Identification of capacitors on MSI mainboard
  • tommi
    • Feb 2014
    • 6
    • germany
    im try to finde out, which capacitors MSI on their mainboard "H87I" use.
    Picture from the mainboard:
    I hope anyone can help me and know, which manufacturer this capacitors produce, and if they are good or not. Oftern the mainboard manufacturers advertise, that the capacitors all are "100% japanese made" to accent the quality. But on the MSI site, the capacitor only called "Hi-c CAP" or "Dark CAP" which is not really a statement for quality.
    Thank you for reading an maybe someone can tell me the manufacturer.
    Tom.
  • selldoor
    Slow Learner
    • 7870
    Re: Identification of capacitors on MSI mainboard
    A close up picture of the cap top and sides would help - please post pictures
    using "manage Attachements" rather than posting in line.
    • tommi
      • Feb 2014
      • 6
      • germany
      Thank you for your answer. I tried to find a better picture of the capacitors on the mainboard. I found some pictures which show the caps a little bit better, but also not very closeup, sorry.
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        MSI's marketing picture does not necessarily show which components the product sold to consumers will actually have
        For example, this thread https://www.badcaps.net/forum/showthread.php?t=26130
        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
        • tommi
          • Feb 2014
          • 6
          • germany
          Ok, thank you for information. The first postet picture is the marketing picture of MSI, that's correct. But the second one are pictures from a review report of an MSI mainboard. So it seems, that MSI realy use this "dark CAPs" for their products. Maybe this is a custom-built capacitor especially for MSI?
          • selldoor
            Slow Learner
            • 7870
            It could be - I have tried looking at lot of caps and co logos but couldnt see anything. The pic is still not that clear look like parallel lines with a v or x
            but could be an arty m or w - sorry cant help.
            • tommi
              • Feb 2014
              • 6
              • germany
              I understand. However, thank you for trying to identify the capacitors! Can you maybe tell me a web page or something near it with an overview of pictures from different manufacturer of polymer-capacitors?
              • mariushm
                • May 2011
                • 3799
                These capacitors are just plain low esr polymer capacitors from Nichicon, Nippon Chemi Con or other brands.
                They just ordered a large enough volume to make a custom batch colored dark and reprintered with that gray paint.
                Initially I was confused by the markings because as far as I'm aware only Panasonic uses that small line to mark the negative side, but they only make surface mount capacitors with that mark. Their radial leaded polymer capacitors are OS-CON branded and have a magenta/dark pink band.
                Asrock used high quality low esr , 2000h@105c Nichicon LF capacitors and named them "Premium Golden Caps" :
                http://www.asrock.com/mb/Intel/X79%20Extreme3/
                Premium Gold Caps are luxury capacitors. These 100% Japan-made solid capacitors are sleek, high gloss caps with a premium gold coating representing long life and stable performance.
                luxury caps - not really, they're available retail and not that expensive. high gloss caps - what's this got to do with performance?, gold coating - won't do shit for performance, it's just aesthetics.
                It was just marketing... and it's the same with MSI.
                • mockingbird
                  • Dec 2008
                  • 5488
                  You forgot about the sleeveless Panasonic FLs Asus used to use:
                  But you're right, I don't think the markings on those caps resemble these.
                  • tommi
                    • Feb 2014
                    • 6
                    • germany
                    Okay, thank you for the explanation. But in the case if Asrock, the "golden CAPs" have tha same marking and the same marking stile, as common polymer capacitors from Nichicon. Also in the promotion of Asrock they write "100% japan made" to accent the quality of this capacitors.
                    In case of MSI the marking text of the capacitors dosent looks like any famous capacitors of an japanese manufacturer. Also in the promotion text MSI never allude, that the capacitors are japan made.
                    So, if that black MSI capacitor are really relabeled ones of a common japanese manufacturer, so I think it's a bad marketing of MSI.
                    • marcin.jakubowicz87
                      Asus TUF RTX 3080 10G-Gaming 2I3S missing capacitors identification
                      by marcin.jakubowicz87
                      Hi
                      I have a card that is missing capacitors, in the places marked in red.
                      Does anyone know their value?
                      Thanks in advance for your help​...
                      04-02-2025, 05:41 AM
                    • dragon3x
                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                      by dragon3x
                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                      power on.
                      Here are some examples :
                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                      switching supply area).
                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                      than 6.3 V.)
                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                      I replaced capacitors with aluminum-polymer.
                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                      03-21-2025, 02:46 PM
                    • Mirenia
                      Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                      by Mirenia
                      I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                      I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                      In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                      The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                      03-30-2025, 06:47 AM
                    • orcic
                      MASTER TL240 and new mainboard LW36BKC01
                      by orcic
                      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                      Now I have some doubts about how to connect the new mainboard to the old power supply.
                      First of...
                      05-12-2023, 08:10 AM
                    • slybunda
                      AA and AAA battery charger capacitors?
                      by slybunda
                      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                      it has inside:
                      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                      2 x 470uf 16v LZ105c branded as G.Luxon
                      not heard of these brands are they any good?
                      iv attached photos of the charger and the board inside for an idea on the type of...
                      12-24-2023, 04:41 AM
