Fake / counterfeit capacitors are getting better
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Usually, there is always something visually wrong with a counterfeit capacitor.
    However, these capacitors look perfectly genuine on the outside.
    There seems to be nothing wrong, bung is correct, vent is correct, printing is correct and high quality.
    Luckily, always when I buy capacitors from questionable distributors (china) I measure them with my ESR / Capacitance meter.
    This time I noticed something weird: these 1000uF capacitors only measure approx 500uF.
    Dont be like me, always buy your capacitors from reputable distributors or straight from the manufacturer!
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Re: Fake / counterfeit capacitors are getting better
    kaoz.... those Chemicon....
    • mariushm
      • May 2011
      • 3799
      Bung is not correct.
      United Chemicon bung as far as i know has channels in the form of a T:
      • Jooo
        • Oct 2011
        • 222
        • Finland
        These are 10mm width capacitors, and according to KY datasheet, the bung is correct: 10mm and smaller capacitors have this type bung.
        Only 12.5mm and wider capacitors have the T-style bung.
        • lexwalker
          • Feb 2011
          • 307
          • Malaysia
          Many fake Nippon Chemicons especially from China market, do not match the datasheet specifications especially when it comes to case size/dimensions. Many were shorter than what's printed in the datasheet...
          • c_hegge
            • Sep 2009
            • 5219
            Where did you get those caps from?
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              sound like more ebay wonders.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • mockingbird
                • Dec 2008
                • 5488
                Excellent fakes, if I say so myself.
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  Have you checked the esr meter batteries? Did you calibrate it recently?
                  • PeteS in CA
                    • Aug 2005
                    • 3583
                    • USA, Unsure of Planet
                    Maybe it's just that I haven't worked with lytics for a few years, but there's something about the lettering of the date/lot code and the tolerance and temperature rating that doesn't look quite right.
                    PeteS in CA
                    • mockingbird
                      • Dec 2008
                      • 5488
                      Even _legit_ caps soemtimes have poor or inconsistent lettering, so unless the lettering is an obvious giveaway, like if the font is wrong or if it's really fuzzy then it's not a sure way in itself to identify fakes. The lettering on these is pretty darn good. I wouldn't be surprised if the sleeving and bungs were sourced from UCC themselves. Remember, Japan is undergoing an economic recession and a massive nuclear problem in Fukushima. I wouldn't put it past certain elements of their corporations to start selling a little on the side to make a few extra bucks.
                      • Rambo
                        • Nov 2013
                        • 15
                        • Pakistan
                        Look fairly fake to me.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Yeah, I noticed that too, especially the temperature markings, the font just looks wrong. It seems too tall and not wide enough like the real NCC caps.
                          Muh-soggy-knee
                          • Jooo
                            • Oct 2011
                            • 222
                            • Finland
                            Just to rule out that my esr meter was bad, I checked the capacitors with a capacitance meter I also have. The results are same.
                            I also took a better shot of the datecode. The upper cap is the KY, lower cap is very old but genuine 470uF 25V LXF-series capacitor.
                            (I trimmed the lead on the KY myself so it would fit the capacitance meter, that wasn't like that when I received it.)
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              It might just happen to be that you got ones that were sitting for a while, maybe in a hot and/or humid environment, and they just went bad for no reason. If they are new, (I don't know how to read NCC date codes) then maybe you could take one apart to see inside. If the insides look OK, then, well.., you could try seeing if NCC will take a look at them for you!
                              Muh-soggy-knee
                              • Jooo
                                • Oct 2011
                                • 222
                                • Finland
                                Just dissected one. It was all nice and wet.
                                I was thinking too that they may be old and stored wrongly, but even then I dont think they all would have failed like this.
                                I have ten of these caps and every single one of them measure something between 494 - 501uF and ESR 0.02 - 0.04 ohms.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  Perhaps try reforming them... i.e. slowly bring up the voltage on them through a resistor up until full rated voltage is reached, and leave there for 24 hour or longer. Then see if that has improved the capacitance.
                                  These look way too good to be fakes IMO (if they are, I give my applause to the Chinese who made these).
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    maybe the ebay fakers ran into a huge qty of 470uf 35v ncc and resleeved them for whatever they had demand for?would explain the bung looking ok.
                                    the font is a bit off on those supposed 1000uf.check leakage at 35v and see if in spec for a 470@35
                                    • k1b0
                                      • Oct 2012
                                      • BiH
                                      Well, I made couple of orders on ebay from unknown sellers, since there was some problem with ordering from egekecu.
                                      Soon I'll have capacitance meter so I will update posts with info on real capacity measurement.
                                      And here they are(some of them; I will post others latter):
                                      1800uF 6.3V supposedly Panasonic on the left and on the right I've put some genuine used ones from dead motherboards
                                      User janeh2100 - 20pcs $3.80
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        Look at the bungs there ^ ! Pretty good fakes. Do their vents look like they do on real Panasonic caps as well?
                                        I wonder if they are just re-sleeved real Panasonic caps.
                                        • Olkus
                                          Elna capacitors - fake?
                                          by Olkus
                                          I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
                                          09-01-2023, 02:45 AM
                                        • dragon3x
                                          by dragon3x
                                          power on.
                                          Here are some examples :
                                          switching supply area).
                                          than 6.3 V.)
                                          03-21-2025, 02:46 PM
                                        • slybunda
                                          AA and AAA battery charger capacitors?
                                          by slybunda
                                          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                          it has inside:
                                          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                          2 x 470uf 16v LZ105c branded as G.Luxon
                                          not heard of these brands are they any good?
                                          iv attached photos of the charger and the board inside for an idea on the type of...
                                          12-24-2023, 04:41 AM
                                        • Hitto
                                          Fake Nichicon capacitors with almost-perfect sleeve?
                                          by Hitto
                                          Fake Nichicon capacitors with an almost-perfect sleeve?
                                          Same font, perfect logo, same size of the sleeve. The air vent looks okay. The diameter of the capacitors is correct per datasheet.
                                          It truly looks like the real thing.
                                          I doubt that you would distinguish it from a genuine one.. if it wasn't for the bung.
                                          Shall we be afraid, at this point, that even the bung can be replicated?...
                                          01-09-2021, 03:07 PM
                                          After all of...
                                          07-13-2024, 08:14 PM
