i have replace nichicon HE series 2200mf 16v with vishay BC 136 SERIES 2200mf.measuring the nichicons sean on meter 2550mf and zero esr.i measure and the new vishays and sean 2080mf and near zero esr that looks normal.the nichicons numbers is normal so far from label data?and what about vishay 136 any infos from other users here?
Re: replace nichicon HE series 2200mf 16v with vishay BC 136 SERIES 2200mf
Not familiar with Vishay caps, but here is the datasheet for Nichicon's HE series:
And for Vishay's 136rvi series:
https://www.badcaps.net/download/?id=8cf5417a
Depending on the case size, the 2200uF, 16V HE part is rated for 27 milliohms and 2230 mA or 43 milliohms and 2210 mA.
The Vishay part is in a different case size than either HE part and is rated for 38 milliohms and 1600 mA.
38 milliohms may be OK, but the significantly lower ripple current rating may be reason for concern.
I don't know what is available to you there in Greece, so the Vishay part may be what is available to you. The Nichicon HE series is very similar to Nippon Chemicon's KZE series, and fairly similar to Nippon Chemicon's KY series, Panasonic's FM series, and Rubycon's ZL series. I don't know Vishay BCcomponents' quality. I do know that the Nichicon, Nippon Chemicon, Panasonic, and Rubycon series I listed are very good (and also Nichicon's HD series).PeteS in CA
2500-odd uF on a 2200 uF cap is generally OK, as that's about +15% higher capacitance. Electrolytic caps are rated +/-20%. Thus, for a 2200 uF cap, anywhere between 1760 uF and 2640 uF is still considered in spec. That said, do beware that when a capacitor's capacitance starts going high and approaches the 20% mark, the cap should be deemed suspect, because that may be indicating that the electrolyte inside the capacitor may be starting to attack the aluminum on the plates, increasing the capacitance at the expense of higher leakage current and also lower tolerable operating voltage. That said, I don't think Nichicon HE are known to fail in this matter, so your Nichicon HE caps are more than likely OK.Comment
thanks for answers guys. i have forgoten to note the vishays is 50 volts that i have available.the last years i have replace hundreds of caps from psus and all types of cirquits and ofcoures measure every time new and old.so big difference never sean again like the nichicons.always i measure 5 to 20% down from label data.and is quite normal.few times only sean that extreme numbers on cheap crap chinese no name capacitors from psus that i have to repaire.from 2200mf to 5550 is a bit strainge and high number.Comment
by DrewPhillipsHello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...-
by chth96I want to calculate capacitor ESR referring to below guide.
https://forum.digikey.com/t/calculat...-from-tan/2633
I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
Is there anyone who still has old nichicon datasheet which has information of LXJ series?-
by chth96A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
https://www.badcaps.net/forum/troubl...e-been-blew-up
and I finally fixed​ this retro game console by soldering varistor and glass fuse.
But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
I have spare console...-
This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
- Loading...
