single bad cap near northbridge causes boot issues?
  • logic7
    • Sep 2009
    • 25
    Back again, this time with a different board. I haven't recapped the Asus P4G800-V I posted about last time (I'll get to it soon!) having bought a replacement to hold me over.
    This time, I have a single bad cap on it's replacement: an ASRock P4VM890 board.
    I've circled the cap in this stock pic since I forgot the SD card the pic I took was on. Anywho, this is the ONLY bad cap on the board. I've been having problems with this thing refusing to boot. I originally had a 3.4GHz P4 HT Prescott on the board along with a firewire card and Geforce 8400 PCI-E video card. It started to flake out on me, so I thought that maybe the PSU wasn't up to snuff and added an Antec 430W unit. Still flakey, I swapped the prescott core processor with a 3GHz P4 HT Northwood core unit, which solved the problem momentarily as the next day it was refusing to boot again. I removed the FW card and all was well until the next day. Removed the video card and reverted to the onboard video and it was ok again... unless I ran anything 3D related. I pulled the machine out yesterday and inspected the board and found this lone bulging cap near the VIA P4M890 northbridge.
    Could this be the source of the problems I'm having? I'm completely puzzled by this since I have an old Gateway PC with an intel P4/i845 motherboard in it with bad caps everywhere (including those near the northbridge and PCI slots), yet it functions just fine.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: single bad cap near northbridge causes boot issues?
    Absolutely it can cause it to not boot. The ESR is probably very high across that cap, and motherboards are only happy with ultra low ESR, so I'm willing to bet that's why. The Northbridge is used to for communication between the CPU and the RAM, so it's very important to be functioning properly
    The one functioning just fine may be getting very low ripple from the PSU so sometimes you can get away with bad caps on the mobo if that is the case
    • logic7
      • Sep 2009
      • 25
      Awesome! Since I forgot to bring the pic with me, I don't have the particulars of the cap so I can't swing by Frys to see if they have a replacement. Hopefully I'll have this issue solved by tomorrow evening! I'm TIRED of using the far slower gateway.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Yeah I don't blame you! Although, I do not recommend getting caps at Fry's, from what I've seen they have a horrible selection and no low ESR caps. You would want to order them from Mouser or Digi-Key. So list the specs and we can find a good replacement for you. Hard to tell but those black caps look like OST or G-Luxon. Ideally, you would want to replace all of those, or at least the ones that are 1000uF or higher
        • logic7
          • Sep 2009
          • 25
          They're black with orange/copper markings. I'll post it up tonight when I get home.
          • PeteS in CA
            • Aug 2005
            • 3586
            • USA, Unsure of Planet
            What P4 said. Get all the known junk out, and use good parts, even if it takes longer.
            PeteS in CA
            • logic7
              • Sep 2009
              • 25
              Ok, finally got a chance to look at the cap: It's blue with copper colored markings. Evercon 1000uf 6.3V caps. There's quite a few of them on this board too.
              • LLLlllou
                • May 2011
                • 201
                To call Evercon shit would be an insult to actual shit.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Yes....Replace 100% of the Evercon if you plan on using the board. They are some of the worst of the worst. Even in the low stress roles they will dry out and die eventually
                  • y_not
                    Same 'ol Song
                    • Aug 2009
                    • 147
                    Originally posted by LLLlllou
                    To call Evercon **** would be an insult to actual ****.
                    That's pretty durn funny! Thanks for the laugh.
                    How to properly apply thermal grease - Y_not's way.
                    • logic7
                      • Sep 2009
                      • 25
                      I counted them up. 18 Evercon 1000uf caps on the board. I'll start with the bad one now and eventually replace them all. Any recommendations on replacement caps?
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        What is their voltage and dimensions? I'm guessing they are 6.3V? If so I would get these: http://www.digikey.com/scripts/dksea...=0&pageSize=50
                        • logic7
                          • Sep 2009
                          • 25
                          Yeah, I posted the voltage last night.
                          That looks like the right size, I'll double check when I get home.
                          After this one, my Asus board is next, followed by the Gateway/Intel unit and my server's Tyan dual Athlon MP board which, like the Gateway, has plenty of leaking caps yet still runs like a champ (current uptime is about 2 months)
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Whoops, my fault Sounds good, make a separate thread for each of them
                            • logic7
                              • Sep 2009
                              • 25
                              found a local supplier for Nichicon caps. Lil pricey ($1.05 each... sheesh), but I'm going to replace the caps in groups 'cause I need to get this PC back up and running by tomorrow evening.
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                What series are the nichicon caps?
                                • lexwalker
                                  • Feb 2011
                                  • 307
                                  • Malaysia
                                  Make sure they are low ESR or low impedance models such as HE, HM, HN, HZ, PM, PW or PS series. Also do beware of counterfeit/fake Nichicon capacitors. Quite easy to detect counterfeit/fake ones from the rubber seal/bung at the bottom, and sometimes a different vent gives them away (e.g. using "Y" vent instead of standard Nichicon "X" vent).
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16959
                                    I have all this stuff you know.... https://www.badcaps.net/store/
                                    Try supporting the site a little...
                                    <--- Badcaps.net Founder
                                    Badcaps.net Services:
                                    Motherboard Repair Services
                                    http://folding.stanford.edu/
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • logic7
                                      • Sep 2009
                                      • 25
                                      No doubt. I did pick up the caps from the local guy 'cause I needed that machine up and running ASAP for a project (plus I do like to support local businesses, even if their prices are a bit crappy)
                                      I still need to get 1800uf 6.3V caps for my other P4 board. I'll order them from you this time.
                                      • theokretes
                                        • Jul 2013
                                        • 49
                                        Also, those two evercons at the top left (above the brown slot right next to the realtek chip), those are the decoupling capacitors. If you replace both with 470uF ones the onboard audio will actually be able to get bass response.
                                        Make sure they're not low-ESR though. Some decent general purpose ones will work fine (Nichicon, Rubycon or ELNA will do just fine).
                                        I'm assuming they underrated them at 100uF (or worse, 47uF).
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
