Panasonic FJ/FL genuine or not?
  • kItE80
    replied
    Re: Panasonic FJ/FL genuine or not?
    Originally posted by momaka
    I would say they look genuine to me as well. I just compared them to a few 16V 1500 uF Panny FL caps that I pulled from an Xbox 360.
    Can we see a picture of the voltage/capacitance rating and another of the bungs too? Just to really make sure they are legit.
    Of course. This is the voltage/capacitance picture. The pictures are mine.
  • ben7
    replied
    They look like the right bungs.
    However, is that a picture you took? If not, we need to see the pics of the caps you got. Some sellers will fool you by putting pics of good caps on the listing, then give you fake ones.
  • LLLlllou
    replied
    +1 genuine
    replied
  • kItE80
    replied
    Thank you, I needed a confirmation.
  • goodpsusearch
    replied
    I think they look genuine to me.
  • kItE80
    started a topic Panasonic FJ/FL genuine or not?
    I bought these caps on e**y from HK and I would like to know if they are genuine. Thanks
  • Andre Gilbert
    by Andre Gilbert
    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
    11-20-2024, 08:52 PM
    by momaka
    03-12-2025, 03:42 PM
  • AquaMan Ua
    by AquaMan Ua
    05-17-2025, 09:40 AM
  • stecos
    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
    by stecos
    Hi everyone!
    For my passion for technology I'm now collecting several...
    11-28-2022, 11:39 AM
  • aa10aa10
    Panasonic Toughbook CF-33 mk1 BIOS repair
    by aa10aa10
    Good day,
    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
    01-21-2025, 06:13 AM
