NICE -- are these considered "Solid" capacitors?
  • handyrandyrc
    • Feb 2007
    • 8
    PNY Geforce Ti4200 card... Are these considered "solid" caps? You can see we lost a FET, too.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: NICE -- are these considered "Solid" capacitors?
    nope they are not
    • gonzo0815
      • Feb 2006
      • 1600
      They have vents, solid polymer usually not. But probably there should be some solid polymer caps. On my old GF4280 there were only Oscon polymers. And it is runing fine so far.
      • Big Pope
        Approved Vendor
        • Dec 2005
        • 426
        Most of guys always have a wrong concept everywhere in the world that metal body caps = solid caps or polymers.
        My SAMXON Capacitors Database HERE!!
        X-CON is a new brand for SAMXON's Polymer Capacitors.
        • PeteS in CA
          • Aug 2005
          • 3583
          • USA, Unsure of Planet
          The vents are pretty much a tip-off. Polymers don't have the liquid electrolyte to generate hydrogen gas, hence no need for vents.
          PeteS in CA
          • Tom41
            • Oct 2005
            • 338
            • England
            There are exceptions to the rule. I have seen for myself some Fujitsu solid polymers that have a K vent on the top. Polymers can bulge too, though usually not as violently as electrolytic caps - it's caused by the seal on the cap being imperfect and moisture in the air getting in.
            Here's a pic from my own board. (The yellow ones are Fujitsu, the black ones are Rubycon). The Fujitsus seem to be bulging ever so slightly...
            You know there's something wrong when you open your PC and it has vented Rubycons...
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              i have seen those fujitsu polymers bulging badly and high esr on lots of asus a7 boards.
              • amelbye
                degradation of solid state capacitors in motherboards?
                by amelbye
                Hi, I have a question regarding a motherboard with SS capacitors that I'm having trouble with. Every now and again it would give overclock failed at boot even when not overclocking.
                Recently more often, and the last few weeks at every single boot. It seems like the typical capacitors needing to warm up, then everything is fine.
                Weird thing is the capacitors are all solid state. Do SS capacitors degrade the same way as normal caps? Is it worth trying to recap the board?
                I have already replaced the PSU.
                The board is a gigabyte x79 ud3....
                11-06-2022, 10:35 AM
              • dragon3x
                by dragon3x
                power on.
                Here are some examples :
                switching supply area).
                than 6.3 V.)
                03-21-2025, 02:46 PM
              • slybunda
                AA and AAA battery charger capacitors?
                by slybunda
                hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                it has inside:
                2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                2 x 470uf 16v LZ105c branded as G.Luxon
                not heard of these brands are they any good?
                iv attached photos of the charger and the board inside for an idea on the type of...
                12-24-2023, 04:41 AM
                After all of...
                07-13-2024, 08:14 PM
              • Cama
                Solar Inverter - SMH-II - 2 missing capacitors
                by Cama
                I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                My model is : EASUN SMH-II 7 KW
                Mother Board : P/N 18947-002401250250
                Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                Thank you...
                09-12-2025, 02:50 AM
