Nichicon PW series rubber seal variant
  • nonanche92000
    • Mar 2014
    • 19
    • France
    I bought some Nichicon capacitor for a recapping project.
    I found that these capacitor , even if they are all from the same series (PW) , have different rubber seal.
    I have a couple of Nichicon gold tune too , with different rubber seal.
    see the photos:
    For the PW series
    For the Gold Tune
    I just want to know if this is normal?
    Main Pc : core i7 2600k @ 4.2 Ghz, ga-z77x up5 th , raptor WD 300Go , 16 Go crucial ballistix 1600 Mhz ,Asus Strix GTX980 DC2OC , Cooler Master storm trooper , Corsair AX860i.
    Laptop : Asus X73SV-TY549V
  • mariushm
    • May 2011
    • 3799
    Re: Nichicon PW series rubber seal variant
    Pictures don't load directly.
    Here's pictures on other host :
    http://i.imgur.com/MqQjgn5.jpg
    http://i.imgur.com/vjpEy0o.jpg
    Where did you buy the capacitors from? If eBay, most likely some, or all of them, are fakes.
    • nonanche92000
      • Mar 2014
      • 19
      • France
      Thanks for the quick reply , they all come from Mouser.com.
      • lti
        • May 2011
        • 2553
        They shouldn't be fake.
        I haven't used Nichicon caps as large as the two largest, but the rest look correct.
        • mockingbird
          • Dec 2008
          • 5484
          They may be from within the same series, but they are different sizes, so that is quite normal...
          • c_hegge
            • Sep 2009
            • 5219
            Don't use 3rd party image hosting, as it is slower to load. Attach your pictures here (I've done it for you this time).
            • nonanche92000
              • Mar 2014
              • 19
              • France
              Hi guys,
              thanks to all of you for all the responses .
              I have sent some pictures directly to Nichicon because they told me to , after explained the difference i found on the rubber seal .
              i will keep you update .
              thanks
              • nonanche92000
                • Mar 2014
                • 19
                • France
                hey guys ,
                Nichicon sent me a very useful document, this document show that for different nichicon capacitor size , they have different rubber seal .
                So nothing to worry about it, this is normal, hope this will be useful for all nichicon users .
                See the document:
                • Jooo
                  • Oct 2011
                  • 222
                  • Finland
                  Exactly the same thing you were told in this thread...
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Good info. Thank you for sharing.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4978
                      • New Zealand
                      Yes, but with this document you can see if the bung shape is correct for the size, or possibly a fake...
                      -David VanHorn
                      • DrewPhillips
                        Capacitor Diarrhea - Nichicon PL Series
                        by DrewPhillips
                        Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                        The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                        03-02-2025, 10:18 PM
                      • chth96
                        Is there datasheet for nichicon LXJ series?
                        by chth96
                        I want to calculate capacitor ESR referring to below guide.
                        https://forum.digikey.com/t/calculat...-from-tan/2633
                        I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                        I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                        Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                        11-20-2022, 08:11 AM
                      • chth96
                        Is there any datasheet for nichicon RT(M) series?
                        by chth96
                        A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                        https://www.badcaps.net/forum/troubl...e-been-blew-up
                        and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                        But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                        I have spare console...
                        11-28-2023, 03:36 AM
                        ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                        This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-12-2024, 03:28 PM
                        ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                        This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
