Can i replace nichicon 1800uf 6.3v for ruby 820uf 6.3v
  • shookie
    • Mar 2007
    • 7
    As the title says.. I have 820uf 6.3v Rubycons
    I want to know if i can replace them for my Dell's Nichicon 1800uf 6.3v caps that bloated and died.
  • shookie
    • Mar 2007
    • 7
    Re: Can i replace nichicon 1800uf 6.3v for ruby 820uf 6.3v
    Or if i can replace the Nichicon 1800uf 6.3 with Sanyo 3300uF 6.3v
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      it would not be recommended to decrease capacitance so the 3300uf would be best.
      • shookie
        • Mar 2007
        • 7
        Well my Dell gx270 mobo has 9 bloated caps alongside the CPU. Would it be safe to replace all nine (1800 uF 6.3v) with 3300uf.. 6.3...
        I also have 1500 uf 6.3's in stock... want to get this machine up already..
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          What series for the various vendors?
          PeteS in CA
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            depends on series.
            low esr 820 may be ok if like a mbz 8mm x 25 like the ones i have.
            i see 1500-1800 in 8mm on some boards and a different batch has 820
            the 820 has a lower esr than the 1500-1800
            • shookie
              • Mar 2007
              • 7
              well i just loaded the 3300uF 6.3 in replacement for the busted 1800uf 6.3
              Am i looking at mobo failure. Seems to be running nice now.
              I plan on purchasing a kit from here regardless and get the proper stuff. I just needed to get this machine up and running.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I've used 1500uF MBZ's in place of those 1800uF Nichi's many times, never had any issues. I would not use 820uF or 3300uF, that's a bit too extreme.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • shookie
                  • Mar 2007
                  • 7
                  Trying to read before i ask.. But im kind stuck as you ask me for the type of series?
                  • shookie
                    • Mar 2007
                    • 7
                    would you go as far as 3300 uf? cause that means tomorrow i will be popping out these 3300's and putting in 1500 uF's
                    • shookie
                      • Mar 2007
                      • 7
                      Rhetorical question sorry. Would i be safe to leave those 3300uf's in my machine for about a week... if not for about 48 hours
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        the only boards i used the 820's in were ones that i have seen with both.
                        i agree that without knowlege of the board being produced alternatly with 820 and 1500 not to try that sub.
                        in a pinch one can check that all those caps are in paralel and stuff every other space with 3300 in place of 1500.
                        most vrm output caps are chosen for low esr and also price.esp with cheapie mfr's that use cheap parts just adequate to work.leaves a big margin for higher value part without issue.
                        • bgavin
                          • Jan 2007
                          • 1355
                          Considering that premium caps are spec'ed at +/- 20%, would it not be safe to apply a rule of thumb: go up in capacitance within 20%, and no worries?
                          For example, replace 1500 uF with 1800uF. The larger cap is exactly 20% higher than the smaller.
                          • spiros.p
                            EV dsp,replace the nippons lxz with nichicon fw ?
                            by spiros.p
                            Hi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
                            12-19-2023, 12:26 AM
                          • spiros.p
                            nichicon LKS for psu to replace the nippon SMH
                            by spiros.p
                            i have ordered few nichicon LKS for psu to replace the nippon SMH.what do you think guys? anybody use them?
                            02-03-2023, 07:48 AM
                          • DrewPhillips
                            Capacitor Diarrhea - Nichicon PL Series
                            by DrewPhillips
                            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                            03-02-2025, 10:18 PM
                          • spiros.p
                            replace nichicon HE series 2200mf 16v with vishay BC 136 SERIES 2200mf
                            by spiros.p
                            i have replace nichicon HE series 2200mf 16v with vishay BC 136 SERIES 2200mf.measuring the nichicons sean on meter 2550mf and zero esr.i measure and the new vishays and sean 2080mf and near zero esr that looks normal.the nichicons numbers is normal so far from label data?and what about vishay 136 any infos from other users here?
                            09-27-2021, 06:12 AM
                          • OriginalDaggers
                            XBox 360 All Polymer Capacitors
                            by OriginalDaggers
                            As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
                            I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
                            If I have things right, I can replace them TO
                            x9 : 1500uF 16V 10x20mm
                            TO: 470uF Nichicon FPCAP R7
                            x2 : 820uF 6.3V 8x12mm
                            TO: 2.5V 820uF Nichicon FPCAP R5
                            On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
                            What's a good replacement for the smaller...
                            This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                            02-20-2024, 12:49 PM
