shows an overheating of 40 degrees at this location.
                          I show you a photo named (InkedGTX 1050 GOOD_LI)...
                          12-30-2021, 04:27 PM
